March 16th, 2014, 02:55 PM | #1 |
Join Date: Dec 2013 Motorcycle(s): 2003 Ninja 250R Posts: 25
200lb rider on an 11 yro pre-gen; suspension upgrades?
This is my first motorcycle and I am having an all-out blast right now. The bike has 18k miles on it. I just put a new chain and sprockets on, put everything back together and took her for a test ride last night; smooth smooth smooth power transition now as I roll on or off the throttle! I love it!
I am a couple months into riding the bike and I am curious if I should upgrade/fix the suspension. I don't really know what to expect, but the suspension feels 'soft'. Lots of brake dive and very spongy. No leaking oil on the forks or obvious damage, so I think things are in good working order. I get around just fine, but I would really like something stiffer. In general I like stiff suspension in my vehicles, and this bike is for fun only, so I don't need to be super comfy or anything. I have read the ninja250 FAQ on suspension upgrades, and it looks like there are a lot of options out there, I just don't know what to choose. Can anyone chime in on heavy guy suspension modes/upgrades that you would suggest? FWIW I am planning on taking her to my first track day next month. Thanks in advance! |
March 16th, 2014, 03:36 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Hi Jacob. I, too, am of similar build as you and interested in possible upgrades to the front and rear suspension.
For my BMW, I had good luck with Klaus at epmperf.com in New Jersey. He fixed me up with YSS Hyperpro stuff, set up for my weight and riding style. If you don't contact Klaus about your pregen Ninjette, perhaps I will. If you get to it before I do, please let us know what you find out. |
March 16th, 2014, 03:54 PM | #3 |
Blind 250 Loving Whore
Do you have a budget in mind or just want better suspension. You could do new fork springs and emulators plus a gsxr rear shock for about $350
March 16th, 2014, 07:16 PM | #4 |
Join Date: Jan 2014 Motorcycle(s): 2007 ninja 250 Posts: 80
A super easy and cheap budget option would be a 2008 or newer rear shock swap and some heavier fork oil. The new gen shock is actually a decent upgrade considering how cheap and easy it is. Upgrading the forks, unfortunately, is a bit more involved.
March 17th, 2014, 07:36 AM | #5 |
Here are the realistic upgrades at a high level.
Gsxr 600 shock in the rear (08-10) Get dogbones that will set the geometry that you want Get the proper spring for your fully geared weight Respring front for you weight (racetech or the like) Get some emulators Choose a fork oil weight Choose a size of preload spacer for the front Fork caps that allow for preload adjustment (optional) Set sag, preload (on entire bike), HS/LS compression and damping (rear) (damping on front via fork oil) Grand total should be around 7 bills for new stuff. It's a lot I know.
March 17th, 2014, 08:07 AM | #6 | |
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
Welcome to the the org Jacob! :: Good to see a fellow TN'er here, even if you're still a ways from me (I'm outside of Nashville).
I'm a little lighter than you (165ish) but wanted preload adjustment and the ability to carry an adult passenger once in a while so I upgraded to the 08+ shock. Paid $20 to a lady turning her 08 into a track bike off craigslist. I haven't ridden it since I installed it (discovered a bad head gasket ), but just sitting with my weight on the bike it's a good inch higher. If I were in your shoes I might do the new gen shock and some heavier fork oil and see what you think. Cost and time should be pretty minimal that way. My 2 cents... Quote:
Oh god the bikes are multiplying!!! |
March 17th, 2014, 11:24 AM | #7 |
Thanks for the thoughts guys! I love the range of responses; cheap to dream. Much appreciated. Budget: Unfortunately not $700, although I wish I could spend that much on my bike right now. Probably more like <$200 for this first round. Which I think takes me out of going with a specialty shop. I have been watching ebay for an old Fox Racing adjustable rear shock, but even with them 20 years old and beat up they still are selling for $300+.
Ideally, with my low-capital buy-in, I would like to start with something that I can try out and build on. I would like a little extra height, so the new-gen rear shock sounds like its right up my ally. I was originally thinking of going for some heavier spring rates for the front forks. It is time to do my fork seals (per service manual) so I was thinking I would pull the forks, swap for some stronger springs (use the calculator to fit my weight) and then upgrade fork oil weight to something heavier? Couple that with a swap to the 08+ 250 rear shock and I may be fine for the season. One question is what extra benefit do I get from emulators (if I do springs/fork oil)? The amount of adjustment and fine tuning on the front suspension boggle my mind. |
March 17th, 2014, 06:33 PM | #8 |
Join Date: Dec 2013 Motorcycle(s): '04 Ninja 250R Posts: 367
i have a 2004 250 ninja. i found a 2013 ninja 300 shock and have to the preload on 4. to me its perfect. a lot stiffer then the stock on. and the sag isnt as bad on throttle. feels easier to throw around turns as well. im 5'11" 170. o newgen 250 will be good as well. to my understanding the 300 shock is stiffer then the newgen 250
March 17th, 2014, 07:10 PM | #9 | |
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; March 17th, 2014 at 09:29 PM. |
March 17th, 2014, 07:37 PM | #10 |
EX500 full of EX250 parts
The RaceTech calculator (which may not be perfectly accurate) suggests 65% stiffer fork springs for your weight. With that much difference, I think it's probably good to get the new springs. They should be under $100.
That's similar to the difference in spring rates for me on my EX500. Upgrading the springs should help a lot. If the springs are providing the proper support for your weight, the fork/shock's damping won't be working as hard trying to constrain crazy bouncing. Going to stiffer springs can actually result in a plusher ride if the current springs are so weak the wheels are just flailing around uncontrolled. RT's calc doesn't show info for the PreGen rear. If the NewGen's 520# spring is a good rate for you, that could be a great drop-in budget upgrade (I've got one on my EX500 at the moment). Even if it's still a fairly low quality, budget OEM shock, it at least has preload adjustment and is hopefully closer to the right spring rate for you. You should be able to find them for $50 or less (possibly much less) on eBay. Emulators or Intiminators will improve the damping control of the forks. The stock damper rod setup uses holes of a set size and fork oil of a set weight to provide a set damping rate. This rate will be perfect for a certain size bump, an inherently too soft for smaller bumps and too hard for bigger bumps. Both Emulators and Intiminators add some fancier control of the damping. In my non-expert mind, the Intiminator seems like a smarter way of handling it, but I don't have any firsthand experience with Emulators (sold mine for the Intiminators before I got around to installing them). http://www.ex-500.com/wiki/index.php...ension_Preload has a ton of info explaining why and how to set the sag/preload. You might need or want to tweak it a bit after doing the math, but it should get you pretty close, rather than just messing around with it until you think you find something good.
March 17th, 2014, 08:48 PM | #11 |
That sounds fantastic, actually. Just started looking for shocks tonight on ebay. Gonna snag me one. Thanks for linking the video and the DIY on spacers... that makes a lot of sense.
InvisiBill, thanks for the thoughts on springs and front fork helpers. Still something I am thinking about... really only want to take the forks apart once this year. Josh_kcco, nice to hear from someone running the 300 shock. I still can't believe I am running a shock without a preload... gotta change that! |
March 17th, 2014, 08:49 PM | #12 | |
March 17th, 2014, 09:24 PM | #13 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Hi buddy, re spring your front from sonic springs and put in some heavier oil... That's the easier mod. Next, like some other people have recommended put in a gsxr rear shock, but that's a bit of DIY required. Also get custom dog bones to increase the height as gsxr shock might reduce your ride height. Good luck!
March 17th, 2014, 11:02 PM | #14 | |
Rode with the Dinosaurs..
Join Date: Nov 2013 Motorcycle(s): '08 Ninja 250 Posts: 486
Fortune favors the brave! |
March 17th, 2014, 11:07 PM | #15 |
I weigh about 82.5% of you... lol Also, I went with a .70 spring and 13.5(approx) weight oil along with a set of gold valve emulators. Also, I used an 8.0 spring on the rear, GSXR-600 shock.
March 18th, 2014, 05:29 AM | #16 | ||
You might be able to add a drain screw to easily change the oil. http://www.ex-500.com/wiki/index.php...rk_Drain_Screw The Gen1 had drain screws, but the Gen2 didn't, so a lot of people add one. If you're going to be experimenting with different oil weights, it should make life easier. Regarding DIY spacers: Quote:
March 18th, 2014, 09:24 AM | #17 | |
What would you recommend for cutting the spacers? It did seem like I had to compress more on the top cap to push it into the fork before putting the retaining clip in. Thanks |
March 18th, 2014, 01:03 PM | #18 | |
I believe that sag does matter if you want to optimally tune your suspension. To change the sag, you change the amount of preload, which is changed by altering the length of the spacer. It should be a fine-tuning step after you get springs of the proper rate. It's not a substitute for the correct springs, and you probably shouldn't bother with it if your spring rates are way off. If it's the case that spacer lengths should never ever be changed, then preload adjuster fork caps (which just push the spacer down more, effectively increasing spacer length) should never ever be used. The preload adjuster on the rear shock serves the same purpose, so that should also never ever be moved. Silly, right? Depending on how close the OEM setup is, getting springs of the proper rate and using stock-ish length spacers will probably put you in the right neighborhood (meaning you don't need to worry about sag measurements), as opposed to just cranking up the preload on springs that are way too soft. If you want to tweak your suspension after you get the right spring rates, start taking measurements and adjusting the spacer length to give you the preload/sag settings you're after. |
March 18th, 2014, 01:20 PM | #19 |
^^^^ this
InvisiBill speaks logic... Although, real life factors come into play. Preload adjustment caps can be of value as one's riding venue changes and warrants the change. Dem pesky bumpty tracks... Also, as one's skill increases at cornering, a simple one or two rotation turn on preload trackside, is much better than a fork rebuild during lunch. The black art, voodoo of suspension is NOT a "by the books" measure. The RIDER dictates the final settings, not a ruler. I have buddies who have their preload maxed out, that doesn't make it right or wrong. It just means they are happy with the current settings and make it work for them. For example; At Putnam park, I ran my fastest laps on the stock suspension, all changes I have made thus far, has slowed me down, despite racetech recommended front springs and a gsxr rear.
March 19th, 2014, 05:01 PM | #20 | |
Join Date: Nov 2013 Motorcycle(s): 2003 Kawasaki Ninja EX250r Posts: 32
bottom line is you should be able to upgrade to all ex500 parts for your suspension for under $200 if youre thrifty, but you always run the gambit on used parts. |
March 19th, 2014, 09:15 PM | #21 |
Quick update. I swapped the rear on mine with the EX500 shock I got from eBay and it fit perfectly. Bit soft but adjusting the preload will fix that. If you do go this route try to adjust your preload before installing and if you are 200 lbs or so then you will likely need a lot of preload. Mine came with the adjuster about half way (stock setting I believe) is say you may wanna adjust it to between 80% and 100% preload. Though again mines at about 50% and its not too shabby
March 20th, 2014, 02:57 PM | #22 |
The EX500 shock uses a 300# spring. That's only about 2/3 the stiffness of the PreGen's stock spring. Unless you're trying to soften the rear end, I'd suggest swapping the PreGen spring on if you're switching to the EX500 shock. In my eyes, the only improvement the EX500 shock has is the preload adjuster. Personally, I put a NewGen shock on my EX500 because its spring is the right rate for my weight (73% stiffer than the EX500 stocker).
The EX500 fork springs are .585kg/mm. That's an upgrade from the PreGen's .440kg/mm springs, but still not all that stiff. According to RaceTech's calculator (which may not be 100% accurate), that's good for a ~110lb rider. You can buy new springs in the correct rate from Sonic for $80, so it seems silly to settle for EX500 springs (unless they happen to match what you need) for the same price. If you already have some sitting around or can get them dirt cheap, it's something to consider, but it's probably a mediocre upgrade for many people and not saving all that much money compared to just buying the right part. Compare the cost and benefit in your own situation and figure out if it's a good value or not. |
March 20th, 2014, 08:40 PM | #23 |
Alright, so I started looking at the GSXR shock considering how many people are chiming in on it. Surprisingly, its cheaper than the new-gen 250 or 300 shock (used on eBay) but I still haven't been able to find solid info on installing it on a pre-gen. Jumped around the net for the last hour trying to find a DIY (even just trying to find one for custom dogbones). The best I found was csmith12's swap on his new-gen... which if I understand correctly is a bit different than how it would fit on a pre-gen?
I am not afraid of a challenge (especially if it means a better riding experience) but I have limited access to grinding tools and a drill press. AND I need my bike seat to go up, not down. |
March 20th, 2014, 08:55 PM | #24 |
I don't remember doing a DIY Jacob . I followed this threads lead. Should be basically the same for you on a pregen. The main difference will be insuring the reservoir doesn't hit anything.
I used a dremel and a cordless drill. I just put the part to be drilled in a vice. Here is a link to a bone solution that is cheap!
March 20th, 2014, 09:01 PM | #25 | |
I appreciate the links! Realized that if I end up doing the GSXR600 shock I should do a DIY writeup... since it seems like info is lacking. Of course they stopped selling pre-gens nearly 7 years ago, so maybe there is a reason info is scarce. |
March 20th, 2014, 09:06 PM | #26 |
Yes, please do, that would be awesome!
March 20th, 2014, 09:12 PM | #27 | |
PS - Just bought my GSXR600 shock on eBay: $34 shipped. It will be a slower road than the J-series or 300 shock, but (hopefully) it will be more rewarding. I am a sucker for DIY jobs. Last futzed with by aelath; March 20th, 2014 at 09:13 PM. Reason: I canz spelling |
March 21st, 2014, 03:45 AM | #28 |
I think I have my pregen bones in the garage already off. I will see if I can get a measure on them.
March 21st, 2014, 04:13 AM | #29 |
My DIY is right in the DIY list on this forum. The only thing that might be different is the mounting hole size but you can just check that easy. I've heard you might not even need dogbones for the pre-gen.
March 21st, 2014, 05:30 AM | #30 |
Looking at the parts fiche, the PreGen appears to use a more complex dogbone than the NewGen. The Gen1 and Gen2 EX500s use different bones too, and the PreGen's look similar to the Gen1's (though it's not the exact same part number).
Gen1 Gen2 If it's just for spacing, it looks like the early style should provide a bit more room, as they bow outward a little to two separate mounting points on the swingarm. |
March 21st, 2014, 06:56 AM | #31 | |
Any info and dogbones is very helpful, thanks! Also, if anyone knows if there is an issue with the piggyback fitment that would be great. The ninja250 FAQ wiki mentions that I will have to ditch my airbox and/or relocate my battery. 0_o |
March 22nd, 2014, 05:24 PM | #32 |
Update: Just bought my sonic springs 0.80 kg/mm and some 15 wt fork oil. Gonna pick up some fork seals from my local dealer and do the whole job at the same time. I feel like I am headed int he right direction, can't wait to get my bike stiff!
April 13th, 2014, 10:03 AM | #33 |
Update: Trying to get the GSX-R600 shock to fit on the pre-gen. Its gonna be tight... the piggyback resivor is bumping up against the battery and air box. Kinda funny 'cause now I understand what faq.ninja250.org was talking about. I am not saying it can't be done (won't know for sure until I get the GSX-R shock mount filed down to fit on the dogbone knuckle), but it will be interesting.
Speaking of dogbones, its not necessary to swap them with shorter ones the pre-gen because the pre-gen shock and the GSX-R600 shock are the same length bolt-hole to bolt-hole. Now if I could only get it to fit... |
April 13th, 2014, 03:25 PM | #34 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
I put a GPZ500 shock in mine and it works really well definitely firms up the rear and is a straight bolt in.
(I realise this contradicts InvisiBill's post but that is my experience, definitely firmer and others report the same, Possibly the UK GPZ500 and the US EX500 are different?) |
April 16th, 2014, 06:51 PM | #35 | |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
April 19th, 2014, 07:13 PM | #36 |
Update: I finally removed enough material from the lower mount of the GSX-R600 (2008) shock to line it up. I popped it in during broad daylight this afternoon... it didn't fit!!! The pre-gen has a bracket welded to the top suspension frame mount that extends straight back and bolts into the rain/mud wheel cover. And the piggy back bumps right into that bracket, leaving the top mount 1/2 inch too low for the bolt to fit. Soooooooooooo.... suck.
Currently thinking about what to do. I still have the sonic springs et al for a front end job, but the rear now has my attention. I was originally going to go with the new-gen (08+) 250 rear shock or the 300 rear shock if the GSX-R shock didn't fit, but now that I have tasted the forbidden fruit of adjustable dampening.... I can't help but want it. At the moment I am referencing another thread (https://www.ninjette.org/forums/showthread.php?t=97764) and thinking about going for a rear shock from a 95 ZX6R, the one with the remote nitrogen canister. I would like the GSX-R shock, but I don't really want to cut on my frame just yet, even though it is an arguably small and irrelevant modification. PLUS, it does look I may run into more issues fitting the battery/airbox even if I do cut the bracket off. Sigh... gotta get my bike back together so I can ride. Last futzed with by aelath; April 19th, 2014 at 07:15 PM. Reason: spellzing |
April 21st, 2014, 09:21 AM | #37 | |
I can't help you get that shock mounted, but if you can see yourself living without the damping adjustment (which BTW I count as an advanced tuning item, not something I'd even want to mess around with), a guy just listed takeoffs from an 08+ track bike here: https://www.ninjette.org/forums/showthread.php?t=176032 You might get in touch with him. Good luck man!
April 21st, 2014, 11:39 AM | #38 | |
April 21st, 2014, 11:44 AM | #39 | ||
http://www.nestreetriders.com/forum/...hock-Swap-Myth Quote:
Last futzed with by InvisiBill; April 22nd, 2014 at 04:29 AM. |
January 21st, 2015, 11:15 AM | #40 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 470
I know that I am chiming a little late, but I am a 200# rider ( without gear ) on a 2000 250R.
As I was new to this bike, I went the easy, and validated method of just bolting in an 08+ 250 rear shock. Install was a peice of cake, and no modifications at all were required. I found no change in ride height. For the front, I used the spring calculator and went with Race Tech springs .80 and 15 wt fork oil. The rear shock was set at two "clicks", and was a dramatic improvement over my stock shock. I was concerned that I might have gone too heay on the front springs, but not so. I should have ordered a bit heavier spring. Overall, for about $175 it was worth it. Everything was "plug and play" and made a positive difference in handling. After riding with this set up, I might adjust the rear another "click" to 3 - for the preload, and increase the spacer in the front to increase preload. I hope this helps others in their decision making.
... can't stop updating the bike! |
Suspension Upgrades or Tires? | Manimal | 2013 - 2017 Ninja 300 General Discussion | 104 | August 3rd, 2015 09:06 AM |
Budget suspension upgrades? | Worldtraveller | Ninjettes At Speed | 40 | October 11th, 2014 02:59 AM |
WTB Suspension after market rear shock/exhaust Pre-Gen Ninja 250ex | WesleySnipes | Items Wanted | 17 | March 5th, 2013 08:27 AM |
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames | kjohng | General Motorcycling Discussion | 5 | February 27th, 2013 10:03 AM |
Suspension upgrades: which first? | cuong-nutz | Ninjettes At Speed | 11 | November 29th, 2011 06:44 AM |
