Old January 20th, 2017, 05:19 PM   #1
daverdfw
Motorcycle(s): 2009 Ninja 250
Can I still use this master link?
I am trying to do a rivet master link for the first time. And I was using the tool to rivet it, and I was using a set of micrometers to make sure the new one was the same flare as the existing. The existing is 5.60mm the new one I got to 5.55m and part of the rivet kinda split. Do I need to get another master link?
Large pic, you can see it around 11 o'clock
daverdfw is offline   Reply With Quote
Old January 20th, 2017, 05:33 PM   #2
Flying
Motorcycle(s): 2010 Ninja 250
Definitely don't reuse that.
Old January 20th, 2017, 05:34 PM   #3
daverdfw
Sigh, this will be my 3rd link. I misused the tool on the first one. Chain came with a clip link. But I had always read those are bad news.
Old January 20th, 2017, 05:55 PM   #4
Not to tell anyone what to do with his or her own safety, but I've used clip type master links for many tens of thousands of miles and never had one give me any trouble. With an O-ring or X-ring chain, you do have to squeeze the link together and make sure the clip is really seated in the grooves properly. These days I usually do this to them with some good adhesive like 3M weather strip adhesive, although in the past I've used them without it:
Old January 20th, 2017, 06:07 PM   #5
9 times out of 10 in my experience with clip masters, is it's installed backward and comes off when the chain gets sloppy.
1. Install it the right direction
2. Keep your chain adjusted
3. Keep your chain clean and lubed
4. Inspect it a bit more often
There shouldn't be much issue really, but like you... I want a rivet type.
Old January 20th, 2017, 06:12 PM   #6
daverdfw
4. Inspect it a bit fore often
any idea how much I should flare it? It came with no directions from RK.
Old January 20th, 2017, 06:53 PM   #7
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
It doesn't take much...if you doubt it just try to get it off, and I'm with Jim .....never had a problem with master link clips.
Old January 20th, 2017, 07:32 PM   #8
Ghostt
Ghostt's Avatar
In in the Clip club myself for many years, no issues if you install it properly, and maintain the chain.
violente et ignorantia
ZX-2R BLOG
Old January 20th, 2017, 08:45 PM   #9
daverdfw
I went ahead and ordered 2 more master links. 5$ each. Since I made the investment in a tool I might as well finish the job.
Old January 21st, 2017, 05:20 AM   #10
britx303
Motorcycle(s): TOOOOOO MANY!!
Heck,I race with clip links. Just smear some clear silicone over it as a little extra "placebo" and go with it. Keep it all clean and lubed to move freely and fugetaboutit
britx303 is offline   Reply With Quote
Old January 21st, 2017, 07:12 AM   #11
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I have good experiences with clip type master links. Goes on & comes off easy with needle nose pliers.
My personal opinion: Although not as secure as rivet type of master links, as long as the clip is installed in the proper direction and you keep your chain reasonably maintained, I don't see how the clip can fail.
Riding it like I financed it.
Old January 21st, 2017, 07:37 AM   #12
^^^ what he said pretty much. I am unaware of an official flair measurement when installing a rivet master link. From what I know, it's more a visual inspection and an attempt to pry it off. Trust your gut, if it looks good and stays in place, mission accomplished.
Old January 21st, 2017, 07:40 AM   #13
I'm surprised that the riveting tool isn't designed to stop when it's done, especially if going too far splits the rivet head.
Old January 21st, 2017, 09:38 AM   #14
jrshooter
Motorcycle(s): ninja 300
one more reply for the clip, love em.
Old January 22nd, 2017, 09:49 AM   #15
genosr1
Motorcycle(s): gsxr 750, sv650, 250 ninja
don't change it , it's still 100 times stronger than a clip
genosr1 is offline   Reply With Quote
Can I use an RK XSO Master Link with an SO chain? daverdfw Ninjettes At Speed 10 January 10th, 2017 05:38 PM
Missing piece to my master link?! mrudich 1986 - 2007 Ninja 250R Tech Talk 24 October 10th, 2014 07:29 PM
FS: RK XSO 520 gold rivet master link choneofakind Motorcycle-related 3 January 18th, 2012 05:48 PM
Riveting new master-link headshrink 2008 - 2012 Ninja 250R Tech Talk 13 December 17th, 2011 06:39 PM
Watch your master link clips!!!! bdavison General Motorcycling Discussion 42 October 7th, 2011 08:07 AM
