Old May 10th, 2021, 02:19 PM   #1
PaleHorse
Moto Nut
Name: Yes, I have one
Motorcycle(s): Harley Davidson Road King, Yamaha FZ1, 92 Ninja 250, 95 Ninja 250
RPM drops when braking
On my 95 250, when I rock the bike back and forth with the front break pulled, the idle will drop significantly and the bike is close to stalling. A few times, on the street I hit the brakes at a stop light / sign the RPM's dropped and the engine died.
About the bike -
2000 original miles
Bike is bone stock
fuel tank is spotless. No rust
New OEM petcock
Carbs just cleaned and all new jets / components installed
Oil changed and just below the upper mark on sight glass
Battery is new
Any ideas what would cause this?
PaleHorse is offline   Reply With Quote
Old May 10th, 2021, 02:48 PM   #2
My money is on the carbs causing the problem. Maybe float level too high or float valves not closing properly.
I hope you didn't use the any jets from a carb kit. They're not genuine Keihin, and they are not the right sizes. The float needles and seats should be OK though.
Old May 11th, 2021, 05:58 AM   #3
I was thinking carb related as well.
Is it sputtering, but will clear if you rev it up? It does sound like excess fuel could be getting dumped-in and flooding the engine.
Float levels would be something to check.
I agree with TJ - don't use aftermarket "Carb Kit" or "Jet Kit" jets. Many times they are not correct.
Old May 11th, 2021, 06:36 AM   #4
ducatiman
ducatiman's Avatar
suggest subjecting carbs to the "clear tube method", adjusting as necessary.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
RPM Gauge keep on 0 Rpm until i rev works Darksik 2008 - 2012 Ninja 250R Tech Talk 5 April 14th, 2018 05:07 PM
Dead Drops spooph Off-Topic 4 January 29th, 2015 02:00 PM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
2-Drops.com is Now Live! AMMOCAN Off-Topic 7 April 20th, 2012 09:01 PM
Dayton Drops In MaLeK New Members 22 June 7th, 2009 08:41 AM
