August 23rd, 2015, 08:25 AM | #1 |
Join Date: Jul 2015 Motorcycle(s): 2002 Ninja EX250 Posts: 10
2002 Ninja 250 won't start after being dropped. Please help.
About a week ago, my ninjette dropped on its right side going about 20 on gravel. Aside from aesthetic damage, I can't tell anything wrong with the bike EXCEPT it won't start.
When I press the ignition I hear a click from near the battery. If I hold it down it goes clickclickclickclick.... When I turn it on, the taillight turns on, so the battery is not completely dead. I figure it's something wrong with the battery or fuses but I'm not sure. If anyone has any ideas, please let me know. I'll post a video if it would help. Thanks guys https://www.youtube.com/watch?v=uIAABt7OUCk Last futzed with by gary; August 25th, 2015 at 05:23 PM. |
August 23rd, 2015, 08:31 AM | #2 |
Step 1 - remove seat
Step 2 - measure current voltage of battery Step 3 - ensure battery connections are clean and tight Optional Step - Sealed battery? If not ensure battery has proper level/mix of acid Step 4 - Ensure fuses and then safety switches (see wiki)
August 23rd, 2015, 10:57 AM | #3 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Never heard of "current voltage"...
You might want to try jump starting the bike with a car battery (car not running). |
August 23rd, 2015, 11:19 AM | #4 |
ie, the voltage the battery "currently" has. Meaning "at this time."
August 23rd, 2015, 12:54 PM | #5 |
Participant
Good point. No need for Gary to set up data logging stuff.
Current, voltage, open, short, loads... All that pesky terminology! |
August 23rd, 2015, 01:48 PM | #6 |
As the bike was damaged on the right side, you should verify all the wires and connectors that link the battery to the starter motor.
The click that you hear is that the relay is connecting the battery to the motor. The condition of the battery should be tested under load, something that any autoparts store can do for you. If the battery was good before the fall, it should be OK still, unless that the internal fluid has spilled out, as explained above.
August 23rd, 2015, 01:51 PM | #7 |
I bought a new battery so that's not the problem.
I tried bypassing starter soleniod and that didnt help. |
August 24th, 2015, 05:58 AM | #8 | |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
Calling it "current voltage" is unnecessary because when you measure voltage it is at that point and time. I would measure the voltage at the starter when the starter button is pushed. |
August 24th, 2015, 09:08 AM | #9 | |
Join Date: Jul 2015 Motorcycle(s): 2004 EX250R Posts: 39
22R88 |
August 24th, 2015, 09:32 AM | #10 |
Sorry ya'lls for my KY slang on this topic. lol Didn't mean to confuse anyone.
Gary, I would focus on the safety switches at this point. 2 common points of issue after a down are the clutch and sidestand safety switches. These two switches will prevent the bike from starting but the odd thing is, when they fail... they are normally 100% silent and don't present the same symptoms you describe. My gut tells me whatever you got going on is fundamentally electrical. Wish I could help more.
August 24th, 2015, 10:35 AM | #11 | |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
Anyways- to add- the safety kill switches you mention cut the power before it even gets to the solenoid so there'd be no clicking. Check the starter motor. It could have possibly be jarred in the crash and too much tension not letting it turn over. Just loosen the two bolts that hold it in- don't take the bolts out- and wiggle the starter. Retorque the bolts and try again. |
August 25th, 2015, 01:59 PM | #12 |
2002 Ninja 250 Clicking/Buzzing and Wont start after dropped on right side
I also tried bypassing starter solenoid and I could hear the starter engine crank a little bit but not enough to turn over the bike. Please help guys Last futzed with by gary; August 25th, 2015 at 03:21 PM. |
August 25th, 2015, 05:12 PM | #13 | |
August 27th, 2015, 03:35 AM | #14 |
Join Date: Aug 2015 Motorcycle(s): 2010 Ninja 250R, DRZ400SM. Posts: 15
Remove and re-tighten both battery terminals and check the fuses. Are you sure the battery just hasn't drained? Just because the lights work doesn't mean it's got enough charge to start.
Tried roll/bump starting it? If it starts turn it off and try to use the starter again. If it doesn't bump start and ride around a while then back home and try again. How long was it on it's side for? |
August 27th, 2015, 12:29 PM | #15 |
Battery charged?
August 27th, 2015, 12:30 PM | #16 |
@Alex, this needs to be merged with the top similar thread.
August 27th, 2015, 12:33 PM | #17 |
/merged
August 27th, 2015, 03:32 PM | #18 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
My bike does that on a dead battery, try jumping it off on a car, DO NOT have the car running, i repeat DO NOT.
05 Ninja 250 won't start on its own - help! | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 59 | July 8th, 2014 11:46 AM |
Dropped bike at low MPH, drained float bowls, still won't start. | BoKing | 1986 - 2007 Ninja 250R Tech Talk | 17 | July 20th, 2013 07:07 PM |
Ninja 250 won't start! please help me! | Black knight | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 23rd, 2013 03:22 PM |
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) | Pocket Sprocket | 1986 - 2007 Ninja 250R Tech Talk | 12 | May 17th, 2013 11:13 AM |
06 ninja 250 won't start | wolfpuss | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 21st, 2012 05:57 PM |
