#1 |
Certified looney toon
MOTM Jul '13, Jul '14
Parking lot drills
Signed up for an Advanced Riders Course offered by our local motor cops so decided to take both bikes out for some drills.
Here's a summary of my hour long pattern today.
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
![]() 4 out of 4 members found this post helpful. |
#2 |
http://amgrass.com/forum/course-maps/
http://amgrass.com/forum/practice-practice-practice/ http://www.msgroup.org/Tip.aspx?Num=194&Set= 1) Rear brake increases lean and tightens turn / Keep throttle slightly open (best/steady control with two fingers on front brake lever), so engine is slightly fighting brake / The less clutch the best, but it is your safety net if engine stat surging/coughing. 2) Throttle reduces lean and opens the turn. 3) Lean your body opposite to the bike: better steering geometry to achieve tighter turns.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
![]() 2 out of 2 members found this post helpful. |
#3 | |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Thanks for posting the vid. I'm going to try those bike control routines.
* rear brake on * 1st gear * revs up at a constant 4k * clutch very slightly disengaged I then adjust speed using the rear brake. Unfortunately I can't easily use my throttle to moderate my speed at low speed. The throttle on my bike is really jerky and imprecise and has been for a while now. I've given up on trying to get it restored to how it was when the bike was almost new. I just have to do things a bit differently.
#4 |
Thanks for the tips, @Motofool! (sadly, amgrass is blocked at work - phooey!)
I'd read/heard that the rear brake was the best for these slow speed rides, but when I tried it on both the Honda and the Ninja, it felt ... weird? Almost like my foot didn't want to cooperate and do anything with the brake. I do use the rear brake regularly, both for slowing to a stop at intersections and in sync with the front brake for slowing and stabilizing in corners. But in the parking lot, not sure what happened. I'll add it in again and see if I can keep a steady fluid movement. I've been using the throttle and clutch to modulate my speed (as can be heard) with limited brake use - mostly when I get going too quick on the straight before the turn. Here's the work I did on the Honda. While I've found it's easier to move to counter balance on the Ninja, on the Honda once I have moved slightly off center, it's more stable.
#5 |
Awesome Teri!
There are two main ways to do slow speed stuff. 1. Drag the rear brake, hold the throttle steady and use the clutch to control speed 2. Drag the rear brake, hold the clutch steady in the friction zone and use the throttle to control speed I fall in group #2. Once riders figure out which they are, things start to fall into place with a bit practice and full lock to lock turns start to get real simple. ![]()
#6 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
#2 here as well.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
#7 |
I'm going to have to have someone walk me through the advice so far. I tried dragging the rear brake and the bike was incredibly unstable. I kept ending up putting my foot down on both left and right turns.
Also tried holding either the clutch or throttle steady. Definitely going to end up being a throttle steady rider. Holding the clutch steady torqued my wrist too much trying to find the sweet spot. However going back to feet on pegs and feathering the clutch and throttle got me able to move back and forth and really counter balance as I got down to 1.5 parking space wide turns. ![]()
#8 |
MOTM - June '15
When I'm doing super slow stuff, slower than walking, on the KLR and tenere, I actually stand up on the pegs, while slipping the clutch and dragging the rear brake.
I have people looking at me funny never stopping at a red light lol
#9 | |
Nooblet
MOTM - Oct '13
#10 | |
![]() Quote:
The idea is to concentrate in one control only, while you dramatically turn your head, look far, relax your arms and sense balance with your body. The reason to use the rear brake as only modulating control is that the foot is independent from steering, which can mess the finesse of throttle and clutch control inputs. Also because it has the braking effect that clutch and throtle combination lacks.
#11 |
I just got off the Advanced Riders Course who noted that many of the super fast motorcops are not using their rear brake and offered advice on using the clutch, throttle, and front brake smoothly. I went through the course working just the clutch and throttle and that got me through their course easily. Only problems I had was when I tried turning super tight (<16') and lost momentum while not counter balancing enough. My failure for trying something far more extreme than any of the other riders. Once I opened up my turn to 18'-20' then everything worked smoothly and made the patterns simple.
Since I'm not going for speed, only smoothness and being able to maneuver around traffic, I'll keep practicing what has worked for me and continue taking courses.
#12 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
So now do we get a video of your skills after the course?
#13 |
Eventually. bur first how about a video on the course?
#14 |
Your head turn to the right is not as strong as to the left, but I am sure you know that.
#15 |
No I didn't. Thought it was about the same.
Stupid question, sure it isn't a trick of the camera placement?
#16 |
I am sure... I also have my cam on the left side, so I know what I am looking for already.
#17 |
Ah OK. So, nope, didn't know that.
#18 | |
MOTM - Jan '16
One of the training companies around here that is run by a retired motor officer has a similar course. They also will rent you a Harley police bike (or a Street 500 with crash bars) for the course so you don't worry about dropping your bike. |
#19 |
While I was out practicing on the super secret motor cop course (as in, the course they actually use to practice competition level patterns), one of the retired officers swung by to also practice. He was kind enough to show me a few more of the patterns, explain the purpose behind some of them, and film me going through a series of tight circles.
#20 |
#21 |
sammich maker
MOTM - Apr '15
About how fast are you going? 1st or 2nd gear?
![]() https://www.brocksperformance.com/VZ...0035+C450.aspx |
#22 |
The correct info (after a half dozen laps to check) is first gear, between 7-10mph.
#23 |
sammich maker
MOTM - Apr '15
Thank you.
#24 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
All those tire marks are from you drifting through the turns?
#25 |
hahahahaha, no, thankfully. My tires would be dead if that was me!
Some are the tracks from motorcycles - you can clearly see it's a single track vehicle. Others are (per a nurse at the senior home behind the wall) cars back there doing donuts and burnouts.
#26 |
My youngest boy and I were just out last night doing some drills.
He just got his first bike, a 2009 Ninja 500, and completed the MSF course about a month ago. I wanted to see what they taught him and how he's doing. I was on my 2006 SV650n. We did some warm-up maneuvering, tight circles, full lock. Not something i do too often, but good to practice. Then we got into some hard braking, eventually up to about 40 mph. Made a few adjustments to the levers to get more travel, and he eventually got some good hard stops right on the edge. I was doing all of it also. Kinda fun, and I improved as well. Overall he's doing pretty well (he's ridden on the dirt since he was about 4). I've taken him out on a few rides where I lead and he follows, then we discuss the ride and any issues when we get back. Worked well for my other boy, who has been riding on the street for almost 4 years now. |
Things you see in a parking lot. | reggae5 | Pictures | 2 | June 29th, 2015 12:16 PM |
parking lot practice | subxero | Riding Skills | 34 | April 9th, 2013 12:26 PM |
Parking lot Scam! | rockNroll | Off-Topic | 31 | August 4th, 2012 02:05 PM |
Parking lot accidents | cuong-nutz | Off-Topic | 6 | May 14th, 2012 12:43 PM |
parking lot test! | heatherintegra | Riding Skills | 17 | May 26th, 2010 07:58 PM |
