Old August 27th, 2014, 11:38 PM   #1
storm720
Full exhaust and intake suggestions
Ex-Racer looking for some Experienced Racers/Tuners suggestions and opinions on a full exhaust system for a 2009 ninja 250 that are currently working for them.
I'm looking at a Full Systems from:
Yoshimura
Two-Bros
Akrapovic
Leovinci
Or something that is working better?
Airbox mods or elimination?
K&N air filter or something else?
Jet kits or jetting recommendations?
Looking for more power while still keeping reliability. Will be used 75% street & 25% track days.
Thanks for the help in advance!
storm720 is offline   Reply With Quote
Old August 28th, 2014, 05:48 AM   #2
micoulisninja
modaholic junkie
well of those you mentioned I think the one you definetely don't want to use is the Two-bros...
performance-wise the LeoVince is the reference point but people in the States with carburated models prefer AreaP's systems, not only because they are reviewed to perform well but also because their aftersales customer service is flawless... they provide you with rejetting instructions and suggestions etc...
track guys remove box and use pods if it is not against certain class regulations, KN mostly either pods or filter...
our track guys will give you more specified info (there are threads on rejetting and tuning based on choice of exhaust system and operating altitudes) since I am on the other side of the Atlantic...
Old August 28th, 2014, 07:04 AM   #3
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
do some searches, do lots of reading and in the end do what ever it is that you want.
the difference is performance between most of the setups will be barely noticeable but other aspects of the setups will be such as, price, sound, looks, other quirks
removing kleen air and common and generally recommended, (check your laws) the air box on the other hand, debatable, pro's and con's to each, read up, formulate your own opinions and make your own decision.
Jetting, will need to be done, that is all, bikes are different, people live/ride in different areas with different setups, they all will require different jetting. However, check out the jetting database in the "DIY" sticky at the top of the new gen tech section for some guidance on where to start.
Old August 28th, 2014, 12:55 PM   #4
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Area P is a favorite here
broilmebk is offline   Reply With Quote
Old August 28th, 2014, 05:27 PM   #5
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Area P
'Merica
Old August 29th, 2014, 12:03 AM   #6
storm720
Input thanks
Thanks gentleman, I appreciate your input. I'll start doing research on the forum here. Raced most of the CBR's and the early R6's for about 13 yrs. so these 250's are real new to me. Trying to get a base setup for the wife's mostly street, but some track endeavors. Thanks again!
Old August 29th, 2014, 12:13 AM   #7
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@storm720, if you'd use it 25% street and 75% race, also looking for highest power output the best choice would be this https://www.ninjette.org/forums/showthread.php?t=66733
Old August 29th, 2014, 05:48 AM   #8
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
Yoshimura
Two-Bros
Akrapovic
Leovinci
^ the exhaust above I can not imagine is a good choice based on the described sound alone but some people like'em loud.
Like I said before, performance wise, I can't see you noticing a difference. If you are racing where fractions of seconds matter... sure but I still can't imagine your extra 1hp is gonna give you much of an edge in the 250 class where I imagine your riding is more the determining factor.
Go with what you want but put lots of consideration into the way it sounds and looks because that is what you will notice the most JMO
Old August 30th, 2014, 12:46 PM   #9
C-Bass
C-Bass's Avatar
Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE
I have the Yoshimura TRC full system with CF canister (restrictive sound reduction insert installed - a lot easier on the ears) -
C-Bass is offline   Reply With Quote
Exhaust/Intake Upgrade Ideas a.kozak 1986 - 2007 Ninja 250R Tech Talk 9 March 1st, 2013 10:57 PM
Top Exhaust + Intake + Jet option 675Raisinator Ninjettes At Speed 6 December 17th, 2011 05:07 PM
[motorcyclistonline] - Cobra Engineering Introduces Exhaust and Air Intake Systems Fo Ninjette Newsbot Motorcycling News 0 June 11th, 2010 08:51 PM
Exhaust Suggestions tlhamon 2008 - 2012 Ninja 250R Tech Talk 6 May 10th, 2009 10:09 PM
Which came first...the intake or the exhaust? M-Oorb 2008 - 2012 Ninja 250R Tech Talk 1 December 5th, 2008 01:41 PM
