February 12th, 2015, 03:17 PM | #1 |
Issues on my recently bought Ninja 250
Hi guys, I've just introduced myself in the Newbie thread and i'm posting my first question re my recently bought Ninja 250.
As a background remark, I do not have much experience on bikes, been riding a BMW F650 during my riding lessons for the past 3 months and now that I passed my unrestricted licence, I've bought myself a second hand green Ninja 250 mainly for daily commute. Since I've owned this Ninja I've been extremely unlucky to find my Ninja dropped twice in 2 months, in my first accident I was parked in a parking space when a lady reversed into my bike, I was lucky enough that the alarm went on and she didn't flee the scene, as I result of this accident I ended up with a broken left fairing, bent left handlebar and some other cosmetic damages. I didn't yet fix these but plan to do so as soon as her insurance gives me the go ahead to repair. Unfortunately yesterday after work I found what looks like mud on the right handlebar and mirrors, I'm thinking that someone might have dropped my bike and put it up again as if nothing happened. I inspected the bike closely but I could not find any other damages except for the mud and scratches on the handlebar and mirror. Damage from what I think was a second drop Oddly enough, the left handlebar is now touching with the tank (it was already almost touching as a result of the first drop). You can see the difference between left handlebar and right handlebar in the pictures below: Difference between left and right handlebar to the tank This leads me up to my big question, now keep in mind I do not have much experience on bikes so it might be it's just my sensation, but I'm feeling that on some instances the bike is going straight but I feel like tipping over from the bike, it feels like I have to struggle to keep on the seat. I get this feeling on occasions and fear instantly kicks in. I did not experience any of this on the BMW F650 and I am thinking it might be that my body position is incorrect, I am putting too much pressure on the handlebars (I am aware of this) or the road is a little bit inclined from left to right or the other way round which gives the sensation that I am tipping over but still keep going straight. What is your opinion about this? do you think a bent handlebar or any of the above options can result in such case? To be totally honest when I bought the bike (since I also didn't yet had a licence) my friend tested it out and told me it looks like a good bike but the dent handlebar could have already been there and my friend didn't notice. Sorry for the long question, but I wanted to give as much information as possible. Looking forward for your input |
February 12th, 2015, 03:40 PM | #2 | |
Simple and easy fixes, your bar inserts are bent, find a good used pair, New they are about $50.00 USD each.
Your other problem might be as easy as the forks are out of alignment, this is easily fixed with the following instructions which I will provide below, Quote:
February 12th, 2015, 03:50 PM | #3 | |
A bent bar may initiate an unbalanced feeling on strongly cambered surfaces and could be amplified by being tight on the bars, being a relatively new rider is also not in your favor. Try replacing the bar first and taking a test ride before missing with the fork alignment. Good thing is, replacing the clutch side bar is easier than the throttle side. The worst part is going to be getting the bar end off.
February 12th, 2015, 03:54 PM | #4 | |
February 12th, 2015, 03:58 PM | #5 | |
The good thing is that the left handlebar, together with the left fairing and some other cosmetic things is going to be replaced by the lady's insurance as soon as I have the go ahead to proceed. She accepted the fault so in that regard I am covered. The other good thing is that I will not be doing the repairs myself so if something is odd, such as also having the forks mis-aligned as you suggested, the agent should be able to notice and let me know. Hopefully this will fix this weird sensation as it is also effecting my confidence on the road. |
February 12th, 2015, 04:01 PM | #6 | |
Good luck, be sure to let us know how it all turns out.
February 12th, 2015, 04:05 PM | #7 | |
I guess it is bound to happen if the bike is sitting on the road. Strangely and luckily enough, that is the only damage I could see, giving that on that side the bike also has the stock silencer I thought it was going to be pretty bad. By the way, being the most densely populated country in Europe together with a high number of cars sooner or later it is very likely that someone (unfortunately) will drop it again. |
February 12th, 2015, 04:06 PM | #8 |
February 12th, 2015, 04:11 PM | #9 |
Np, after looking closer at your picture, that left bar is most definitely bent big time, the right one as well, but just a little bit compared to the left one.
To be sure take a straight edge, a ruler will do, hold it on top, line it up with the center of the bar up by the riser, then look at it, it should line up with the center of the grip, and bar end. The picture I posted shows where they bent at, close to the riser, this is just the design of the bars themselves, and almost always bent at the point.
February 12th, 2015, 04:18 PM | #10 | |
As it turns out, the second drop wasn't just a mirror and a bar-end. |
February 12th, 2015, 04:26 PM | #11 | |
If you have a friend at a machine shop your set, I've personally done this and just used old front wheel drive axles, which had bad CV joints, so they were free, just my time on a lathe. Too bad you overseas, the shipping cost of me making you set, and shipping them would not be worth it. Add to the fact I've done this on a pre-gen model, and I'm sure the bar is different on the new gens, so I would need one to make sure it's made correctly.
February 12th, 2015, 04:32 PM | #12 |
February 12th, 2015, 04:36 PM | #13 |
Damn Skippy!!!!!
We gotta hook up sometime this season for sure.
March 19th, 2015, 11:55 AM | #14 |
Hi guys, quick update re my issues... I picked up my bike a week ago and everything seems fine. The left handle is fixed and the whole experience feels better so probably that was the issue as you rightly suggested.
The only drawback is that the newly replaced left panel is brighter green than the rest of the bike, probably due to a bit of fadings on the old panels but I can live with that. Thank you all for your input |
March 19th, 2015, 11:58 AM | #15 |
Awesome, I love a happy ending glad it all worked out for you.
Just bought a ninja 250 yesterday!!! | Twitchy Stitch | New Members | 14 | May 30th, 2014 05:45 PM |
New member just bought a 2012 Ninja 250 | josefmd | New Members | 29 | October 25th, 2012 09:32 AM |
Just bought a 2007 ninja 250 | dago | 1986 - 2007 Ninja 250R Tech Talk | 12 | March 12th, 2012 06:35 PM |
Bought a Ninja 250 today 5/16/11 | exploring/carolina | Pictures | 56 | June 6th, 2011 03:00 PM |
Bought a 2nd 250 ninja cause it was CHEAPPP!!! | speedgsx98 | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 23rd, 2011 08:31 PM |
