September 23rd, 2016, 08:04 AM | #1 |
My first 10,000 miles
I hit this on my Ninja 300 last month. It's been a lovely year, and interesting for me as I'd started to think I would get bored with the bike after three months. However I told myself I had much to learn and I didn't actually realise how right I was. I wrote about some of it here.
I love my bike and riding even more than I did a year ago. I wouldn't have thought that was possible. |
September 23rd, 2016, 08:24 AM | #2 |
September 23rd, 2016, 09:17 AM | #3 |
I'm only at about 4,000 miles on mine, and loving it more every time I take her out! Everybody seems to think the little bikes are just for starting out but I'll probably keep her for a while. I love having a light bike!
Glad you're having such a good time. |
September 23rd, 2016, 09:17 AM | #4 |
It's good to hear a success story, keep enjoying it. But don't lose your vigilance... other drivers do not see you!
If you had to replace the chain and sprockets in less than 10,000 miles, something was amiss. Did you keep it lubed regularly? I've gone farther than that with a conventional non-O-ring chain, and my sprockets normally go three times that far. |
September 23rd, 2016, 09:26 AM | #5 | |
The problem was two-fold. I rode through winter and part of the cleaning regimen (using Maxima cleaner) involved rinsing the chain, and I think I just never got it dry enough; eventually I got a couple of tight spots almost certainly due to water ingress. I also adjusted it too frequently, which hastened the occurence of tight spots. I'm not sure the original chain shipped with the bike was that great, as the new one hasn't needed an adjustment in 1500 miles since I put it on. I don't use any water any more and usually clean and rub the chain with kerosene or WD40, before applying the lube. |
September 23rd, 2016, 09:37 AM | #6 |
Good analysis, thanks. I always hate to wipe a chain to clean it, because it wipes grit into the gaps between the side plates, but with riveted chains the alternative is very tedious. I've seen plastic contraptions that allow rinsing with solvent with the chain in place, but haven't tried one of those. Maybe someone here has experience.
I remove my bicycle chains and soak them in Varsol, shaking them in a Gatorade bottle intermittently for a few days. Then I dry them and re-lube them in a mix of Varsol and grease and hang them up until the Varsol is gone. Rotating two chains that way, I can get more than ten times the life that the manufacturers say I should get. Like easily 15,000-20,000 miles per chain. |
September 23rd, 2016, 09:42 AM | #7 |
Certified looney toon
MOTM Jul '13, Jul '14
Congrats! It's cool seeing that fifth digit appear, isn't it?
Keep riding, keep learning, and keep enjoying your bike. They can really go anywhere.
50,000 miles.... | bdavison | General Motorcycling Discussion | 7 | October 2nd, 2015 04:30 AM |
45,000 miles and it finally got me | backinthesaddleagain | !%@*#$%!)@#&!%@ I crashed! | 34 | November 18th, 2014 07:07 AM |
Is 33,000 too many miles? | XurXes | General Motorcycling Discussion | 10 | August 25th, 2012 06:58 PM |
12,000 miles and my first mod | Little Green Machine | General Motorcycling Discussion | 30 | June 26th, 2012 05:37 PM |
After 11,000 miles... | RyderRider15 | Ride Reports | 9 | April 10th, 2012 06:06 PM |
