Old March 11th, 2022, 04:12 AM   #1
BloodFX
Motorcycle(s): kawasaki eliminator 250 d4
El250 will no longer start
Hi, suddenly today my el250 will no longer start, was working perfectly yesterday, I noticed yesterday there was alot of petrol coming out of left carb overflow.
Today it sort of started but was only firing on right cylinder, then petrol started coming out of airbox and since then it won't start at all, I used low pressure air on the carb inlet and the carb no longer spills fuel out of overflow, but it still will not start.
I also noticed I have been having problems with the key ignition sometimes when I turn the bike on the bike lights do not come on, but after turning on and off a few times they come on, might be related to the problem?
BloodFX is offline   Reply With Quote
Old March 11th, 2022, 06:48 AM   #2
ducatiman
ducatiman's Avatar
electrical and high fuel level= totally separate problems. I see a carb pull in your future.
you posted "a lot of petrol coming out of left carb overflow".
please better describe precise location of left carb overflow?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old March 11th, 2022, 06:58 AM   #3
BloodFX
Bottom of carb.
Old March 11th, 2022, 07:56 AM   #4
ducatiman
ducatiman's Avatar
hmm, overflow at bottom of carb? the drain bolt is sufficiently tight? Or is fuel actually migrating from above somewhere?
Custom Carb Service
Old March 11th, 2022, 08:31 AM   #5
thedrewski86
thedrewski86's Avatar
My money would be on stuck float in the left carb. In my experience, left carbs stick much more than right ones, especially on a cruiser like the Eliminator which doesn't have a centerstand. Leaned over on the side the way they are wreaks havoc on that low carb. Personally, I would send the set off to the dude that services carbs here
As far as the electrical issue, dig into the wiring and start cleaning. Being that your ignition wiring is affected, I would look for rubbing around the headstock and any place where things could get pinched. Somewhere some insulation is getting worn thin, I would think.
Don't think, look!
Old March 11th, 2022, 09:29 AM   #6
Petrol coming out of airbox is major problem! Routing of hoses may be mixed up. Overrlow hose should be draining straight to ground near centre of bike. Need to pull carbs for complete overhaul.
As for lights not coming on, might be worn-out ign-switch. Measure voltage on output wires at switch itself. If power isn't coming out at source, it's not gonna make it downstream to bulbs.
Old March 11th, 2022, 11:25 AM   #7
ducatiman
ducatiman's Avatar
complete overhaul.....not limited to simple jet cleaning....using all new float valves and bowl orings ...clean the float system as well, finish with adjusting and wet testing PRIOR to reassembly on bike.
Custom Carb Service
Old March 12th, 2022, 04:39 AM   #8
BloodFX
I noticed no fuel would flow into carbs, but when I pulled the fuel pipe off the carb, then fuel would flow out?
Guess your right carbs off time.
Old March 12th, 2022, 07:16 AM   #9
ducatiman
ducatiman's Avatar
If need be, I'm at your service. I do these routinely with success.
Custom Carb Service
Old March 16th, 2022, 12:10 PM   #10
BloodFX
Turns out internal tank filters are blocked and 1 has disintegrated, the reserve filter was toast, installed new 1's and found a bit of tank paint lacquer jammed in the float valve.
Think I will replace fuel tap to as thats 27 years old also and flushed the tank out to, runs fine now. Thanks yall.
Last futzed with by BloodFX; March 16th, 2022 at 02:23 PM.
Old March 16th, 2022, 12:32 PM   #11
ducatiman
ducatiman's Avatar
Turns out internal tank filters are blocked and 1 has disintegrated, the reserve filter was toast. [B]installed new 1's[/B] and found a bit of tank paint lacquer jammed in the float valve.
if you are referring to petcock mesh filters....just where did you get new ones?
Custom Carb Service
Old March 16th, 2022, 02:21 PM   #12
BloodFX
Here: https://www.fowlersparts.co.uk/parts...e-gb/fuel-tank
Old March 16th, 2022, 03:21 PM   #13
ducatiman
ducatiman's Avatar
ah, UK model
you actually replaced filter assemblies, as separate filter (only) are NA.
Custom Carb Service
Last futzed with by ducatiman; March 17th, 2022 at 06:54 AM.
Adding a analogue rpm gauge to an el250 BloodFX 1986 - 2007 Ninja 250R Tech Talk 3 April 6th, 2021 01:25 AM
el250 coolant hose routing BloodFX 1986 - 2007 Ninja 250R Tech Talk 1 April 27th, 2020 03:45 AM
El250 engine swap BloodFX General Motorcycling Discussion 12 January 1st, 2019 10:18 AM
El250 BloodFX General Motorcycling Discussion 17 December 20th, 2018 07:04 AM
Oil & Temp light staying on longer at start-up headshrink 2008 - 2012 Ninja 250R Tech Talk 5 June 19th, 2009 01:24 AM
