November 30th, 2014, 03:31 AM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
Signs of Carburetor Icing
What the title says. Searching on Google gave me many results specific to aviation.
Could someone list the classic signs/symptoms of carb icing while the bike is running as well as inform whether or not these issues would cause short-term damage? |
November 30th, 2014, 05:24 AM | #2 |
MOTM - Mar '13, Jun '14
Icing used to happen in one of my dad's planes. You get lose of power and sputtering. Just pull on the carb heat and it will stop.
November 30th, 2014, 05:24 AM | #3 |
It's about 2-4c outside, the bike losses power & cuts out, rolling on doesn't help. it's happy to restart after sitting for a short time (no vacuum raises the melting point & the carbs are on top of a warm engine) but does it again.
It's not going to do much damage by itself, but knowing it's losing power means you want an exit strategy because the dozy prick in the Jeep behind you could... |
November 30th, 2014, 05:38 AM | #5 |
MOTM - Sep '18, Feb '16
It would be rare to ice up the carb on a 250 ninja. No ,no carb heat. But the icing is caused by perfect conditions. It like a high dew point. The air is saturated with cold moisture. The barometric pressure in the carb condenses the moisture and water is produced. This water freezes and blocks fuel passages.
The solution is to simple start te engine . Let it run then shut it off. Allow the engine heat to warm the carb. This will melt the ice and you can go on riding.
November 30th, 2014, 06:02 AM | #6 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
I've ridden down to -5f last winter for short periods of time with no icing or loss of power but it does take a lot longer to warm the bike, and you'll use almost full choke until it is completely warm.
November 30th, 2014, 08:27 AM | #7 |
I am pretty sure this would be the first sign of carb icing. ijs...
November 30th, 2014, 09:30 AM | #8 |
November 30th, 2014, 09:57 AM | #9 |
When it's super cold there is not much moisture in the air. It takes a specific set of conditions for icing to be a problem
November 30th, 2014, 02:11 PM | #10 | |
Lifted from another forum, a long serving mod who's a mechanic got sick of answering the same question multiple times
Last futzed with by Whiskey; November 30th, 2014 at 04:53 PM. |
November 30th, 2014, 03:44 PM | #11 |
I think I might have your answers, http://faq.ninja250.org/wiki/What_is_carburetor_ice%3F
Carburetor Cleaning | Motofool | Videos | 3 | May 20th, 2014 08:42 PM |
Carburetor - what maintenance? | LemonSlice! | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 17th, 2013 09:48 AM |
Carburetor Diaphragm | kingkang204 | Motorcycle-related | 4 | September 21st, 2011 07:20 PM |
carburetor bolts | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 2nd, 2011 01:53 PM |
Carburetor Heads Up | Jakester9500 | 1986 - 2007 Ninja 250R Tech Talk | 14 | March 31st, 2010 09:44 AM |
