View Poll Results: ARE YOU REBUILDING?
NO 2 28.57%
YES 5 71.43%
THINKING ABOUT IT 0 0%
Voters: 7. You may not vote on this poll
Old April 4th, 2021, 03:59 PM   #1
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
Smile Rebuilding my ninja.
Trying to refamiliarize myself with the forum please shoot me a message. Leave a reply. Let me know how your day is going.
JayVapes is offline   Reply With Quote
Old May 1st, 2021, 09:42 AM   #2
JayVapes
JayVapes's Avatar
Ok so I got my fairings off, tank is off and rusted around, everything is off the frame with the exception of the motor trans, as well as wheels and brakes
RIDE IT UNTIL THE WHEELS FALL OFF, THEN BUY NEW WHEELS
Old May 1st, 2021, 11:35 AM   #3
JayVapes
JayVapes's Avatar
I don't know where to start
Old May 4th, 2021, 04:04 PM   #4
Singh2jz
Singh2jz's Avatar
Motorcycle(s): '07 ex250-F/J
haha you can start from anywhere! Just make sure to attach and tape the screws/bolts to their respective pieces to stay organized!! that's if you're not already familiar with what bolts where.
Keep us updated!!
I am currently rebuilding one too lol. trying to do a full ground up refresh but we'll see as it happens.
The Bike | The Truck
Old May 5th, 2021, 08:29 AM   #5
davenay67
davenay67's Avatar
Does the bike start and run? This determines what your next steps are....
Old May 5th, 2021, 03:58 PM   #6
JayVapes
JayVapes's Avatar
I have removed almost everything and I think I want to change the spring/shock. remove the valve covers and have the exhaust restored. I dont know where to start. I appreciate suggestions. it started the last time it had a battery. I want to make sure the cams are all aligned properly and make sure that the rocker arms and valves are all good to work properly. I'm interested in having the starter refurbished... I know nothing of transmissions or chains. all advice is accepted and considered.
Old July 10th, 2021, 02:19 PM   #7
JayVapes
JayVapes's Avatar
quick update, I have removed the oil and the exhaust. I will be ordering new spark plugs, oil and oil filter, brake fluid, and maybe a new shock.
Old July 10th, 2021, 02:22 PM   #8
JayVapes
JayVapes's Avatar
i also had the radiator pressure tested
Old July 10th, 2021, 07:03 PM   #9
Snake
Snake's Avatar
Look forward to see the finished project.
Old September 30th, 2021, 09:50 PM   #10
JayVapes
JayVapes's Avatar
Ok quick update, valve clearance are all checked and at .13mm. took out the starter and cleaned off the gunk. Got new handle bars in and I need to move the controls to the new handle bars but haven't ordered grips. Also I broke a bolt while trying to losent the clutch so that sucked, I may have to order the whole bolt kit I saw on eBay for around 60 dollars. They say they are not "Kawasaki" screws but they had screws specially made to replicate them... (Stainless steel to prevent rust). I ordered some dumb shocks from ebay that didn't fit. I hope the bolts kit fits right. I ordered some CA in order to adhere the cracks in the fairings and I ordered plastifix in order to make a mold of the pointed studs on the side fairings... I don't know what to do about the shock absorber. It came with a single eye hole and as you all know our shocks come with a u style mount for the dogbone
Old September 30th, 2021, 09:54 PM   #11
JayVapes
JayVapes's Avatar
I still haven't installed the oil filter, oil, coolant but I did install the radiator and the fan. Next is to break open the harness casing and check for broken wires loose ends etc.
Old October 1st, 2021, 08:08 AM   #12
you can get replacement shock clevis mounts. Verify dimensions and threading before ordering. Be sure spring is unloaded with spring-compressor before disassembling.
https://www.ebay.com/itm/Motorcycle-...-/362892629966
https://allstarperformance.com/amp/s...cers-all99331/
Old October 1st, 2021, 08:10 AM   #13
coming along nicely!!! Find the 4-way common ground point and solder all the crimped connectors together. They like to corrode over time and cause issues.
Old October 4th, 2021, 04:25 PM   #14
JayVapes
JayVapes's Avatar
Can you suggest a kit for the wiring?
Old October 4th, 2021, 06:45 PM   #15
BonelessSugar
Motorcycle(s): EX250-F x 3, TW200, NPS50
Are you missing sections of your harness? Or do you just need wires and connectors? Need some more info. Probably a good idea to find a wiring diagram for your year while you're at it, multimeter too if you don't have one.
Last futzed with by BonelessSugar; October 4th, 2021 at 11:17 PM.
BonelessSugar is offline   Reply With Quote
Old October 4th, 2021, 11:18 PM   #16
JayVapes
JayVapes's Avatar
i have the complete harness, all my connections are in good working order, I was imagining you had a kit in mind when it came to heat shrink, coupling, soldering iron, maybe even replacement wire
Old October 4th, 2021, 11:37 PM   #17
try this package, seems to have everything you may need.
https://www.amazon.com/dp/B07S61WT16 - soldering kit
https://www.amazon.com/dp/B01AAX64WO - wire assortment
Rebuilding 04 Ninja 250 NinjaBraap 1986 - 2007 Ninja 250R Tech Talk 26 August 4th, 2019 05:37 PM
what to consider when rebuilding an engine? MrAtom General Motorcycling Discussion 15 April 22nd, 2015 09:50 PM
Rebuilding Questions eulark 1986 - 2007 Ninja 250R Tech Talk 171 September 19th, 2013 05:58 PM
1998 Ninja 250 - Rebuilding Carb? anabolicinsider 1986 - 2007 Ninja 250R Tech Talk 24 June 15th, 2012 12:04 PM
Rebuilding a motor... saber63 1986 - 2007 Ninja 250R Tech Talk 3 May 16th, 2011 11:42 AM
