Old July 30th, 2009, 06:29 PM   #1
mista350z
Motorcycle(s): 08 CBR600rr, 08 Ninja 250r - sold
DIY Exhaust ???s
Ok So my new (used) exhaust came in the mail today. It is a TwoBros slip on. The guy who sold it to me said it comes with all mounting hardware. I downloaded the install manual for the exhaust off the website. I am looking at the exhaust wondering if this came with everything I need to install it. If anyone can look at these pics and let me know if there is anything else I need to install the slip on. I would rather get everything I need and then start, rather than get my hands all dirty and have to run to home depot to pick up parts. Any tips would be helpful too. I read kkims diy exhaust as well. This will be my first upgrade/install on my bike so be friendly guys.
Thanks in advance.
mista350z is offline   Reply With Quote
Old July 30th, 2009, 06:56 PM   #2
Daeldren
two wheel addict
Daeldren's Avatar
Motorcycle(s): 94 xlh 883, 1984 kawi gpz money pit
Slip-ons are fairly simple, in fact the full exhausts are fairly simple to install as well. The slip-on you bought looks like it has the adjustable clamp that attaches the slip-on to your main pipe, and the hanger bolt. Should be all you need to install it, other than getting some exhaust gasket material to prevent popping (you would put around the end of the main pipe where the slip-on clamps on to it.) but this will not hurt your bike if you do not put any seal on it, you will just get some popping when you lay off the throttle due to air getting in.
Daeldren is offline   Reply With Quote
Old July 30th, 2009, 07:03 PM   #3
AnarchoMoltov
AnarchoMoltov's Avatar
Motorcycle(s): 2007 Suzuki GSX-R750
Looks 2 me like it has everything, remove your stock can, and replace with slip-on...Slide your stock pipe into the inlet of the can 3/4" roughly, Mount the can with the srew on the top of it, the same way your stock can was mounted...Tighten the bolt, and clamp....DONE.....
AnarchoMoltov is offline   Reply With Quote
Old July 30th, 2009, 07:09 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
You should have that on your bike already
Old July 30th, 2009, 07:18 PM   #5
mista350z
Can I reuse the gasket that is already on the stock pipe?
Old July 30th, 2009, 08:20 PM   #6
mista350z
Ok...so 20 minutes later and I installed the exhaust. I fired it up and this thing is loud. I reved the throttle a bit and it started popping. How can I fix that? also where the 3/4 inlet meets the stock pipe, I tightened the clamp as hard as I could but it still felt loose. When I pulled the stock pipe out it felt snug. Could that be my problem for the popping?
Old July 30th, 2009, 08:29 PM   #7
AnarchoMoltov
The popping has to do with the kleen air system on the bike...To stop the popping, remove this by plugging up the system...It's really easy took me maybe 30 mins to do, you will need some supplies though...Here's a link
http://www.ninjette.org/forums/showthread.php?t=9948
Make sure all your connections on the pipe and can are secure, and if its still popping do this, You should do this anyway though now that you have a new can..
Old July 31st, 2009, 10:56 AM   #8
Snake
Snake's Avatar
Looks good on your bike. Nice job.
Old July 31st, 2009, 11:16 AM   #9
mista350z
Thanks.
Old September 7th, 2009, 04:58 PM   #10
killerkay3
killerkay3's Avatar
Motorcycle(s): 2009 Yamaha R6 / 2008 Green Ninja 250 (Sold)
so did you fix the problem with the popping? and if so how?
killerkay3 is offline   Reply With Quote
Old September 7th, 2009, 09:31 PM   #11
mista350z
Nope, I just got used to it. I have been meaning to pull the snorkel, but have been lazy...I am sure that + shimming will help alot.
Old September 7th, 2009, 10:46 PM   #12
remove the kleen system.
DIY MGP Exhaust Baffle dragonboy 2008 - 2012 Ninja 250R Tech Talk 8 August 17th, 2015 10:15 PM
DIY -T-Rex Exhaust Slider dragonboy 2008 - 2012 Ninja 250R Farkles 16 April 6th, 2013 02:05 PM
DIY: Exhaust Hanger (no welding) Shift250R 2008 - 2012 Ninja 250R Tech Talk 31 January 12th, 2013 08:09 PM
DIY- AP Exhaust Hanger kkim 2008 - 2012 Ninja 250R Farkles 12 June 18th, 2010 12:39 PM
DIY: Evotech Exhaust Hanger schneider_11 2008 - 2012 Ninja 250R Farkles 7 May 22nd, 2010 01:42 PM
