April 15th, 2014, 12:38 PM | #1 |
Join Date: Feb 2014 Motorcycle(s): 2010 Ninja 250r Posts: 36
Exhaust for the ninja?
I saw an r6 with a toce double down exhaust on it, I couldn't help but want it on my 250. Does anyone know of a company that makes a double down exhaust like that for the 250?
Here is a link to the exhaust: http://www.toceperformance.com/Toce_.../tpy606-dd.htm |
April 16th, 2014, 06:00 AM | #2 |
None that I have seen. I have seen a custom made gp single out exhaust that looks similar. It would surely have to be seriously loud though. You might be able to use the one for the r6 by getting an adapter made to fit the midpipe/header.
April 16th, 2014, 06:07 AM | #3 |
Private Joker
MOTM - Mar '14
As much as I would love that style exhaust I'm fairly sure that it would require an adapter and likely some welding skills which I currently lack. That and I'd get a full exhaust before a slip-on exhaust. I have not seen anything close to this available for the 250 without a good amount of work with an adapter unfortunately.
April 16th, 2014, 06:26 AM | #4 |
Seems like that might be a custom job. You could probably make it fit.
I have seen a custom job done with an Arashi exhaust on a Ninja 250 that looks pretty cool. There also a you tube video. |
April 16th, 2014, 09:02 AM | #5 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
"even a proper fitting helmet can 'get loose'" -csmith |
April 17th, 2014, 03:57 PM | #6 |
Engine Room-> Dyno
Ive tested many of them on my dyno with multiple builds...we use M4
April 22nd, 2014, 06:53 PM | #7 |
Join Date: Oct 2013 Motorcycle(s): 2012 Ninja 250 Posts: 35
This isn't totally related to the original exhaust post but, I didn't know where else to share my recent upgrade: I just bought a full Yoshi exhaust and new Michelin Pilot 2 tires. Last weekend I turned over 200 miles on them - and I'm feeling like a pro!(well, ok, as long as I ride by myself) The Yoshi sounds great, I'm getting significantly more power in the mid-range and the new Pilots are fantastic on the corners. I couldn't believe the difference. Don't go slip-on...go all the way. You won't regret it.
Ninjas:The Answer to Life, the Universe & Everything |
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust | c-dog | Motorcycle-related | 2 | September 12th, 2014 10:48 AM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
WTB: Area P full exhaust (or exchange 08+ stock exhaust) | mikecronis | Items Wanted | 0 | June 16th, 2010 05:54 AM |
