Old August 25th, 2013, 10:27 AM   #1
kslane
kslane's Avatar
Motorcycle(s): 2003 Ninja
floats too high or low
my cycle will not start now unless i have full choke on and full throttle. I am assuming it is the floats. Thank you for your help
kslane is offline   Reply With Quote
Old August 25th, 2013, 10:59 AM   #2
What makes you think that?
Old August 25th, 2013, 11:06 AM   #3
kslane
kslane's Avatar
well I said I am assuming. I really do not know. It is getting fuel. the only thing i have not done is adjust the floats.
Old August 25th, 2013, 11:14 AM   #4
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
What is your idle set at after the engine is fully warmed? Do you know when the last time the carbs were cleaned?
Mods: Offset clutch pressure plate
Old August 25th, 2013, 11:22 AM   #5
Originally Posted by kslane View Post
my cycle will not start now unless..........
What has changed or been done on the bike lately?
Is this a sudden change in starting behavior?
Testing is always better than assuming.
Old August 25th, 2013, 11:35 AM   #6
kslane
kslane's Avatar
The only thing that has changed is that I found a leak comming from the bolt holes where the faring connects at the top of the tank. I fixed the leak.
Before i had the leak the cycle ran pretty good and was just needing some minor adjustments
Old August 25th, 2013, 12:19 PM   #7
Hmmm....
Maybe you got some water in the gas or something has a jet clogged. It has to be something simple or your need a carb cleaning.
Vac line off maybe? Hard to get a handle on with limited info.
Old August 25th, 2013, 12:27 PM   #8
kslane
kslane's Avatar
Hmmm....
I will be taking the carb off tomarrow to check eveything and clean it.
Old August 25th, 2013, 02:11 PM   #9
While you do that drain the tank into a glass container, check that:
1) The petcock is working with vacuum applied
2) That the flow is about 2 cc per second or 1/2 cup per minute
3) That the fuel is not contaminated with water (which will stay at the bottom of the container)
Old August 27th, 2013, 12:02 PM   #10
kslane
kslane's Avatar
well i found two disconnected vacum lines. taking out my carb will check eventhing else while it is out.
Old August 27th, 2013, 12:16 PM   #11
verboten1
verboten1's Avatar
MOTM - June '15
there you go, you may have found your issue.
Ride more, worry less.
Old August 27th, 2013, 12:53 PM   #12
FvnnyL3tt3r1ng
Bikes probably gonna run like new now lol
