Old November 12th, 2014, 02:20 PM   #1
Gaaldornick
Motorcycle(s): Kawasaki Ninja 250r
New to forums and motorcycles, but need help with tach issue :(
So hi everyone!
I am new to the forums, but I did look at the wiki and browse all the similar threads I could find for the issue and I am just not sure what to do (and don't have a ton of money to fix the issue!)
My brother purchased a 2012 Kawasaki Ninja 250(r?) with something like 2,000 miles on it I think. He drove it maybe 1-2 dozen times and one of those times he said he redlined it and when he did the tachometer stopped working. Now when it's turned on it looks like it moves a TINY TINY (really tiny) bit then does nothing the rest of the time it's on. The engine sounds fine and everything runs great but the tach doesn't move. I tested the battery and voltage is appropriate (something like 12.8v)
I am really unsure what to do at this point, my thought is go to a motorcycle shop, but the ones near here charge $70+ an hour just to look, and I can't afford extended "looking" sessions to find the problem. Trying to get a head start on it if I must bring it in.
and to clarify, after breaking the tach, my brother sold me the bike for cheap, thus I now need to fix it
Gaaldornick is offline   Reply With Quote
Old November 12th, 2014, 02:27 PM   #2
Welcome Steven! Someone should be able to help with your issue. I would start by ensuring the battery terminal connections are clean and tight.
Old November 12th, 2014, 02:29 PM   #3
Gaaldornick
I checked them when I tested the voltage, and they seemed tight and were quite clean. Thanks for the greeting, and I do hope someone can help!
Old November 12th, 2014, 02:40 PM   #4
Welcome.
I would look up the wiring diagram and find the color of the wires associated with the tach, then trace them from the gauges to their destination - which I believe would be the coil - looking for loose connectors or broken wires. An Ohm meter could also help if you have both ends of the wire accessible. A break in the wire would give you infinite resistance.
If that all checks out, it would suggest a mechanical problem with the tach itself. In that case you could start disassembling it, but chances are it would be more of an internal issue that would require replacement.
Old November 12th, 2014, 04:42 PM   #5
Gaaldornick
Originally Posted by jkv45 View Post
Welcome.
Alright, I will give that a try tomorrow when it's light out
Any other things it could be? Also, from experience does anyone know what I might be looking at price wise for this sort of problem?
Super appreciate the advice so far!
Old November 12th, 2014, 04:46 PM   #6
you don't need the tach anyway.
welcome aboard. have fun and be careful. don't forget to take some training.
Old November 12th, 2014, 04:50 PM   #7
Gaaldornick
Aye, I take safety seriously, I did take a 2.5 day safety course in IL to get my M class. It seemed pretty helpful and informative
I know I don't need the tach, but I do like my things in proper working order.
Old November 12th, 2014, 05:22 PM   #8
garth285
KAWASAKI GURU
garth285's Avatar
Hey bud, if you wind up needing a tach I have one :-)
Old November 16th, 2014, 08:05 PM   #9
Cat-Man
Motorcycle(s): 2008 Ninja 250, 1974 RD350, 1996 CBR1000F
I have funky intermittent odo myself on an 08. Also have checked cleanliness and used a DVOM on terminals, looks good. Tach: usually works. Speedo: Rarely works Fuel: Sometimes. I suspect some moisture may have gotten in at some point but what I am seeing may be simply UV degrading on the exterior. I suspect the temperature is involved, it seems if it is too hot or too cold it is more likely to occur. The needles pop up "randomly" as I ride usually, although sometimes even with 30-40 minutes of hard riding I get nothing. I have heard if it does turn out to be the odometer the parts inside those are fairly standardized and rebuilding either yourself or sending it out may be cheaper than a replacement, then again, that is just from vague memory. Good luck with yours, I'll post If I ever get around to using the volt meter and wiring diagram to really check things out.
Cat-Man is offline   Reply With Quote
Old November 16th, 2014, 08:48 PM   #10
If I'm not mistaken, on your model there is a main wiring connector under the tank that the wires for the gauges use. I believe that the connector can corrode and cause issue like you are having.
Might be worth a look (or a search for more info).
Old November 16th, 2014, 11:59 PM   #11
Cat-Man
Thanks I'll check this out.
Old November 17th, 2014, 03:22 AM   #12
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome, it might be easier to replace it. You could use this as an excuse to upgrade or contact this guy...
Old November 17th, 2014, 05:43 AM   #13
garth285
KAWASAKI GURU
garth285's Avatar
It just sold on ebay, sorry about that!
Old December 14th, 2014, 09:38 AM   #14
I have had moisture/condensation affect the tach but the odometer and speedometer are mechanical and should be unaffected.
The speedometer cable is probably not threaded into the gauge correctly. It can be pretty difficult to get the cable threaded. It sometimes feels like it is threading correctly even when it often isn't, which makes it stop without being fully inserted. Also check to see if the cable is broken inside the sheath or the pickup gear. If you are missing a spacer or something on the front wheel you'd probably have a more serious problem, but check to see that the speedometer pickup gear is notched into the fork like it should be.
Old December 16th, 2014, 12:54 AM   #15
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
The tacho will go loopy (bouncing all over the place) if the negative/ground is not properly connected. You'll also keep losing spark momentarily - check the battery connections, tighten with a spanner/wrench and the check the earth connection to the frame.
My tacho just sits at 0 until I rev the bike a bit of give it a tap... it's only recently developed this issue
Linkin is offline   Reply With Quote
Old December 16th, 2014, 01:17 AM   #16
MrAtom
MOTM - July '15
I got a stickytach (sticky tack?) as well. I'm gonna give it a little silicone spray lube because I planned to go spelunking in my gauge cluster anyway. I'll let you know if I break it or if it works.
Old December 16th, 2014, 07:08 AM   #17
A dead battery will make the tach go loopy too. Both times I've had to bump-start the tach would stay pinned at one end until I reached a certain RPM and it would suddenly pin at the other end. Once charge levels returned to normal the tach settled down.
New to motorcycles, not just the forums MrAtom New Members 21 August 23rd, 2014 09:16 PM
Another tach issue Cosmos 2008 - 2012 Ninja 250R Tech Talk 2 July 19th, 2013 06:04 AM
Ic ignitor or tach issue and dealership kittyslasher 2008 - 2012 Ninja 250R Tech Talk 13 June 21st, 2013 04:34 AM
New to the forums and motorcycles :) JerseyBoy New Members 17 March 22nd, 2011 12:36 AM
[topix.net] - Suzuki recalls 73K motorcycles over electrical issue Ninjette Newsbot Motorcycling News 0 February 28th, 2011 08:10 AM
