Old November 22nd, 2017, 03:59 PM   #1
NinjaBiker
Motorcycle(s): 2007 Ninja 250, 1985 Honda XR200R
Fuel Not Flowing to Carb Bowls
Have a 2007 Ninja 250. Currently getting the fuel tank cleaned as it sat a while with gas. Noticed that when I start the engine the fuel is not flowing to the carb bowls (I had drained them first) and the engine does not start. It appears the petcock is working to flow fuel when there is vacuum. So, if fuel is not getting to the carb bowls, does that indicate the internal carb passages are clogged? Perhaps I need to pull the carbs and clean them. Not looking forward to that. Thanks.
NinjaBiker is offline   Reply With Quote
Old November 22nd, 2017, 04:42 PM   #2
HI Steve, it's good to meet you. If you're saying that the output hose of the petcock flows plenty of gas when you disconnect it from the carbs and crank the engine, but it's not getting to the float bowls, yes, something is wrong, like the float needles are stuck closed from gasoline turning to varnish. You can bet that if that's the case, there's a lot more to clean then the float needles and seats.
You may know, but Ducatiman here on the board does professional carb refurbs at a reasonable price. That is, if you don't want to do the work yourself.
Old November 22nd, 2017, 04:51 PM   #3
NinjaBiker
Thanks Jim. That makes sense. Guess it's time for me to pull the carbs and learn why my next bike should be fuel injected.
Old November 22nd, 2017, 05:30 PM   #4
I'm not sure you'd be any better off with a fuel injected engine that has old stale fuel that's turning to varnish in the system.
Old November 22nd, 2017, 06:15 PM   #5
Except fuel doesn't evaporate in a sealed FI system. It stays liquid pretty much forever since there's no openings. I've started up cars that's been sitting for years and no fuel-problems.
Old November 22nd, 2017, 06:24 PM   #6
That's good to hear, because I have one of those that I'll need to get running before long.
Old April 26th, 2022, 07:20 PM   #7
Zgray350
Did you figure it out I got same problem
Zgray350 is offline   Reply With Quote
Old April 26th, 2022, 07:29 PM   #8
Hi Zach, verify petcock actually flows or doesn't flow petrol:
1. disconnect fuel-hose from carbs and aim into cup/bucket
2. apply vacuum to petcock's smaller hose (with vaccum pump or by sucking on hose, dangerous)
Does fuel come out of petcock?
Old April 26th, 2022, 07:31 PM   #9
Zgray350
Yes if I unhook line from petcock and crank it gas comes out Iv cleaned carbs prolly 5 times last time I put gas in carbs put bowls on and it started tilll it ran out loosed drain screws and nothing came out
Old April 26th, 2022, 10:23 PM   #10
Try testing other end of fuel-hose. Leave connected to petcock and disconnect from carbs. Then crank again.
Old April 27th, 2022, 04:18 AM   #11
Zgray350
Fuel comes out that way also
Old April 27th, 2022, 05:44 AM   #12
ducatiman
ducatiman's Avatar
https://www.ninjette.org/forums/show...40#post1307440
response in your actual thread
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Seafoam in the carb float bowls? Kurgan 2008 - 2012 Ninja 250R Tech Talk 14 July 22nd, 2015 10:06 PM
CARB Dropped and Busted Fuel Inlet - Suggestions? Road Dawg1 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2014 07:12 PM
Unscrew carb bowls - tips please mickheaven 2008 - 2012 Ninja 250R Tech Talk 10 September 5th, 2013 09:52 AM
Adjusting the carb to let more fuel in? 2fiddy 2008 - 2012 Ninja 250R Tech Talk 3 May 16th, 2011 11:20 AM
Hex Replacement Screws for Carb bowls and tops g21-30 2008 - 2012 Ninja 250R Tech Talk 2 June 14th, 2010 06:52 PM
