Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old May 11th, 2015, 08:01 AM   #1
chemist
Motorcycle(s): gsxr 600 2012
Comfort for taller riders-rearset etc?
Ok taller guys on 300s what are you doing to get comfortable on long rides? I have heard from several that rearsets help and rearsets don't help. Have also heard rearsets+clipons or none of the above...you get the idea.
I am 6"1 with very long legs(relatively speaking).
Possibilities:
1)newbie/nerves- yes this does happen from time to time but I am mostly past that now.
2) My weight does stay on my legs but to a point. What I mean is that with my lanky legs their is no real easy molded area for me to grip. They don't really fit right in the grooves and I find myself gripping either from the outside in on top of the grooves or pushing my legs directly into the tank( this position works but it is not always possible)
3) I stay as far back on the seat as possible(resting my lower back on rear cowl)
One issue may be that I am using mesh/textile pants. Pondering another excuse to get leather perf pants for grip.
Stompgrip for added leg grip to increase comfort. Adj. rearsets, clipons?
The wind doesn't bother me and I do feel pretty comfy stretched out on the tank. thank again though, my feet are so long that my arms end up resting on my legs lol.
Motorcycles are stable, I am not. RELAX-Keith code
chemist is offline   Reply With Quote
Old May 12th, 2015, 03:28 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Sorry I have the opposite issue. I do like my rearsets, I moved mine high and back.
I think maybe @csmith12 can help. He knows a lot of riders and might be able to help.
Old May 12th, 2015, 04:15 PM   #3
Originally Posted by chemist View Post
......... I am 6"1 with very long legs(relatively speaking).
You can use the following site to input your height and inseam, to locate yourself on the seat, to customize pegs, seat and handlebar and to compare to different bikes:
http://cycle-ergo.com/
Old May 12th, 2015, 04:16 PM   #4
Ghostt
Ghostt's Avatar
Sorry I'm a PreGen, but I feel your pain, being 6'3" with a 34" inseam.
I would avoid clip-ons as they lower your grips, May cause strain on your back.
I know they make footpegs that drop down to help, but be warned, if you like the twisties, as it will be easier to drag the pegs.
violente et ignorantia
ZX-2R BLOG
Old May 12th, 2015, 04:25 PM   #5
Ghostt
Ghostt's Avatar
Also work on your core strength, very important!!! You shouldn't be holding yourself up with your arms.
Also might want to consider a better seat, or modify yours.
Where in Tennessee are you located?
ZX-2R BLOG
Old May 12th, 2015, 04:33 PM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I forgot about the drop downs, my hubby ( @Hellmutt ) is 6' and me has them on his zx14.
Old May 13th, 2015, 12:06 PM   #7
Hey there Jonathan!
Let’s start with 3 questions;
1. How do you support your weight on the bike?
2. How do you want to set your bike up? Comfort while just riding around town, comminuting or cornering?
3. Have you spend enough time cornering on the bike to find a spot in the seat where you are comfortable while cornering and not sitting right up on the tank?
The first question will address fatigue and other comfort factors no matter what ergo changes you make to the bike.
The second question will answer if you should go with clip-ons. Commuting = no/maybe, cornering = yes.
The third question will help to know if and how adjustable a new set of rear sets can help you.
Let’s take care of the rider first. Comfort on the bike begins with stability while riding. This task of supporting your riding weight should be done by the larger muscles of the body, ie the legs and core. Being “newer” at riding, it may be as simple you’re not supporting your weight on the bike with your legs and core. This is where tank grips can help and yep… many brands of mesh/textile gear are kinda slippery on shiny painted surfaces, making it harder to get a good solid lock on the tank.
Teaching a man to fish.
We begin with ergos by putting your knees on the tank where you are comfortable AND allow you to grip the tank sufficiently to ride loose on the bars. Do you fit comfortably somewhere on the seat? If so, this will be close to your “sweet spot” in the saddle and all the other ergos of the bike should be based on that location.
Now reach for the bars. If you commuting, do you want to lean over or do you want them higher to allow for a more straight up posture? If you're a canyon carver, do you want them farther down to help enable a more aggressive riding position? Make note that some riders buy clip-ons to get a lower, more forward upper body riding position and other riders buy full handlebars with risers to raise the upper body riding posture. Only you know what you want.
Now put your feet on the rear sets. Can you get your knee/legs in the same place to grip and support your weight on the bike? If you answer YES, then no rear sets are needed unless your ankles are at an uncomfortable angle, if you answer NO, then you will have to move your feet around to find a comfortable spot and estimate how much your pegs need to move and in what direction. Some rear sets are very adjustable. Others… not so much.
Finally, these two ergos work together to create an overall riding position that tilt the entire body mass forward, neutral or farther back. The trick is to find the combo that works for you.
The most common bike setup I have seen are;
1. Commuting = stock height (or heigher) bars and stock height or lowered rear sets (sometimes even more forward)
2. Canyon/track = lower, forward bars and higher, farther back rear sets
Old May 14th, 2015, 08:05 AM   #8
chemist
thanks motofool! that link is pretty sweet. I have been playing around with some of the settings on it and find it useful.
I am located 30 miles south of nashville in Spring Hill. Beautiful area Yea, working on core strength. I have a fair amount from bicycle racing but taxing different muscles in different ways here.
Hey there Jonathan!
Sweet advice!!! I looked at the post yesterday and let the questions percolate while I rode a few times
1) I do think I support my weight with core and legs 70% of the time Still working of course on not being a newbie. A few things, when I shift gears, I have to move my leg forward and I notice my knee comes up over the "ridge" and when I am in this position it is much harder to hold my weight with my legs. I also notice this when braking. I tend to sit up a bit more and ultimately end up putting more weight on my arms when I brake and I do think a large part of that is my mesh/textile pants with a tank that I clean and wax often.
In other words I can actively be squeezing my legs/knees into the tank and still slide forward some when going down hill or braking due to slippery surface.
I ordered stompgrip for the tank as it seems like a win win mod other than the look(went clear). I am sure I will get better at gripping the tank and I am sure that is part of it. All that being said, when I am not upshifting,downshifting or braking my arms are weight free
2) Well I want my bike setup for cornering but probably need it set up for commuting All I do is commute, I don't have much time on the weekends to canyon carve but with that said, you know TN roads are pretty similar to KY and we have some FUN areas even commuting. My bike handles and turns great as is but I do get concerned if I mod it too commuter friendly as I still want that dialed in turn luxury that and I love the look of clipons but probably need to get over it.
3) Hmm, spent enough time cornering...not sure but I can tell you that I am never up on the tank. My ass is either against the rear cowl or an inch from the back cowl. I still haven't perfected the 90 degree turn into side street from main traffic going 50 but time and practice should fix that. Any sweepers/hairpins while commuting or on a fun adventure seem fine at normal speeds.
I do fit comfortable a bit closer to the tank? almost in the middle of the seat.
Wierd thing is I do actually like/want to be a bit more leaned over than I am now. My problem when I lean over of course while commuting is it is a pain in the ass to see traffic behind me. While sitting up, I just move my elbow out of the way and can usually get a good gauge of traffic behind me. If I am crouched over I have to sit back up to look behind me.
I will have to play around with what you suggested on finding out if I should get rearsets or not. I haven't sat still on the bike and tried to move positions yet.
thanks all
Old May 14th, 2015, 08:40 AM   #9
Cool!
Once you get your ergos in the ballpark, you can move to lever positions. If you adjust your shift lever, you may not have to move you entire legs so much. And then move to the brake and clutch lever. They should be angled down enough to keep your wrist as straight as possible when you reach your fingers out to pull them. This is especially important on the brake lever. Why do you think that is?
Old May 14th, 2015, 01:27 PM   #10
thanks motofool! that link is pretty sweet. I have been playing around with some of the settings on it and find it useful.......
You are welcome
Take a look at this:
http://www.sportrider.com/riding-ski...trol-tailoring
The heel of your gear foot should remain on the peg as you up-shift, as you rotate the foot around the perch of the lever from bottom to top (and vice-verse) and as you downshift.
That can be achieved by adjusting the linkage of the gear's lever or by relocating the clamp on the selector shaft.
When not shifting, the support of the foot changes from heel to ball.
Something similar applies to the brake foot, proving enough room to prevent the weight of the foot from inadvertently putting pressure on the lever and dragging and overheating the rear brake.
Old May 14th, 2015, 01:31 PM   #11
Ghostt
Ghostt's Avatar
I would advise to adjust the gear shifter, use the adjustment rod, not the selector clamp.
ZX-2R BLOG
Old May 14th, 2015, 01:59 PM   #12
Old May 15th, 2015, 05:51 AM   #13
chemist
Cool!
Hmm, well I am assuming it is important as if you have the wrong wrist angle you could end up grabbing throttle with the brake. Also assuming best force available with wrist parallel to lever. ?
Old May 15th, 2015, 05:57 AM   #14
chemist
You are welcome
thanks motofool! Love that article and will have to play the video on my phone at some point today Yes, I do have the proper ball and heal position when shifting. It sounds like I need to adjust my brake lever down slightly and I also probably need adjustment of my shifting
When I go from the ball of my foot the the heal(while staying on the peg) it seems just enough to move my legs up and over that hard ridge thus reducing how easy it is to grip with my legs. Hoping stompgrip and lever adjustments will hlep!
Thanks ghostt for suggestion, much needed
Old May 15th, 2015, 07:31 AM   #15
Yep! You don't want to be twisting your wrist to grab the brake. In the event of an emergency it's easy to do.
Old May 16th, 2015, 05:51 PM   #16
chemist
So pretty excited that I went with clear stompgrips and really like how they blend in with the bike! I should be able to see what kind of a difference this makes on monday which is pretty exciting!
I should adjust levers and look at rearsets tomorrow to see how i am sitting!
hoping these attachments work
Old May 18th, 2015, 06:39 PM   #17
chemist
So here is a picture post stompgrip and after I have moved the clutch lever and braker lever down slightly(maybe a bit to far) but I am waiting to see how it all feels tomorrow.
Thoughts on my commuting postion? I could probably post in gear and in a full tuck as well if needed. I think I am most comfortable in the middle of the seat. Not up against the tank of course but also not completely against the rear cowl.
Old May 18th, 2015, 08:37 PM   #18
Roark
Roark's Avatar
Motorcycle(s): 2007 Ninjette
You want your arms more parallel with the ground to ensure no weight is on your wrists. If you can work that out, the commuting will be a lot easier.
"That's what" -she
Roark is offline   Reply With Quote
fs: taller pregen center stand GlassAnkles Motorcycle-related 0 May 9th, 2013 11:40 AM
Northern VA checking in! Questions about Ninjette for taller/heavier folks. McFly1125 New Members 15 February 28th, 2013 08:29 AM
More comfort ? thurt88 The Ex-Ninjetters Lair 8 March 19th, 2012 06:12 AM
Seat comfort vs Butt comfort? JoeLansing General Motorcycling Discussion 11 July 17th, 2011 06:59 PM
Taking care of the underbrush to make the tree look taller? Alex Off-Topic 23 August 26th, 2010 01:14 PM
