Old September 3rd, 2013, 06:12 AM   #1
juanpak87
Motorcycle(s): ninja 250
new gen shock on pre gen
Hey all, i want to change the shock on my bike and was wondering if all i need is the new gen shock or is there more parts i need to change it?
juanpak87 is offline   Reply With Quote
Old September 3rd, 2013, 06:21 AM   #2
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
I've put the shock from an '08 onto my '89 EX250 with good results.
You'll need some form of adjustor to change the preload.
GeorgeRYoung is offline   Reply With Quote
Old September 3rd, 2013, 10:23 AM   #3
@choneofakind has one on his as well.
Old September 3rd, 2013, 11:53 AM   #4
The shock is a straight swap. I bought the OE adjuster tool for the newgen from cheapcycleparts.
All you have to do is take off the old shock and then bolt the new one in its place. The coolant reservoir is even shaped correctly to allow you access to the top bolt without removing anything.
Also, keep an eye out for new shocks off the 300. Rumor has it they revalved the shock for a little more damping. That's a straight swap as well, and it will have many fewer miles than an 08-12 shock (most likely)
Old September 3rd, 2013, 12:26 PM   #5
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
haha it's funny how I would've paged chone as well..lol.
...Rumor has it they revalved the shock for a little more damping...
What would the increase in damping do?
The Bike | The Truck
Old September 3rd, 2013, 02:38 PM   #6
More damping will make the shock resist compression/rebound. So if you notice issues with your bike pogo-ing, you might look into a 300 shock.
Or I guess I should say different valving for different damping. Not sure if it's more or less damping but reviews of the suspension seem generally positive in comparison to the newgen (and the pregen for sure!)
Old September 3rd, 2013, 02:48 PM   #7
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old September 3rd, 2013, 04:16 PM   #8
Lychee
sail away
Lychee's Avatar
300 shock works well on my bike. Don't have a new gen shock to compare against, but I have heard the same rumors that Chris heard.
Old September 4th, 2013, 07:01 PM   #9
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
Sorry for hijacking the thread but i didnt wanna start a new one.
I just put the newgen shock on my pregen, went for a ride and didn't notice any difference...the little handle is at the middle (3rd?) right now
which setting am i looking at for riding solo and 2up? should I move the handle higher for stiffer rear?
edit: opps forgot to mention, im 135lbs btw
fr1dayn1ght is offline   Reply With Quote
Old September 4th, 2013, 08:38 PM   #10
Singh2jz
Singh2jz's Avatar
Change it to the 5th(stiffest) setting..
Old September 4th, 2013, 09:10 PM   #11
You didnt notice any difference? It was pretty apparent to me when I made the switch. Not perfect, but a definite improvement as far as smooshyness goes.
I'm also 135 without gear.
Old September 5th, 2013, 07:58 AM   #12
fr1dayn1ght
I guess i just didnt know where to look at to see the difference, i ran over a couple bumps but couldnt tell
btw how do you adjust your shock on the pregen? I cant find any way to fit my hand and the wrench without taking off the chain guard everytime...
Old September 5th, 2013, 08:10 AM   #13
The spanner wrench fits under the undertail, but just barely. I pointed the spanner wrench directly at the rear wheel and turned from that position. No jamming on the chain guarg. I currently have trimmed that plastic flap off to get some more clearance for my hugger (see my photos) but I was able to adjust the preload without removing anything before I installed my hugger.
Be sure to use the centerstand (if you have one) or put the bike on the sidestand to get some weight off the rear wheel. This will make the adjustment much easier.
Old September 5th, 2013, 10:24 AM   #14
Lychee
sail away
Lychee's Avatar
Oh that's genius! why didn't I think of that yesterday. I did manage to find enough room to adjust after taking off the left knee fairing though.
Old September 9th, 2013, 07:55 AM   #15
juanpak87
So i installed a new gen shock on my bike this weekend successfully. It was super easy, hardest part was taking off the bolt/nut because it was locked in tight. But, used wd40 and a pipe as leverage n it came right off. Put the new gen shock in its place n retightened everything n now i ride smooth. Thanks for the help guys.
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
New-gen shock on pre-gen baxtc1 1986 - 2007 Ninja 250R Tech Talk 28 October 30th, 2014 05:10 AM
Rear shock option for pre-gen. Jammerkiller 1986 - 2007 Ninja 250R Tech Talk 11 April 24th, 2014 08:51 PM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
WTB - pre-gen shock Tony B Items Wanted 4 October 10th, 2012 01:58 PM
