Old August 9th, 2020, 05:19 PM   #1
tyhainey
Motorcycle(s): 06 ninja 250
pulsing idle 06 250 ninja
the idle on my bike float up and down at about 1000 rpm pulses what could cause this
tyhainey is offline   Reply With Quote
Old August 9th, 2020, 06:00 PM   #2
Vacuum leak possibly.
Have you made adjustments to the Idle Mixture Screws?
Removing caps - https://faq.ninja250.org/wiki/Removi...re_screw_plugs
Making adjustments - https://faq.ninja250.org/wiki/How_do...dle_mixture%3F
Old August 9th, 2020, 06:36 PM   #3
ducatiman
ducatiman's Avatar
petcock, float system, idle circuit issues....could be multiple, non-obvious stuff going on.
Example...out of spec, high fuel levels (both or 1 carb) don't necessarily spew onto the garage floor, not visible ....therefore possible to go undiagnosed.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old September 1st, 2020, 04:56 AM   #4
Nicosiacustom
Motorcycle(s): Ninja
Im having the same problem on my 06 i have a jet kit installed no vacuum leak didn't have the problem till after the jet kit was installed. Im leaning towards the fuel filter or the air valve for the tank its almost like its not filling the bowl fast enough and the idle will go from 1500 to 500 and back between 1500 and 2000 dont know if yours is the same but if it will help ill let you know if i figure it out.
Nicosiacustom is offline   Reply With Quote
Old September 1st, 2020, 05:40 AM   #5
Were all the jets genuine Keihin parts? I'm not sure about the kit you bought, but all the carb rebuild kits available for the
(1970s) Kawasaki triples use non-Mikuni parts and they all make the carbs unusable. They do make a few bucks for everyone in the supply chain though.
I bet @ducatiman can let us know whether kits for our 250s are usable or not.
Old September 1st, 2020, 06:42 AM   #6
ducatiman
ducatiman's Avatar
So many copycat carb kits on the market currently. Within my service I strive to restore and reuse precise, correct OEM Keihin tuning components (jets, needles, needle jets) wherever possible with the exception of orings, and float valves....the normal consumables which get replaced with new. My chosen stuff tried and true. I avoid any copycat crap.
Of course, in regards to jetting....bigger is not necessarily better, as member @DannoXYZ has documented in detail on this very forum.
Truly clean circuits, careful setup and adjustment usually reward with a fine running 250.
Once you are pulling airbox, playing with exhaust....individual requirements will differ....all bets are off.
Custom Carb Service
Old September 1st, 2020, 10:32 AM   #7
If fuel-flow is not sufficient for idle, bike would not run at all at higher-RPMs.
Did you check valve-clearances? What are they?
Which jet-kit did you install and which jet-sizes?
Really need wideband-O2 datalogs or dyno-testing to tune with jet-kit. Otherwise, there's absolutely zero way you can determine what jetting changes are needed.
Bet if you go back to bone-stock, idle will be perfectly fine.
Last futzed with by DannoXYZ; September 1st, 2020 at 11:55 AM.
Pulsing front brake headshrink 2008 - 2012 Ninja 250R Tech Talk 36 April 18th, 2011 08:51 PM
