Old September 16th, 2016, 01:45 PM   #1
Trinja
Motorcycle(s): Honda RC46 VFR800, 2009 Ninjette
New lazy owner....
Okay, I briefly searched the forum for answers, but I thought I'd ping the membership, since I'm hoping these may be common issues and sometimes it's easier to ask people that have experience on these things...
Bought the Missus a 2009 last night, 21Kmiles and the thing looks to be in very good shape. Bought it kinda impulsively, at night, and drove it home. Here's what I see now....
Fuel gauge and very top of speedo is starting to fog up. Not from moisture, but looks more from U/V, like a car's headlight, only very mild. Same for the oil level window. Common?
I smell coolant. Everything is dry as a bone, with no blow-by that I can see. I haven't ripped the thing apart yet, but I will. But, I smell coolant, without a doubt. Common?
Stutter, only at light throttle input, and only between 7-8K RPM. Any gear/rev below that is fine, anything above that is fine. It's only on light throttle at 7-8K. I'm gonna run some seafoam through it I suppose, and change the plugs... but thought I'd ask. Common?
Other than that... the thing looks close to new as can be for a bike this age. I can attach pics, if needed.
Trinja is offline   Reply With Quote
Old September 16th, 2016, 01:54 PM   #2
Welcome Trinja,
None of those issues are common.
Old September 16th, 2016, 02:10 PM   #3
Trinja
Welcome Trinja,
LOL.... Welp, I guess let's turn it into a stunt bike.
Oh, and it looks like I posted in the wrong sub section. Wow, I'm dumb.
Okee dokee... not a great start.
Old September 16th, 2016, 02:14 PM   #4
/moved to new-gen tech
Old September 16th, 2016, 02:19 PM   #5
Well, these lil bikes are pretty hard to mess up, but it's possible. Not common doesn't necessarily mean hard to fix.
Things to check;
Coolant: Make sure it's filled to proper level and is purged of all air pockets. Not ensuring things are right may result in the coolant overflow tube drainage. If the smell is very sweet, then it's leaking and burning before hitting the pavement. If more subtle, then could be coming out the exhaust.
Dash: The lens on the gauges can be taken apart and polished like car headlights if you have the right stuff. Otherwise, just replace it as it's not worth the time to try to fix vs cost to repair.
Stutter: You can try to run a tank of seafoam or 2 and it may help. Otherwise, it sounds like a carb clean/idle screw adjustment/float adjust and sync are in your near future. But first, is this only with the choke on or after fully warmed up?
Old September 16th, 2016, 02:22 PM   #6
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
You should be able to use the same headlight polish on your speedo.
Pics are always a welcomed addition
Old September 17th, 2016, 03:30 PM   #7
Trinja
Thanks guys, coolant smell is certainly there. No leaks that I can see though. I'm gonna show wifey how to change the oil tomorrow so I'll get better eyes on it....
Pulled the air filter... Has a bit of oil blow by on it. I'm just gonna buy a new one and start fresh.
And yup, gonna do the headlight treatment on the cluster, I was just trying to figure out if any of these issues are common on these things.
Plugs and seafoam too, while I'm at it.
Thanks for the input, guys!
Old September 17th, 2016, 03:37 PM   #8
JohnnyBravo
I smell coolant from mine sometimes, but ain't got no visible leaks either maybe it ghosting
Old September 17th, 2016, 04:46 PM   #9
BDfromBC
Motorcycle(s): EX250-J
The coolant, I would let it sit running while I'm there watching it for 30 mins or so, ride around driveway /parking lots and then try to find a spot of the ground.
Or you can tear down the fairing on the right side and watch everywhere as its running, could be as simple as purging the system to get rid of the smell, is the fan coming on?
The stutter sounds like your carbs, run some cleaner through, don't be shy with the seafoam once, I'd put significantly more than they say to add to fuel, and run it all through.
And the gauges, use some mothers headlight restore, and call it a day 😎
BDfromBC is offline   Reply With Quote
Cut my fender (when you're too lazy to eliminate) Lap202 2008 - 2012 Ninja 250R Farkles 7 August 4th, 2016 03:37 PM
New Valve Shim Matrix (the lazy way) headshrink 2008 - 2012 Ninja 250R Tech Talk 20 May 14th, 2014 09:31 AM
[visordown.com] - The lazy biker's guide to cleaning Ninjette Newsbot Motorcycling News 0 April 3rd, 2013 09:50 AM
Lazy Sunday Backroads Ride Chamus57 Ride Reports 7 October 1st, 2009 11:21 AM
Lazy owner or scam? backinthesaddleagain General Motorcycling Discussion 13 June 28th, 2009 07:20 PM
