Old February 19th, 2016, 01:22 AM   #1
Triple R
Motorcycle(s): Suzuki's
Hard to downshift any ideas why?
Hey guys,
I have a 2010 250 I'm building for racing and it is very hard to downshift. I currently have ebay rearsets setup for gp shift and it literally hurts to try and downshift on this bike. Is this common? Any ideas of why this is going on?
I've installed a Factory Pro shift spring but it was hard before I ever installed this. Clutch is setup properly too. No idea what's going on. Any help would be appreciated!
Triple R is offline   Reply With Quote
Old February 19th, 2016, 03:09 AM   #2
The chain is most likely too tight. Perhaps you adjusted your slack on the stands and when the bike is on the wheels + rider weight it's too tight. It should have about an inch slack fully loaded.
Chain too tight is the #1 most common reason to fail trackday or race tech. I hope it's that simple for you.
Old February 19th, 2016, 07:14 AM   #3
Originally Posted by Triple R View Post
Hey guys,
I would start there.
Remove the connection to the engine's shifter shaft and see if there is any binding in the rearsets. Make sure the arms are in the correct position and the joints aren't binding.
If you have stock parts available, you could put them back on and see if it solves the problem.
Old February 19th, 2016, 08:03 AM   #4
Ghostt
Ghostt's Avatar
Shifter linkage alignment is critical for proper operation, check it especially when you changed the rear sets, something tells me it's off.
violente et ignorantia
ZX-2R BLOG
Old February 19th, 2016, 08:15 AM   #5
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
take a picture.
TEAM ALFALFA
www.apexassassins.com
Old February 20th, 2016, 09:04 PM   #6
Triple R
Will check it out thanks guys!
Old March 18th, 2016, 07:43 AM   #7
Any resolution?
Old March 18th, 2016, 08:22 AM   #8
Triple R
I pulled the trigger on a set of woodcrafts. Solved the problem! STAY AWAY FROM CHINA SETS! I personally didn't buy them, they came on the bike already!
Dropped bike. Cannot downshift ): skeeker20 2008 - 2012 Ninja 250R Tech Talk 6 August 13th, 2012 03:57 PM
Clutchless downshift? Numbersix Riding Skills 9 August 26th, 2011 01:53 PM
Loud noise on downshift Archerzz 1986 - 2007 Ninja 250R Tech Talk 17 June 1st, 2011 03:22 PM
Unable to downshift (mechanical) junsiang 2008 - 2012 Ninja 250R Tech Talk 3 April 18th, 2010 02:06 AM
Newbie can't downshift! djmonkiigrl 2008 - 2012 Ninja 250R Tech Talk 20 July 7th, 2009 06:01 PM
