Old March 22nd, 2015, 10:23 AM   #1
wardie
Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT
slipper clutch
Found on Asphalt Junkies a post on a slipper clutch for the 250's. If you do track days probably a worthy addition. Anyone install the slipper clutch on their 250?
I know the 300's have them.
wardie
wardie is offline   Reply With Quote
Old March 22nd, 2015, 10:25 AM   #2
wardie
Slipper clutch
Found on the Asphalt Junkies websaite a post about slipper clutch mod for th 250 Ninja. Anyone having done this or rode a 250 with a slipper clutch installed?
wardie
Old March 22nd, 2015, 10:25 AM   #3
wardie
double post
sorry bout that
wardie
Old March 22nd, 2015, 10:33 AM   #4
Almost no need as it hardly has any engine braking to screw with rear traction
Old March 22nd, 2015, 11:36 AM   #5
Trust me, I am a junkie and have chatted with these riders... Skip it. Unless your top tier racing for points and championships, you don't need it. As a championship winner myself (without a slipper) it wouldn't have made a difference either way. Simple fact when hammering the sh*t outta 2fiddy, if you lock the rear on downshifts, you downshifted too early. Been there, done that.... fun yes, right? Not even close.
Spend your $$$ on other things that will actually get you closer to lap record pace.
Ask me how I know...
Old March 22nd, 2015, 11:41 AM   #6
Brah....
Never underestimate how badly a rider can charge a corner. hahahaahahhah
For sh*ts and giggles, I will brake super late and downshift waaaayyyy early to get the rear all kinds of out of shape. It aint right, but it sure is fun.
Old March 22nd, 2015, 03:21 PM   #7
wardie
U guys just can't take the fun out of u no how LOL
thanks on slipper clutch info
I'm thinking taking her to Mid Ohio or something for a track day...
wardie
Old March 22nd, 2015, 04:26 PM   #8
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Yeah, the only real benefit I could think of is the clutch pull would be easier... if I remember correctly the ninja 250's clutch pull was still very easy though. If you really want to do a cool mod you should consider a EFI install. That's about the only thing I hated about my 250 was those damn carbs!
Be careful. Remember you are
invisible
Old March 22nd, 2015, 06:08 PM   #9
slipper wouldn't affect clutch pull. 300 has self servo clutch which makes it easier. that's separate from the slipper. 250 lacks good suspension i think
Old March 22nd, 2015, 07:58 PM   #10
Hero Danny
Inline 4!!!
Hero Danny's Avatar
huh.... I always heard it did make it easier? Learn something new every day.
invisible
Old March 22nd, 2015, 08:11 PM   #11
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
That is only his opinion, not a fact... think of it this way....
IF the slipper clutch was such an ineffective/unneeded mod on the 250, then why the hell did they add one to the 300??
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old March 22nd, 2015, 08:29 PM   #12
Mainly because a Japanese supplier has come up with a cheap to manufacture clutch, that incorporates both a very easy clutch pull and a reasonably effective slipper function. Ducati paved the way with this design on their lower-end Monsters, and now it's showing up in many Japanese bikes as well.
Old March 22nd, 2015, 10:15 PM   #13
Sorry
If you wanna slipper then by all means... Just lemme see when you hit up mid-o.
Old March 22nd, 2015, 10:48 PM   #14
Based on feedback from racing activities, the Assist & Slipper Clutch uses two types of cams (an assist cam and a slipper cam) to either drive the clutch hub and operating plate together or apart.
Under normal operation, the assist cam functions as a self-servo mechanism, pulling the clutch hub and operating plate together to compress the clutch plates. This allows the total clutch spring load to be reduced, which translates to a lighter clutch lever feel when operating the clutch.
When excessive engine braking occurs – as a result of quick downshifts (or an accidental downshift) – the slipper cam comes into play, forcing the clutch hub and operating plate apart. This relieves pressure on the clutch plates to reduce back-torque and help prevent the rear tyre from hopping and skidding. This race-style function is particularly useful when sport or track riding.
look at the picture... the movement of the outer basket relative to the inner hub moves the servo ramps which when going one way, add pressure to the clutch, but when going the other way (engine braking) actually push the clutch plates apart to make them slip.
Old March 22nd, 2015, 10:49 PM   #15
a cheaper alternative would be simply using the clutch lever
Old March 22nd, 2015, 10:52 PM   #16
check mark in a check box.
Old March 23rd, 2015, 04:29 AM   #17
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Ninja 250 clutch 4 springs
Ninja 300 clutch 3 springs
Old March 23rd, 2015, 05:49 AM   #18
pratik06
Motorcycle(s): Yamaha R15, Kawasaki Ninja 300
Because there are enough morons in this world who would rather down shift than learn to use the brakes properly. They believe that the engine is a brake
pratik06 is offline   Reply With Quote
Looking for a slipper clutch for your new gen? Somchai 2008 - 2012 Ninja 250R Farkles 2 December 1st, 2013 08:07 AM
[topix.net] - 2013 Kawasaki Ninja 300: 39bhp, 20lb/ft, ABS, slipper clutch Ninjette Newsbot Motorcycling News 0 September 4th, 2012 05:40 PM
[hell for leather] - 2013 Kawasaki Ninja 300: 39bhp, 20lb/ft, ABS, slipper clutch Ninjette Newsbot Motorcycling News 0 September 4th, 2012 11:30 AM
[motorcyclistonline] - Tire Pressure, WD-40 Myth and Slipper Clutches | Ask the Pro Ninjette Newsbot Motorcycling News 0 February 28th, 2012 04:30 PM
So how much of an impact would a slipper clutch have on engine braking? pucktoplay1 General Motorcycling Discussion 33 July 1st, 2011 01:30 PM
