Old May 22nd, 2015, 03:34 PM   #1
Ralgha
Ralgha's Avatar
Ninja 300 Turn Signals
Has anybody tried to put the front turn signals from the Ninja 300 onto the 250? Is it possible?
Old May 23rd, 2015, 03:21 PM   #2
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Front turn signals or rear? Can't recall the front but aren't those mounted in fairing, like on the front radius area? If rear, the. I wouldn't see why it couldn't be done. Appears to be same wiring, maybe different harness, but could remove and go wire to wire. Mounting may be a challenge if it doesn't line with current mount on 250.
Old May 23rd, 2015, 05:06 PM   #3
Ghostt
Ghostt's Avatar
What year 250?
violente et ignorantia
ZX-2R BLOG
Old May 23rd, 2015, 08:06 PM   #4
Ralgha
Ralgha's Avatar
2012. I don't know how they're attached to the 300, is it a bolt? Would that fit through the 250's mounting hole?
Old May 23rd, 2015, 08:20 PM   #5
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
You'll find what you're looking for here http://www.hightechspeed.com/products/ProtonLights/
Old May 23rd, 2015, 09:11 PM   #6
Ralgha
Ralgha's Avatar
If I go with a third party it'll be CustomLED. I haven't seen a proton one in person (or a CustomLED) one, but the pictures and videos I've seen are quite unimpressive. The CustomLED ones appear to be much more visible.
Old May 24th, 2015, 12:08 PM   #7
verboten1
verboten1's Avatar
MOTM - June '15
No, I've not tried. I did it. They are Ninja 650 rears, looks just like 2015 versys fronts and 300 rears. Took a little modification, but not much.
Ride more, worry less.
Old May 25th, 2015, 08:11 AM   #8
Ralgha
Ralgha's Avatar
That looks like an improvement over stock, but I'm interested in the front signals from the 300, which are flush mount.
Old May 26th, 2015, 05:06 AM   #9
BlownWideOpen
BlownWideOpen's Avatar
Motorcycle(s): Stuff
Front signals wont work without extensive modifications to the fairing.
Paint side up, rubber side down!
BlownWideOpen is offline   Reply With Quote
Old May 26th, 2015, 08:43 PM   #10
MetaOrbit
Side note - I don't suppose you tried mounting those to the rear?
I've been on the lookout for some rear turn signals that look like that (or the rear 300 signals), but despite my investigating photos of them on eBay, can't tell how they mount.
MetaOrbit is offline   Reply With Quote
Old May 26th, 2015, 08:48 PM   #11
Welcome John!
Old May 26th, 2015, 09:06 PM   #12
verboten1
verboten1's Avatar
MOTM - June '15
They mount a bit differently than the stock ones. The rubber fits through the hole, and a plate sandwiches it and locks it in. I have no idea what the stock rear end looks like, I've never had it, but I doubt it will work.
Old May 28th, 2015, 06:30 AM   #13
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
You have to cut custom holes into 250 fairings to fit 300 Front signals
or
Purchase 300 fairing and customize the mounting holes to fit on the 250 (I think this might be more impossible)
Otherwise flush mount LEDs like the protons or custom-leds would be best alternative.
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old May 28th, 2015, 06:45 AM   #14
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Check out the oxford universal turn signals, I put the neptunes on my bike and love them.
Spoiler for topic:
It might just be the [you] tag
Old May 28th, 2015, 11:48 AM   #15
Ralgha
Ralgha's Avatar
Do those attach directly to the existing mount, or do you have to do something extra?
Old May 28th, 2015, 12:02 PM   #16
DEFY
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
DEFY's Avatar
Steps you have to take is pull the stocks lights out and then install the oxford along with their resistors they include with purchase, unless you would rather just replace the relay(I used the resistors and it flashes a little bit quicker but I like the way the flash is).Oxford does also have a kit to allow you to convert to the correct connectors for the bike brand, or you can remove and add the factory ones using some butt connectors, your choice. I ordered off revzilla, also left a nice review of them with pics (neptune, same price as oxford only no shipment cost.
I can get some vid/pic of the bike and how they look on it if you want. I think the installation is easy.
edit: they install the same as factory, it's a bolt-nut combo.
Spoiler for topic:
Old May 28th, 2015, 04:09 PM   #17
Ralgha
Ralgha's Avatar
Bolt and nut is all I needed to know, thanks.
I think I'll go with custom LED for the front, maybe those Oxford ones in the back, they look pretty cool.
Old May 28th, 2015, 05:02 PM   #18
Kurgan
Kurgan's Avatar
Motorcycle(s): '09 Ninja 250R
If you want something that looks like the front signals of the white 250R in that pic above, try looking for Rumble Concept Sierra LED signals.
Kurgan is offline   Reply With Quote
