July 13th, 2021, 08:54 AM | #1 |
Join Date: Apr 2021 Motorcycle(s): 2007 Ninja 250 Posts: 20
6.5k rpm bog
So I'm chasing problems on 07 ninja 250. The bike idles and runs perfectly up to 5000rpm. Then the throttle is a little less responsive from 5k-7k rpm. At 6.5k rpm it almost wants to die. Then above 7k rpm it is smooth. The problem only appears to happen over 3rd gear. I think it is starving fuel, because I replaced my fuel filter a week ago and the bog went away. It came back though when I was riding 2 days ago. I have one of those eBay Chinese fuel filter and they don't seem to be clogged and they worked fine before but now I'm getting problems. I have gotten a Prime line filter that I will put in and see if that last longer.
Last futzed with by bigBug; July 13th, 2021 at 09:10 AM. Reason: Details |
July 13th, 2021, 11:08 AM | #2 |
A large inline filter can cause problems, and create a low spot in the fuel line that interrupts flow.
The hose from the petcock to the carb isn't long enough for anything except a small mower-style filter. There is a filter designed to go in the carb inlet, and it should be adequate to catch anything that is heading for the carbs. This section may help - https://faq.ninja250.org/wiki/How_do...fuel_filter%3F Check that your tank is clean and rust free also. Make sure the air filter is in good condition, not over-oiled, and the snorkel under the seat is clear. |
July 13th, 2021, 11:18 AM | #3 |
Make sure your stock hidden-in-fuel-line filter isn't still in there and clogged. Its right at the carb inlet. I thought mine had been removed, but sure enough there it was. It had been causing a problem when going to reserve, not letting gasoline get flowing again without stopping, shaking the tank back and forth, etc..
July 13th, 2021, 12:51 PM | #4 |
Its funny that you say that because that is how all the problems started. I had little rust spot in the tank, which clogged my carb twice. So I wanted to fix that and used por15 in the tank and I didn't know it blocks any small holes in the tank. I am not sure what it blocked but there is definitely no pressure build up inside the tank. I rode around with my gas cap open and it made no difference. Also it worked perfectly for a month in a half after that procedure.
July 13th, 2021, 12:55 PM | #5 | |
July 13th, 2021, 01:05 PM | #6 |
July 13th, 2021, 01:28 PM | #7 | |
July 13th, 2021, 01:36 PM | #8 |
I've encountered some rail filters scrunched up an inch or so up into the fuel line....creating flow problems. I stock EX500/ZX6 rail filters as they fit just a bit tighter...and stay put/don't automatically pull out with the hose when removing it.
Your rail filter may even be missing as they are frequently tossed.....but in the case of a midrange bog....I'd be more inclined to think the holes in the emulsion tube may be varnished up some. Pic.....PROOF the final catch rail mesh filters actually work.
Custom Carb Service |
July 13th, 2021, 09:28 PM | #9 |
I got to change the filter and it improved a bit but the problem is still there. The chinese one actually was more of an improvement but it keeps bending. I think it might be because of a low point in the fuel line. I'll try running straight line without any filter when I get a chance. @ducatiman was right I took off the fuel line on the carb side and there was no filter there. One weird thing I found was that the problem goes away if I wide open the throttle and it only stutters when I go thru the rpm or at not wide open throttle. I'll try to post pictures
Last futzed with by bigBug; July 14th, 2021 at 09:06 AM. |
July 14th, 2021, 05:20 AM | #10 | |
July 14th, 2021, 09:17 AM | #11 | |
Here are some pictures. The removed filter and the new one that I put on.
July 14th, 2021, 10:15 AM | #12 |
A personal suggestion, cut to the chase.... pull/clean the carbs, install a mesh rail filter using full length hose (sans the inline filter)
Note the petcock (just a few inches upstream) utilizes mesh filters as well. Provided those petcock mesh filters are present, the inline filter would be overkill (provided you are using the final rail filter). As I previously posted, mesh filters work fine, all thats needed as a preventative to solid crap infiltrating float needles/seats. However....varnish is a whole nother ball game.....so deal with the carbs on that level.
July 14th, 2021, 11:14 AM | #13 |
I'm just not a fan of the aftermarket inline fuel filters on the Ninja.
If you look at the fuel line above your filter, you will see it's starting to buckle - which may restrict flow. My suggestion would be to make sure the tank is clean, check the petcock filters to make sure they are clean and in good condition, install the OEM mesh filter inside the carb inlet, and replace the fuel line. If it's still running poorly, the carbs need to come off and be properly cleaned, rebuilt, and adjusted. |
July 14th, 2021, 12:44 PM | #14 |
That's why I put the filters in. I was riding and was pretty far from home. little rust flakes from the tank got in the needle passageway which kept overflowing the carburetor, it was a long way back home pushing the bike until I got someone to bring their truck. Funtimes. I have since fixed the rust in the tank. I'll try running a straight line and see if that solves it. I'll also see if I could get the mesh rail filter. If not carbs will next.
July 14th, 2021, 12:52 PM | #15 |
I'd still recommend a EX500/ZX6 rail filter (final catch at fuel entry point to carb) in conjunction with straight hose run. Got them in stock, if you opt to install. An insurance policy, of sorts.
July 14th, 2021, 12:55 PM | #16 | |
July 14th, 2021, 01:10 PM | #17 |
For what it's worth, I've always run a small plastic filter like yours in my line, and have had no problems from doing it.
July 15th, 2021, 08:21 AM | #18 | |
Thanks guys for all your input. Until next problem. |
July 27th, 2021, 12:54 AM | #19 |
Retired motorcycle Mc.
Join Date: Jul 2021 Motorcycle(s): 2012 Kawasaki Ninja 250R, 2021 CSC TT250, 1977 Triumph Bonneville 750cc,2001 Honda XR650L. Posts: A lot.
Aurgh ! you don't want to flip around the fuel filter and use it again !
a fuel filter catches junk in one direction and will release that junk in the other direction ! and you really can't clean them enough to prevent the junk from infecting the carbs. ( I have tried high pressure air in the opposite direction but the junk is still lodged in there...) just replace an old inline filter it's easier and better... .... Sounds like emulsifier tubes to me as well, I think those carbs need to be dipped for a long time ! I know this is an old thread but I am interested if he ever got it running right again ! Bob....
Its too late when you've gone too far ! |
July 27th, 2021, 06:14 AM | #20 | |
July 27th, 2021, 06:34 AM | #21 |
LOL yah I HOPE so ! HAHAHAH
Bob.....
February 2nd, 2022, 02:43 PM | #22 |
Final update: It ended up being the carburetor slides
After replacing the fuel lines, the bog came back, so I knew something was wrong with the carburetor. Upon taking off the carburetor and disassembling it. It ended up being the slides, they were just covered in motor oil from the air filter and the air filter was full of fuel. Cleaned up the air filter and soaked it again in oil and cleaned the carb and everything is running smoothly!!!
February 2nd, 2022, 03:05 PM | #23 |
Good work!
RPM Gauge keep on 0 Rpm until i rev works | Darksik | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 14th, 2018 05:07 PM |
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
Low and mid range bog. | Lemonfresh | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 16th, 2014 12:05 PM |
Advice Needed: Engine Bog @ ~6k 1/4 Throttle | MaxxVE | 1986 - 2007 Ninja 250R Tech Talk | 7 | March 16th, 2014 05:10 PM |
Was that a bog? | tsiratiug | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 15th, 2011 12:25 PM |
