Old February 8th, 2015, 10:05 PM   #1
RuthlessZ
Motorcycle(s): 05 Ninja 250R
Neutral Light/Safety switch not working help.
Hey guys sorry but this is frustrating, I've been doing work on my Ninja, and the Neutral switch has been broken since I wrecked, I was fine, I wrecked on the left side, and my left handle bars are bent slightly, how can I check the wires that go into the high beam control, do those effect the ground wire for the neutral light? I've checked all visible wires, but so many are just wrapped in the harness. I've grounded out the wire for the neutral light, and it still didn't work so I know it's not just the switch. Any advice on where to look?
RuthlessZ is offline   Reply With Quote
Old February 9th, 2015, 07:31 AM   #2
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I've looked around a bit and haven't found the answers I'd hoped for... I am of little use at electrics
Old February 9th, 2015, 09:05 PM   #3
Originally Posted by RuthlessZ View Post
............ Any advice on where to look?
Hope this helps:
http://faq.ninja250.org/wiki/Electrical_%26_Lighting
http://faq.ninja250.org/images/0/07/..._Schematic.pdf
Old February 11th, 2015, 04:34 PM   #4
RuthlessZ
Yeah, I've followed the diagrams/the neutral wire to no avail. I wouldn't really care but it sucks to have to be on your bike for it to idle it.
Yeah, I'm abysmal at electric diag as well. I may have to just ignore this.
Old February 11th, 2015, 05:51 PM   #5
Ghostt
Ghostt's Avatar
Stupid question time, did you physical check to bulb itself??
violente et ignorantia
ZX-2R BLOG
Old February 11th, 2015, 07:52 PM   #6
JohnnyBravo
Get a multimeter an follow the pdf of the factory manual...
It's how I do when I don't wanna wait on my dad to fix stuff for me
Old February 12th, 2015, 09:42 AM   #7
JohnnyBravo
He is right... Always start with the simplest things and do as motofool always says check each part and rule them out until all you are left with is your problem, or does chone say that, coulda been CC, whoever said it learned it from the army I'm sure though
Old February 12th, 2015, 10:11 AM   #8
Ghostt
Ghostt's Avatar
Just don't look at it, take out the multi-meter and start doing continuity checks, never assume a part should be fine.
ZX-2R BLOG
Old February 12th, 2015, 10:13 AM   #9
I would rather fight tigers in the dark with a switch than to sort out wiring. Uggg....
Old February 12th, 2015, 10:24 AM   #10
Ghostt
Ghostt's Avatar
Not me, but that does sound like fun though.
If you take your time, and physical & meticulous check things, it's a lot easier than people think, often times people make it more difficult than the problem is.
They start unwrapping the harness, cutting things, etc.... most of the times is unneeded and unwarranted, start with the easy stuff first, and then work your way up, looking for a wore spot in the harness is another good clue.
Most of the times I have found on motorcycles it's as simple as a bad bulb, dirty, or bad switchs, or a bad or corroded connector, investing in a basic multi-meter, a can of contact cleaner, and connector grease.
Just to give you an idea what you should look for, not necessarily these brands.
ZX-2R BLOG
Old February 12th, 2015, 12:22 PM   #11
JohnnyBravo
I usually require things before I go to the trouble of of testing all the wires and doodads if I'm sure it is a writing issue... You wouldn't believe how many boats I rewired in the army
Old February 12th, 2015, 12:46 PM   #12
Ghostt
Ghostt's Avatar
No doubt
ZX-2R BLOG
Old February 12th, 2015, 12:51 PM   #13
cuong-nutz
cuong-nutz's Avatar
Did you check to see if the wire is plugged in the neutral switch under the front sprocket cover?
It's pretty common (for me at least) for the clutch switch to go bad. You can take them apart and rebend the tabs so a good contact be made.
HalfFast Racing Team
Old February 12th, 2015, 01:04 PM   #14
JohnnyBravo
No doubt
You wouldn't believe how many motors they blew either... No fault of the manufacturer though, a few people knew how to adjust the governors to get all the power out, and then they let idiots drive the boats
We really did need more power to keep the bridges from floating off down the Tigris and Euphrates
Old February 13th, 2015, 11:31 AM   #15
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
It's a really simple circuit. The bulb gets power from the same (brown/blue?) wire that powers all the warning lights and the gauges themselves. It grounds via the green wire through the neutral switch.
Check the contacts at the bulb. You should have 12V on the one for the brown/blue wire anytime the ignition is switched on. You should have ground on the green wire's contact whenever the bike is in neutral.
Neutral safety switch rc-rick Ninjettes At Speed 2 April 7th, 2013 10:53 AM
1st Gear or Neutral when at a red light? ajcadoo General Motorcycling Discussion 27 April 21st, 2012 09:32 PM
Neutral Light islander 2008 - 2012 Ninja 250R Tech Talk 8 March 22nd, 2012 08:16 PM
Laid it down in dirt (right)-now only starts in neutral: NOT kickstand sensor/switch! CZroe 2008 - 2012 Ninja 250R Tech Talk 16 September 7th, 2011 04:00 AM
Brake light on while in neutral? andrewsfm 2008 - 2012 Ninja 250R Tech Talk 13 July 31st, 2011 07:45 PM
