October 24th, 2014, 02:46 PM | #1 |
Inline 4!!!
USB install on 300?
Hey everyone!
I want to install a GPS on my ninja 300 so I could go have fun far from home without getting too lost. I was wondering if there was an easy plug and play option to install a USB so I could charge my GPS with it? Any information would be appreciated Disclaimer: I did search and didn't find much on the topic. I admit i'm not the best at searching though :P
October 24th, 2014, 03:01 PM | #2 |
Certified looney toon
MOTM Jul '13, Jul '14
I haven't seen a simple plug and play means, but have installed a few on my bike by wiring to a fuse block to control when it is powered.
There's a couple ways I know you can do it.. If you want the USB socket hot all the time (regardless if the bike is on or not) you can: Connect the wires directly to the battery using a ring connector. Connect a SAE/12v (Cigarette lighter style)/Powerlet type connector to the battery and then plug your USB port into that (bonus, the SAE can also be used for a battery tender) If you want the USB to only be hot when you turn the key: You can either splice the positive to a swtiched hot wire (tail light, license plate light, etc) and ground the negative. Install a fuse box (like FuzeBlock) that has a relay hooked to the switched wire to connect the USB to. All the above connectors can work this way too, just going to a switched wire vs the battery. I got some rugged weather resistant USB plugs here: http://burnsmoto.com/usb-power-socket-weatherproof.php
October 24th, 2014, 04:53 PM | #3 |
Inline 4!!!
Thanks Teri,
Yeah, once i hear "splice" I instantly get turned off lmao. I think i'll just hold off on it then
October 24th, 2014, 05:01 PM | #4 |
There's enough little connector thingys to make splicing fairly easy and painless.
Another option, depending on how far out you want to go, is buy one of the little portable power packs for phones and such and run your GPS off that thing. Toss it in the tank bag and mount your GPS within cable reach. Mine is huge, but can power a gizmo for 15 hours. Something like this: http://lifehacker.com/five-best-exte...acks-509802431
October 24th, 2014, 05:17 PM | #5 |
Ok this is an easy fix, but first do you have a battery tender? If so buy this
Battery Tender 081-0158 Black Quick Disconnect Plug with USB Charger by Battery Tender http://www.amazon.com/dp/B00DJ5KEF4/..._9RUsub00RJXAG If you don't have a battery tender, get one, or at the very least pick up the adapter. Battery Tender 081-0069-6 Ring Terminal Harness with Black Fused 2-Pin Quick Disconnect Plug by Battery Tender http://www.amazon.com/dp/B000NCOKZQ/..._NUUsub1BHTEFB I use this set up with no issues, if you have a tank bag it makes it easier as well .
October 24th, 2014, 05:32 PM | #6 | |
MOTM - July '15
Unless you were talking about not wanting to snip up the wires on your bike, which is understandable I guess. |
October 24th, 2014, 05:38 PM | #7 | |
Freedom for Germany
October 24th, 2014, 05:40 PM | #8 |
Another option:
Motorcycle Waterproof USB Power Port Socket Charger for Iphone\Ipad\GPS Perfect http://pages.ebay.com/link/?nav=item...118207&alt=web
October 24th, 2014, 07:13 PM | #9 | |
Inline 4!!!
October 24th, 2014, 07:14 PM | #10 | |
Inline 4!!!
October 24th, 2014, 07:23 PM | #11 |
Yes, and no, it would be on, but the amount of wattage drawn is minimal. I'm pretty sure it uses a resistor style to step down the voltage, and not a transformer style.
October 24th, 2014, 08:36 PM | #12 |
MOTM - July '15
Personally, if I don't intend to sell something in the foreseeable future, I don't really feel like it's mine unless I've done my fair share of jury-rigging on it :P
October 27th, 2014, 10:53 AM | #13 |
EX500 full of EX250 parts
I have the Burns Moto style one on the EX500, currently wired up to an always-on fuse (I'll be swapping some wiring around in the future to make that fuse switched). It's been a bit since I've ridden due to poor weather, but I haven't had any issues with battery drain yet.
Ideally, it wouldn't draw any power if there wasn't a device plugged into it, but the circuitry inside may draw a tiny amount even without a device hooked up. If you're storing it for a long time, it's probably best to unhook it, but as long as you're riding semi-regularly, it shouldn't be an issue.
October 27th, 2014, 11:59 AM | #14 |
I just installed a cig lighter adapter and then plug in my dual USB into the charger.
October 27th, 2014, 12:06 PM | #15 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
I just ordered a waterproof USB port to put on this winter. For now i'm doing the battery tender cable thingy.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
Ninja 300 Pod Install | mattmid | 2013 - 2017 Ninja 300 Tech Talk | 28 | February 3rd, 2015 11:16 AM |
Ninja 300 Ebay Smoked Double Bubble Windscreen Review, Unboxing, Removal, Install | SON1C | 2013 - 2017 Ninja 300 Farkles | 5 | September 18th, 2014 07:02 PM |
Ninja 300 Ebay Rear Seat Cowl Review and How To Install - Stardust Pearl White | SON1C | 2013 - 2017 Ninja 300 Farkles | 4 | September 11th, 2014 08:06 PM |
How to install Rear Spools on your Kawasaki Ninja 300 Motorcycle & eBay parts review! | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 14 | June 27th, 2014 08:15 PM |
Install Block Off Plate On The 300 | cbzdel | 2013 - 2017 Ninja 300 General Discussion | 28 | January 16th, 2013 12:48 PM |
