Old September 5th, 2016, 01:29 PM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Trail Tech Vapor Odometer
So I've been trying to figure out how to transfer the odometer reading from the stock gauges over to my new Trail Tech Vapor and couldn't find anything on this forum, but I did some Googling and figured it out.
So when you get the Vapor, the odometer starts at 0 and the manual doesn't tell you how to change this, which makes sense because it's illegal to tamper with odometer readings. However, 9.9 times out of 10 anyone who buys a Vapor isn't putting it on a bike with 0 miles on it.
So here's how to change the odometer reading to match the odometer on the stock gauges. Remember: this is only for transferring over the current odometer reading and shouldn't be used to tamper with the mileage and change it to an inaccurate number, because that's illegal!
1. Press all three buttons at the same time for 3 seconds until you enter data settings mode.
2. Press the mode button until you get to the tire size screen. Enter in 9110 for the tire size and then hold down the right button for three seconds (don't worry; your true tire size will still be saved and used).
3. If done correctly, you'll see the 12/24 hr screen. Keep pressing the mode button until you get to the Odometer set screen. From here, you can change the odometer reading.
4. Once set, you can wait for it to automatically exit the data settings mode or keep pressing the mode button until you exit.
To see the odometer reading, press the mode button until you get to the max speed and max RPM screen. Then press the right button, which will show you the odometer.
Cra1g is offline   Reply With Quote
4 out of 4 members found this post helpful.
Old September 7th, 2016, 11:27 PM   #2
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Thumbs up
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old September 7th, 2016, 11:28 PM   #3
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
geez.. i thought the thumbs up is for "found this post helpful".
What button to click if i want to rate that??
Old September 8th, 2016, 12:23 AM   #4
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
Wish I knew this before!!! Thanks though..
The Bike | The Truck
Old September 8th, 2016, 07:02 AM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Need more posts! Then you can click the thumbs up. For now, just say thank you!
Goin' fast on slow bikes!
Old September 8th, 2016, 07:06 AM   #6
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
To rate the post helpful or unhelpful you need a certain amount of time and posts on forum @Abu_Mishary
Old September 8th, 2016, 07:37 PM   #7
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
i need to be a post whore. aahhh.....
Trail Tech Vapor MAZ 80 General Motorcycling Discussion 2 October 19th, 2015 04:10 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Trail Tech Vapor and mount rugbert 1986 - 2007 Ninja 250R Farkles 12 September 2nd, 2013 11:36 AM
Vapor Trail Tech Question/Help skilletmo 2008 - 2012 Ninja 250R Tech Talk 41 May 12th, 2013 02:40 PM
Trail Tech Vapor Tach experience? Chicagobob 1986 - 2007 Ninja 250R Farkles 5 April 19th, 2013 05:23 AM
