#1 |
Join Date: Mar 2020 Motorcycle(s): 2012 Ninja 250r Posts: 6
Leaking Carb
I have a 2012 250r and just did a carb rebuild kit, I just put it back on with the fuel tank just to find out that I have a leak. After some investigation I found it to be leaking on the left side where the pilot air screw is. It seems to looks slightly different compared to the other side. Can those holes be "bored" to clean them up, or am i missing something that would still be causing a leak?
Thanks |
#2 |
Before condemning the pilot screw....be certain that the fuel is not migrating from elsewhere. A rail oring(s), a bowl seal or a failed float valve all need to be eliminated.
This is where a "wet test" on the bench is so valuable in diagnosing, pinpointing and saving R & R time.
#3 |
Hi Nick, welcome to Ninjette!
![]() Did your carb rebuild kit come with all new jets and pilot screws? Did it come with new O-rings, washers and springs for pilot-screws? Those items really should be replaced when rebuilding. You might be missing spring or O-ring on that one pilot-screw that's leaking. Or parts were re-assemble in wrong order. |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
Leaking Carb | woodchipliz | 1986 - 2007 Ninja 250R Tech Talk | 6 | February 19th, 2020 09:59 PM |
2005 carb leaking | Firebrick | 1986 - 2007 Ninja 250R Tech Talk | 13 | April 23rd, 2015 03:51 PM |
Carb to Intake rubber boot clap leaking | joecool | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 24th, 2014 08:17 AM |
Leaking Carb- Out of ideas.... | drew13 | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 10th, 2012 04:12 PM |
