Old September 29th, 2013, 07:23 PM   #1
caineroad
caineroad's Avatar
Motorcycle(s): 2010 Ninja SE
Powering heated stuffs with stock battery?
Hi,
I'm looking to buy some venture heated clothing for the winter, and it looks like the Ninja has a mere 80-100W of usable excess wattage, do I need to upgrade the stock battery to a better one to support the higher load? The heated jacket alone is 83W from venture, not including pants, gloves, etc.
Thanks
caineroad is offline   Reply With Quote
Old September 29th, 2013, 07:39 PM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I'm subbing to this since I'll have the same question before too long. I'm probably pushing the limits of the available power with what I have plugged in and there's still a few toys/gear/farkles I want.
<-- Linky
Old September 29th, 2013, 07:46 PM   #3
Upgrading the battery won't really do much. If you're using more wattage than the bike's charging system can put out, the drain will eventually result in a dead battery, no matter how powerful it starts out.
That said, you can run it at a deficit for short periods, as long as you understand that it needs to be turned down soon after to build the charge back up safely. Even if the jacket takes 83 watts at full bore, make sure that there is a thermostat on it so you can control how many watts it actually uses. My gerbing is 77 watts I believe, but I only have it on full blast for a few minutes before dialing it down quite a bit, even in the coldest weather.
More info here: DIY - What Electrical Items Can be Used and Not Overload the Battery?
Mobile Warming Battery Operated Heated Gear BlackNinja8 Motorcycle Gear 8 January 15th, 2013 01:22 PM
Rechargeable Battery Powered Heated Insoles g21-30 2008 - 2012 Ninja 250R Farkles 4 January 13th, 2010 04:43 AM
[webbikeworld.com] - Blazewear Battery Heated Vest Review Ninjette Newsbot Motorcycling News 0 December 28th, 2009 10:10 PM
[webbikeworld.com] - Blazewear Battery Heated Vest Review Ninjette Newsbot Motorcycling News 0 December 18th, 2009 02:40 PM
[webbikeworld.com] - Warmthru G3 Battery Heated Gloves and Battery Heated Glove Liner Ninjette Newsbot Motorcycling News 0 February 1st, 2009 08:43 AM
