Old March 27th, 2016, 01:44 PM   #1
Jono
Jono's Avatar
Question Earplugs and a new Helmet
So yesterday I purchased a new helmet, Shoei Qwest. I have been riding with 3M foam earplugs 32dB for years with my old helmet, Seven-Zero-Seven Backlash but every time I tried to put on my new Shoei with the earplugs, they would get pulled out slightly which makes them worthless.
The helmet fits great once it's on my head, but it is currently kinda painful to remove as it pulls my ears. Might need to work on trying to remove the helmet differently. And yes, I am pulling on the chin straps as I'm removing it. Hopefully it will just break in and my ears won't get so pinched when removing the helmet.
I Must Have Earplugs! I absolutely hate riding without them.
Is it normal to have difficulty keeping earplugs in while putting on a new helmet? Or do I need to start looking for a different type of earplug? I don't remember having this issue with my previous helmet when it was new but I may not have been wearing earplugs back then either. Also, it didn't fit quite as snug either.
Help Me!
Old March 27th, 2016, 06:30 PM   #2
Ralgha
Ralgha's Avatar
My first guess is that you're not using the earplugs correctly. They shouldn't stick out far enough, or be loose enough, for a helmet to pull out.
Old March 27th, 2016, 06:34 PM   #3
Get a set of the re-useable plugs that have the string connecting them. Pull the string, Clip 1/8" off the outside of the earplug so it clears your helmet. Problem solved. They're re-useable and can be cleaned by dunking in soap and hot water.
Old March 27th, 2016, 06:46 PM   #4
Yarhj
Yarhj's Avatar
Motorcycle(s): Ninja 250 (2001)
I have to agree with this. There's almost no way properly-inserted earplugs could be affected by helmet fit. Watch this smiley fellow demonstrate proper earplug insertion.
Yarhj is offline   Reply With Quote
Old March 27th, 2016, 07:14 PM   #5
Jono
Jono's Avatar
Holy crap I am so stupid. Haha. I did it like the dude in the video and I could put my helmet on no problem. Man do I feel dumb. I always thought I was getting them in there deep enough but I haven't been. I mean they worked fine the way I was doing it before but now they will really work. Thanks folks. I'm dumb. Lesson learned.
Old March 27th, 2016, 07:31 PM   #6
Yarhj
Yarhj's Avatar
To be fair, proper earplug technique is COMPLETELY unintuitive. I spent more than a year wearing them incorrectly at work (along with all of my coworkers) before I found out I had been doing it wrong in some random thread about earplug use on motorcycles on either this forum or advrider =P.
Old March 27th, 2016, 09:37 PM   #7
They must touch your brain.
Old March 28th, 2016, 07:47 AM   #8
Brother Michigan
Motorcycle(s): 2013 Ninja 300
Don't feel bad about not knowing how to properly insert your earplugs. OSHA actually has a simple formula for calculating the noise reduction rating of earplugs as they're typically worn (i.e. incorrectly) that can be as low as half the stated rating.
If you ever still have issues with your helmet pulling your earplugs out, look into a silk balaclava. It will stop the ear-pulling, too.
DISCLAIMER: I generally have no idea what I'm talking about.
Old March 28th, 2016, 08:28 AM   #9
Panda
not an actual panda
You should super glue your ears shut before each ride.
Problem = solved.
Old March 28th, 2016, 08:44 AM   #10
"Sound deadening is not just a lifestyle, it must be at one with your soul."
-Sensei Smith.
What earplugs do you use? asdfman Motorcycle Gear 14 March 16th, 2015 05:20 AM
Should You Wear Earplugs? hamm Videos 12 March 17th, 2013 03:31 PM
FS: Used earplugs alex.s Gear-related 34 October 27th, 2011 09:33 PM
looking for earplugs alex.s Motorcycle Gear 13 June 8th, 2011 07:25 PM
Free Earplugs - Get Them Now g21-30 Gear-related 45 May 11th, 2010 08:16 PM
