Old May 4th, 2015, 07:55 AM   #1
spent_too_much
spent_too_much's Avatar
Street fighter / naked bike / Rat bike / cafe racer build - suggestions welcome!
I enjoy reading other's build threads, and all of the great advice. So, I thought thatI would document my build - and seek advice...
I'm starting with a complete 94 EX250 - with lots of issues. The engine turns, but won't start ( carb issues? ). I have a donor frame / engine / harness from a 95 - that does run - so I will just swap out the motor for now.
I have an overall direction for the build, but welcome suggestions. I don't plan to use any fairings, would like to cut the rear off and add a hoop or something for the seat. And, above all else, keep the cost down - around $300 for the parts that I MUST purchase.
At the moment, it is torn down to the frame.
I have lots of spares from my first EX250, which I still have and will keep. I just wanted to build something of my own.
Inspirational builds...
File Type: jpg doc-s-chops-yamaha-virago-is-simply-stunning-photo-gallery-55072-7.jpg (82.8 KB, 29 views)
Last futzed with by spent_too_much; May 12th, 2015 at 07:05 AM. Reason: updated title
Old May 4th, 2015, 08:22 AM   #2
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Mine is not done, yet but check out metric motos "maya"
My Cafe Racer Build
My intro post
Old May 4th, 2015, 08:27 AM   #3
chancethomas65
chancethomas
Motorcycle(s): none yet
the red one for sure dude
chancethomas65 is offline   Reply With Quote
Old May 4th, 2015, 08:35 AM   #4
spent_too_much
How I obtained it. Flat, dry rotted tires; bent handlebars; suspension shot ( front and rear ); missing lots of bolts / screws; lots of broken plastics - it all needs to go!
Last futzed with by spent_too_much; May 4th, 2015 at 08:55 AM. Reason: added to condition
Old May 4th, 2015, 08:41 AM   #5
spent_too_much
Current status. Stripped to the frame. Spare wheels added ( tires are good ). I plan to paint all of it different colors.
Frame and wheels - dark red / cranberry
Tank and swing arm - light grey
For now, the purple wheels match the stripes on the tank dead on!
Old May 4th, 2015, 08:57 AM   #6
spent_too_much
Wow! That is beautiful!
Old May 4th, 2015, 03:21 PM   #7
liberpolly
Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold.
I like this one:
Screw the inscrutable, eff the ineffable.
liberpolly is offline   Reply With Quote
Old May 5th, 2015, 08:30 AM   #8
spent_too_much
suspension
I rebuilt the front forks, just by replacing the seals, and fork oil ( about $35 total, and a few hours work ). They are MUCH better now. Previuosly, they would bottom out just by hopping on the bike and applying a little down force. Now, even though I did not upgrade the springs, they actually do their job
As for the rear shock, I am trying a GSXR shock, wich requres a little modification. On my other EX250, I just swapped in a 2008+ rear shock and it was a huge improvement - no mods required; it just bolts right in. I'll see if the GSXR is worth the added tweaking.
Old May 6th, 2015, 04:50 AM   #9
spent_too_much
Someone else also liked the idea of painting the frame dark red.
Old May 6th, 2015, 04:55 AM   #10
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
This may be helpful. Or at least entertaining.
http://youtu.be/oZ_rnmB2RBI
Worlds fastest 250 ninja
Old May 6th, 2015, 04:41 PM   #11
spent_too_much
Thanks. That was some great info. I'm unsure if I will put that much effort into the porportions of the build, but great to know!
Old May 6th, 2015, 05:19 PM   #12
paging @Jono. The white 250 is his. He may be able to help a tad.
Also, subbed for progress. because build thread.
Old May 6th, 2015, 05:40 PM   #13
spent_too_much
I messed around with the parts that I have on hand, thinking that I should confirm that this will be a fully functioning bike and one that can be registered ( I have the title to it, so it should be. ). I am realizing that $300 will not buy the goodies to do this up the way that I want, so I might have to postpone that idea. It is slowly morphing into a "rat" bike - at least for now.
I once heard a TV car show host say, "There is no better way to save money than not to spend it".
Here is what I have at the moment ( again, this is only temporary ). I have lots of spare parts to throw at this.
Old May 6th, 2015, 07:46 PM   #14
crazymadbastard
Get it running and sell off "spares" and upgrade with the funds. Most of the times I have saved my spares, i never use them.
My Cafe Racer Build
My intro post
Old May 6th, 2015, 08:34 PM   #15
Jono
Jono's Avatar
Nice to see my old bike is inspiring people. My inspiration came from this bike...
Not sure who's bike that is but I think it was somebody on this forum.
I sold my ninja before I got to do this to mine. I was a little scared of putting on pod filters but it's needed to get that cafe type look.
If you have any questions about my bike just ask.
Old May 7th, 2015, 08:07 AM   #16
spent_too_much
@ crazymadbastard - I will try, but have not had much luck attempting to sell off parts in the past. I really don't want to deal with shipping some of the fragile parts. Also, as soon I sell / trash something, that's when I need it! lol
@ Jono - I'm glad that I used one of your creations for part of my inspiration. I saw that other bike as well.
I have a question to you all. The fuel tank has a few rust "chunks" in it. I can hear them rolling around, but can't get them to exit the tank! I have fished around in there with a magnet, but no luck. I have removed the petcock, and fuel door. Any suggestions?
There isn't all that much surface rust in the tank, so I might just use the vinegar method for rust removal. Perhaps even throw in a chain for agitation - as long as I can fish it out when done.
Old May 12th, 2015, 07:09 AM   #17
spent_too_much
I ordered a couple of things. The more that I look at the front end, the more I know that it doesn't look right.
New headlights, and levers are on their way.
I want to go with round guages as well. There are so many to choose from in chrome, but not so many in black - which is what I want.
Last futzed with by spent_too_much; May 12th, 2015 at 07:10 AM. Reason: spelling error
Old May 14th, 2015, 07:52 AM   #18
spent_too_much
I ordered a few more parts. The turn siganals were only $7.50 shipped - for all 4
I am trying to figure out what Speedometer to order. What ratio do I need for a mechanical replacement, where I can just screw in my existing cable?
Last futzed with by spent_too_much; May 14th, 2015 at 07:52 AM. Reason: spelling
Old May 14th, 2015, 10:15 AM   #19
Kruse08
Kruse08's Avatar
Motorcycle(s): 99 Ninja 250
Buy the trail tech vapor. Look at my build thread as I installed one. Only have 4 wires to hook up, very easy install.
Everything you’ve ever wanted is on the other side of fear. –George Addair
Kruse08 is offline   Reply With Quote
Old May 15th, 2015, 07:13 AM   #20
spent_too_much
I know. Many people recommend that set up. What model # is recommended though? The EXseries is not listed on their website.
What, exactly, is that plastic mount that you used? It looks easy enough to use.
Old May 15th, 2015, 08:35 AM   #21
Kruse08
Kruse08's Avatar
This is the write up that I followed and also asked Chicago Bob a few questions along the way. I can explain it to you if you have any questions that are not answered in this write up.
https://www.ninjette.org/forums/showthread.php?t=129394
The mount I used is a mount that comes with the kit. It is one of the handlebar mounts. Some people may not like it because it is not as clean as a cafe/streetfighter but it is cheap. Any questions please ask.
Old May 18th, 2015, 09:51 AM   #22
spent_too_much
I decided to try this first, for my speedometer. I don't really need all the bells and whistles of the Vapor, and can live without a tach.
Benefits:
$14 shipped
Speedometer
odometer
backlight
battery operated ( cheap batteries )
auto on/off
clock
adjustable for tire size
I'll post results once it arrives and is installed.
Old May 30th, 2015, 07:05 PM   #23
spent_too_much
I have not had any time to work on the project. Parts have been arriving. The bicycle speedometer arrived scuffed up, and I read in the fine print that the speed would flash above 20 MPH. Also, it was much smaller than I expected. So, I did not even try it out, and returned it.
Old March 5th, 2016, 04:41 PM   #24
spent_too_much
After nearly a year, new direction
This build has languished for nearly a year. I am now ready to complete it, but in a different direction...
https://www.ninjette.org/forums/show...73#post1087473
Old February 3rd, 2022, 07:47 AM   #25
MondoMesh
Motorcycle(s): 1999 Kawasaki Ninja250 1979 Honda CX500 !997 KTM300EXC 2004 Honda 450CRF
99' EX250F Build
Here's my current build!
MondoMesh is offline   Reply With Quote
Old May 27th, 2022, 09:40 AM   #26
Deezg
Deezg's Avatar
Motorcycle(s): 1994 ninja 250
Current bike. Needs some tlc but i love it regardless
Deezg is offline   Reply With Quote
My 05 250 street fighter build ieathonda 1986 - 2007 Ninja 250R Farkles 19 April 5th, 2016 01:09 PM
My 07 250 cafe racer build elephantman78 1986 - 2007 Ninja 250R Farkles 12 December 25th, 2014 07:09 AM
My Cafe Racer Build girlracer 1986 - 2007 Ninja 250R Farkles 17 December 2nd, 2014 08:14 AM
Nick's Street Fighter Build nickjpass General Motorcycling Discussion 79 August 18th, 2014 08:54 PM
[topix.net] - Goosing the Goose: Making a Cafe Racer out of the Guzzi V7 Cafe Ninjette Newsbot Motorcycling News 0 September 10th, 2011 01:00 AM
