Old November 21st, 2015, 01:55 AM   #1
iforgot
Motorcycle(s): 08' Ninja 250r
Bike won't crank, lights come one, replaced battery and solenoid starter.
I have a 08' ninja 250r. It just won't crank over. Here's some info about the situation:
Lights come on but when I press the start it won't do anything. No sound at all.
It will push start with a really good push.
It will start if I arc the solenoid.
I have replaced the battery AND solenoid and it still won't start. I bypassed the kickstand safety switch to see if that was the problem but still nothing.
I'm running out of ideas now. :/
I took off the clutch safety switch and cleaned it up but that didn't seem to be the problem either?
If you can give me some help I'd really appreciate it!
iforgot is offline   Reply With Quote
Old November 21st, 2015, 07:18 AM   #2
Clutch safety switch?
Labeled as the plunger in the pic.
Old November 21st, 2015, 07:24 AM   #3
Ghostt
Ghostt's Avatar
Starter button? Inspect and clean as well.
violente et ignorantia
ZX-2R BLOG
Old November 21st, 2015, 09:57 AM   #4
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I'm sure you've already checked all the fuses and connections (eg. grounds)?
k-os is offline   Reply With Quote
Old November 21st, 2015, 12:35 PM   #5
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
FYI, the clutch switch is irrelevant if it's in Neutral (the same switch that lights up the dash indicator light).
The starter button (and coils) gets its power through the killswitch from the Ignition fuse. Check for power at the brown/black wire in the main harness where the right control plugs in. The start button triggers the starter relay through the black/red > Diode B > blue wire, which triggers the solenoid via the yellow/red wire.
Starting issues, Ninja 2010 won't crank BlueDragon 2008 - 2012 Ninja 250R Tech Talk 6 March 12th, 2015 02:49 PM
Bike won't start. Dash lights up...sometimes.. kdogg2077 2008 - 2012 Ninja 250R Tech Talk 20 July 4th, 2014 12:01 PM
Another bike will crank but won't start thread... remix919 2008 - 2012 Ninja 250R Tech Talk 10 May 12th, 2014 01:05 PM
Bike won't start using starter switch lilgreenninji 1986 - 2007 Ninja 250R Tech Talk 36 October 31st, 2012 08:28 PM
bike won't crank!! LoneRonin 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2011 04:19 PM
