January 8th, 2016, 08:25 PM | #1 |
Join Date: Dec 2015 Motorcycle(s): 2006 Ninja 250R Posts: 85
2006 ninja 250 power band question
Spooph indicated in my winter storage thread not to worry about running the engine at 8-12k once the engine is warmed up. My bike seems to have a noticeable power band starting around 6k rpms. But, if I'm at 70mph in 6th which is between 8,200 and 8,400 rpms and Crack the throttle to pass, there is no burst of power. Is that normal for this bike, or is something maybe out of tune/adjustment. I am running new plugs, checked the gap, so I'm fairly certain it's not a plug issue. The bike is parked for the winter and my rpm range is from memory- haven't ridden for about a month.
January 8th, 2016, 08:52 PM | #2 |
Depending on your jetting, exhaust and gearing that would be normal. Many of the riders here have new gens (08-12) and that bike pulls the hardest starting around 8k with stock bits. Pregens (07 and less) can feel a bit different, many riders that own both even say they are faster engines.
January 8th, 2016, 09:02 PM | #3 |
MOTM - July '15
At that particular speed, it's normal.
January 9th, 2016, 09:56 AM | #4 | |
Join Date: Aug 2015 Motorcycle(s): 05 Ninja 250, 04 KTM 625 SMC, 01 Xc250 Posts: A lot.
Because Unregistered sucks at riding. |
January 9th, 2016, 07:46 PM | #5 | |
The problem could be adjustment of valves or dirty/incorrect size of jets or sticky slides/damaged diaphragms. You can always downshift one step (6 to 5) prior to attempt a pass, which will add 1000 rpm's to your engine in order to keep the 70 mph initially. Your engine happily delivers maximum torque around 9K~10K rpm's.
January 10th, 2016, 07:52 AM | #6 |
Your PreGen likes more RPMs than that (8,000-ish). Click down at least 1 gear if you need acceleration. A PreGen engine needs to be near 10,000 RPMs if you want to go anywhere.
As long as the engine is properly tuned and adjusted, and the oil is good, there's no problem running it in that range. It will pump some oil into the airbox through the crankcase breather when running in that range for an extended amount of time, especially in hot temps, so you need to keep an eye on the oil level a bit more than other bikes. Run Rotella T6 5W-40 oil. It's synthetic, easy to find, inexpensive, and covers all of the bases. Last futzed with by jkv45; January 10th, 2016 at 09:57 AM. |
January 10th, 2016, 09:06 AM | #7 |
Perhaps you need an upgrade to black or maybe even purple, if you're careful. I wouldn't go green, though. You might melt your tire.
January 10th, 2016, 06:17 PM | #8 |
Last time, before I parked the bike, I was going around 60 mph in 6th. That's around 7200 rpm. I did downshift to 5th, a celerated and shifted up to 6th. I was doing about 80 after the pass. It just seems like the greatest burst of power comes at closer to 6 or 7,000 rpms.
January 10th, 2016, 07:01 PM | #9 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
How much do you weigh? How much gear are you carrying?
OEM gear/sprocket ratio? OEM tires? |
January 10th, 2016, 08:41 PM | #10 |
I'm 5'-6" 145 lbs. No gear. Rear tire is a Pirelli 120/80-16. Front tire is stock size. I believe gearing is original/ stock.
Stock rear is listed as 130/80-16 Last futzed with by Nu2Street; January 11th, 2016 at 05:02 AM. |
January 10th, 2016, 11:39 PM | #11 |
Join Date: Mar 2012 Motorcycle(s): 2006 Ninja 250 Posts: 44
My 2006 has sport demon tires (100/90/16 and 130/90/16) and stock sprockets, and it is about 8800 rpm at 70mph. Is it because of the tire size or is it something I need to worry about? Is there a way to bring the rpm down at the same speed?
January 11th, 2016, 06:52 AM | #12 |
Install 15t sprocket Tang.
Tire question for 2006 250R | Nu2Street | 1986 - 2007 Ninja 250R Tech Talk | 8 | December 30th, 2015 12:11 PM |
Hooked up a wide band o2 on the 250 | cuong-nutz | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 29th, 2014 08:18 PM |
Flat Spot in Power Band | Redgeneral | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 20th, 2012 06:52 PM |
Power question, powerlet 12v to mini-usb power. | karlosdajackal | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 12th, 2010 05:03 AM |
Power band after mods.... | Cali619 | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 13th, 2009 07:49 AM |
