Old January 10th, 2017, 10:29 AM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Can I use an RK XSO Master Link with an SO chain?
So for my track day only bike I ordered a RK 520 SO chain, and it came with a clip link. I am trying to find just a rivet master and all I am finding are XSO master rivet links. They looks like same, just wanted to sanity check before I order. Anyone know if I can use an XSO with an SO chain? Thanks!
daverdfw is offline   Reply With Quote
Old January 10th, 2017, 10:36 AM   #2
If they are the same pitch and width I don't see an issue, we use alternate brand master links from time to time during a track day and all works out just fine.
Old January 10th, 2017, 12:00 PM   #3
Clip or ribbeted type?
Old January 10th, 2017, 01:30 PM   #4
daverdfw
I came with a clip, I want a rivet type
Old January 10th, 2017, 01:48 PM   #5
Clip or master, pitch and width rule the day. If you search this site, you will find methods of safety wiring clip style master links.
Bottom line, don't mater which type, check often and check like your arse depends on it, because "IT DOES."
Old January 10th, 2017, 01:51 PM   #6
daverdfw
would this one work?
https://www.revzilla.com/motorcycle/...xw-master-link
I have a rivet tool coming.
Old January 10th, 2017, 04:41 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
all i am wondering is why?
TEAM ALFALFA
www.apexassassins.com
Old January 10th, 2017, 05:09 PM   #8
daverdfw
why what? On the wiki and everything else I have read it says not to trust the clip master links. I am just trying to find the correct rivet one for my chain.
Old January 10th, 2017, 05:28 PM   #9
Yes...
I have used clip masters with success and fail. To each their own on what they want to invest their own in.
Bottom line as I am sure you already know, rivet and forget aside of a an eyeball on it before the track day. If you use the clip style, still have a look before riding for the day, but if at the track... might want to safety wire it.
Not sure why I found this pic first, but this image is MY work and will pass track day tech without question.
Old January 10th, 2017, 05:33 PM   #10
^^^^ fyi
That safety wiring job as good as it looks, will NOT last forever, please check it every track day. HOT, COLD, HOT, COLD, HOT, COLD makes the wire brittle and it will fail on you. DON'T let it fail.
Old January 10th, 2017, 05:38 PM   #11
daverdfw
I ordered the rivet one. This chain should last a long while. So I want to be able to not worry about it.
RK 520XSO Chain Clip vs Rivet Master Link agentbad 1986 - 2007 Ninja 250R Tech Talk 5 May 15th, 2014 07:35 PM
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? CZroe 2008 - 2012 Ninja 250R Tech Talk 56 July 7th, 2012 05:42 PM
Adding a rivet master link to the stock chain ??? Tiane 2008 - 2012 Ninja 250R Tech Talk 1 June 13th, 2012 12:58 AM
Request: Silver chain, gold master link. Mountain Dew Pictures 3 January 25th, 2012 08:24 AM
FS: RK XSO 520 gold rivet master link choneofakind Motorcycle-related 3 January 18th, 2012 05:48 PM
