Old April 15th, 2015, 03:51 PM   #1
Ghostt
Ghostt's Avatar
Digital gear indicator
Well I decided why the hell not install one. it's one of those things I don't need, but I figured it might be nice to have.
I purchased one off eBay for about $20 USD almost a year ago.
Installation time:
I decided on the mounting location, above the warning lights on the instrument panel. So drilled a small hole in the trim panel for the wires to pass thru, and secured the indicator with 3M mounting tape.
I also decided to make use of the power, ground, and neural light at the panel as well. So removed the gauge panel, and found the wires needed.
I used the gauge lighting to power the unit, positive and negative leads, and the neutral ground wire as well. I then proceeded to find the leads at the harness plug, removed the connectors and soldered the leads right to them.
I also removed gauge lighting metal diffusers. I did this due to I'm using LEDs, and just by doing this increased the brightness overall of the gauges. Also I painted the cover between the gauges and lens part # 14024 aluminum, it added a nice subtle accent color to the gauge panel, which ties it onto the main color scheme of the bike. I believe this is a nice touch, and others might find it interesting to try on their own.
So now the fun part, the sensors themselves are triggered by the small magnet you stick on the shiftrod, the space the two sensors apart about an inch.
This is where the tricky part comes in, I cut a small piece of plastic about 25mmx45mm and secured it to frame with 3M mounting tape. This allowed me a place to mount the sensors to.
After that the hardest part was finding the sweet spot for the small magnet, so it would trip both sensors properly.
RIDE REPORT:
It works, once you adjust the sensors, and magnet, which took several times.
violente et ignorantia
ZX-2R BLOG
Old April 15th, 2015, 03:53 PM   #2
Old April 15th, 2015, 07:09 PM   #3
Pictures of the installed sensors and magnet?
Old April 15th, 2015, 07:15 PM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Old April 15th, 2015, 07:28 PM   #5
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
Old April 15th, 2015, 07:46 PM   #6
Qomomoko
Motorcycle(s): 1995 Ninja 250, 2005 R6, 2002 Ducati Monster S4
Can you get false gear changes?
Not sure if I make sense ...
There is one for $25 or so on eBay but you need an ekectronic speed sensor and pregens do not have it so yours is the best thing.... I think
Qomomoko is offline   Reply With Quote
Old April 15th, 2015, 09:42 PM   #7
ieathonda
ieathonda's Avatar
Motorcycle(s): Ninja EX250F
Very cool mod ghost. Why hasnt anyone done this already? btw love that 3m dinoc wrap you got on that cluster
ieathonda is offline   Reply With Quote
Old April 16th, 2015, 09:20 AM   #8
Ghostt
Ghostt's Avatar
You can, and I did, until I adjusted the magnet, and sensors just right, once that is done, it's pretty much dead on.
If you do get a false shift, no worries, because when you shift in neutral, it resets it anyway.
@ieathonda the wrap also goes well with the other items I have done on the bike, most notably was the upper fairing.
ZX-2R BLOG
Old April 16th, 2015, 10:53 AM   #9
Qomomoko
sweet..
i'll try it then.. I am not the best at keeping track of my gears at the track...especially going all the way down to 1st by accident on a slow corner is not the best feeling.
Universal Gear Indicator ? Digital Klondike1020 2008 - 2012 Ninja 250R Farkles 9 January 10th, 2018 12:33 PM
Anyone use a gear indicator? Ducati999 General Motorcycling Discussion 34 March 15th, 2014 09:12 PM
Do you have a gear indicator? Cab305 2008 - 2012 Ninja 250R Tech Talk 2 February 21st, 2011 09:25 PM
gear indicator? mike_sema 2008 - 2012 Ninja 250R Farkles 11 December 26th, 2009 03:32 PM
datatool digital gear indicator tinng321 2008 - 2012 Ninja 250R Tech Talk 11 December 18th, 2009 08:55 PM
