Old March 31st, 2016, 06:06 PM   #1
smitty3896
Motorcycle(s): 2005 Ninja 250r
fuel needle cleaning.
I am working on the abandoned nightmare of an 06 250, which i mentioned a couple of weeks ago. i have a question about cleaning the fuel needle, the piece the float pushes up and down. im guessing i canot put this in the chem-dip because of its rubber top, do i just need to spray it with carb cleaner and wipe it good? or is it actually safe to drop into the chem-dip cleaner.
its part # 16030 on this diagram
http://faq.ninja250.org/images/f/fc/...ETOR_PARTS.png
smitty3896 is offline   Reply With Quote
Old March 31st, 2016, 07:18 PM   #2
Copied from
https://www.berrymanproducts.com/pro...parts-cleaner/
"Fast-acting immersion cleaner for all metal parts, including alloys. Removes gum, varnish, sludge, carbon, and grease without heat or agitation. Non-chlorinated and nonflammable formula is VOC-compliant in all states. Safe on plastic and rubber and will not cause rusting. Use for cleaning carburetor and transmission components, valves, and other small, hard-to-clean engine parts."
You may want replacing those, as the tip tends to harden with time, especially if exposed to air.
Old March 31st, 2016, 07:23 PM   #3
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
U can replace it with a new one, if that is an option...?
chugs is offline   Reply With Quote
Old March 31st, 2016, 07:41 PM   #4
Ghostt
Ghostt's Avatar
Replacement is called for, these are consumable parts. That small viton tip wears out, the picture below shows old vs new. PM @ducatiman for you carburetor needs, he sells rebuilding kits, along side full services for carburetors.
https://www.ninjette.org/forums/show...09&postcount=3
https://www.ninjette.org/forums/showthread.php?t=226815
violente et ignorantia
ZX-2R BLOG
Old March 31st, 2016, 10:02 PM   #5
SRH
Motorcycle(s): Kawasaki, Hondax3, Suzuki, Ducati
Just a little tip: When I'm working on carbs, any carbs, that won't be going back together the same day, I leave the bowl seals and any other rubber or fiber parts covered w/Stabil until they're ready to assemble so they don't dry out.
SRH is offline   Reply With Quote
Old April 2nd, 2016, 06:27 AM   #6
ducatiman
ducatiman's Avatar
IMHO...costing all of $6 ea ...BOTH float valves an automatic replacement during any carb refurb or comprehensive carb service....as do orings while carbs are off and you're in there.
If you leave the bike an excuse to do the job twice...you will.
Old April 2nd, 2016, 08:39 AM   #7
Ghostt
Ghostt's Avatar
ZX-2R BLOG
How high the needle? Ninjinsky 1986 - 2007 Ninja 250R Tech Talk 1 September 29th, 2014 05:27 AM
Cleaning and lubing my chain, oilchange , and cleaning air filter SON1C 1986 - 2007 Ninja 250R Tech Talk 3 June 29th, 2013 05:55 AM
what carb needle to use? 01subaru 2008 - 2012 Ninja 250R Tech Talk 6 April 24th, 2012 05:17 PM
Cleaning out the Fuel Tank quanttrom 2008 - 2012 Ninja 250R Tech Talk 1 March 13th, 2012 11:13 PM
which size needle goes where? slow_2k10 2008 - 2012 Ninja 250R Tech Talk 7 September 7th, 2010 01:57 PM
