Old May 28th, 2022, 07:51 PM   #1
blackiredi
Motorcycle(s): '10 Ninja 250R (track), '20 Street Triple 765 (street), '12 CRF150R SM (racing)
Fueling help
Hi All,
I just picked up an '08 250R with OEM carbs and an off brand aftermarket carbon can. I am trying to get it prepped for race weekend next week. It was bogging bad. So I rebuilt the carbs, replaced the plugs (man the bike was run lean) and have backed out the mix screws 3 full turns.
It now revs out really strong- no bog. But if I rev it hard and hold throttle at say 9000 rpm it dies off to 6000 or so as I holding the throttle in the same place. And the exhaust pops a lot.
My guess is it is still too lean, but my question is should I continue to back out the mixture screws or shim the needles? It seems like shimming the needles would be the right thing since it would give more fuel through the whole rev range?
Any help is appreciated.
Thanks
blackiredi is offline   Reply With Quote
Old May 29th, 2022, 12:37 PM   #2
Might be lean because carbs still aren't factory fresh clean. Bike ran perfectly fine when leaving showroom floor and revved to redline without any problems. When you get carbs back to factory-fresh clean, it'll run like that again. Some tips:
- complete disassembly down to every last nut, bolt and individual component.
- scrub everything with PEA-based fuel-system cleaner. Spray "carb cleaners" no longer work due to removal of chlorinated compounds. don't forget secret hidden passages
http://n4mwd.blogspot.com/2013/10/se...-passages.html
- poke out all bleed-holes in carb-venturi, emulsion-tubes and pilot jet with matching size soft copper wire
-ultrasonic soak and micro-soda blast everything
- replace all rubbers when re-asembling: float-valves, fuel-rail O-rings, pilot-screw O-rings, float-bowl seals, even carb-diaphragms if needed
- set float-levels & wet-test
- sync carbs in bench and on bike
do search on here for "clean carbs ducatiman" for guides and photos
Old May 29th, 2022, 02:16 PM   #3
blackiredi
Cool. Thanks. I thought I got in there pretty deep and replaced almost everything, but didn't get as deep as your pic shows. I'm going to be good at pulling this carb when this is all done.
Old May 29th, 2022, 04:04 PM   #4
Don't worry, many expert mechanics have had to pull carbs 4-5x for ever deeper cleaning before they were factory-fresh clean! One guy had to pull them 10 TIMES!! Might as well do complete restoration job 1st time around. I missed 1st race of my 2nd season because I thought I had "cleaned carbs" sufficiently, nope... Luckily, I had 2nd set of carbs professionally refurbished by ducatiman. Swapped those in and was able to do my remaining races that day and next.
Parts that you can replace are only 5% of job. Needs to scrub entire fuel flow-path from beginning to end. Some of those hidden secret passages have 90-degree bends you can't get scrub-brush through. Thus ultrasonic cleaner. Disassemble emulsion tubes pilot-jets from carbs and poke out all bleed holes with soft copper-wire. Dried petrol gets pushed out like little grains of sand. Your model has solid emulsion tube, but should still be scrubbed out inside.
Don't forget petcock. If carbs are dirty, petcock most likely also. Replace screens, seals. Make sure petcock flows sufficiently, otherwise brand-new factory-fresh carbs still won't work.
Also replace internal filtre. Many are wadded up from being installed backwards.
Best to replace with inline filtre that can be inspected easily. Got pack/10 for cheap from off-road shoppe.
Old May 29th, 2022, 07:47 PM   #5
blackiredi
Son of a carb. 10 times? I've got the inline filter already. Will add checking the petcock to the list. I am suspicious of it. I went ahead and did the needle shim anyway because the plugs were just about burned away.
Thanks for the info!
Old May 30th, 2022, 02:37 PM   #6
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Motorcycle(s): '11 CBR250R, '22 CFMOTO 300NK
Never did a carb cleaning that was 100% without a minimum of 3 removals/cleanings. Blessed be those with fuel injection.
jcgss77 is offline   Reply With Quote
Old May 30th, 2022, 03:15 PM   #7
blackiredi
Yeah, when I upgraded my CRF I went for the '10 just for FI. I guess I never learn.
Old May 30th, 2022, 06:10 PM   #8
blackiredi
It s all apart and being cleaned. Petcock passed the vacuum test. The question now is how do you know if the diaphragms are shot?
Old May 30th, 2022, 06:37 PM   #9
ducatiman
ducatiman's Avatar
"The question now is how do you know if the diaphragms are shot?"
*any* holes, rips, tears, folds, etc. are no good, requiring automatic replacement.
When reassembled, a *slight* blast of compressed air at the upper intake openings (see pic) should raise each slide. *Go easy with air blasts.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old May 30th, 2022, 08:45 PM   #10
blackiredi
Thank you! I had one with a small tear in the lip where it seats and the other has what seems like a "bubble" in the cone. Like it's stretched out in one spot- kind of worldly. Ordered new rubbers.
Also took off the Kleen Air system and ordered a block off plate. About ready to rip out that airbox too. But I don't want to have to order new jets. If I go to pods will needle shimming be enough do you think?
Thanks again.
Old May 30th, 2022, 09:14 PM   #11
Why pods? Nothing but trouble. Search here for "pod filters" and all you will find are people asking for stock airbox to rip out their pods. Causes mid-range stumblings that cannot be tuned-out. When hitting cross-winds, bike will stumble and almost die. Way, way too many side-effects for zero gains.
Old May 30th, 2022, 09:45 PM   #12
blackiredi
Interesting. I was seeing a bunch of pods and people hating on the airbox. I don't have a problem with it other than I am pulling the carb a lot and its in the way. Is it going to be a problem that I ripped the snorkel off?
Old May 30th, 2022, 10:28 PM   #13
Fine-tune technique and you can pull carbs in under 10-min. I have write-up somewhere, might make DIY post. Maybe I update with video. I do it twice a day @ track, 4x in one weekend, no problems with airbox installed.
Removing snorkel's one way to increase power. Worth about +1 bhp! Can't believe AFM bans removing it in stock class!
Last futzed with by DannoXYZ; May 31st, 2022 at 09:30 AM.
Old May 31st, 2022, 08:18 AM   #14
blackiredi
I remember seeing your 10min thread. I think maybe in the DIY list? I'll check it out.
Old June 1st, 2022, 07:15 PM   #15
blackiredi
Update: Everything has been cleaned in all ways except for soda blast- cuz I don't have that. I ordered new diaphragms and slides and a new air cut off diaphragm- the old one looks all wavy.
Since I am determined to figure this out or destroy it in the process (then ducatiman rescue as a last resort) I need more help please.
Question: Is the assembly of the air cut off valve in correct order and I seem to have a spring and a plastic washer I don't know what to do with- diagrams are not helping. I used the plastic washer with the flange under the throttle nut and two like this one are under the choke slide screws- this one needs a home. And I have the choke return spring in place. Pictures attached.
Really appreciate all the help so far. This is my first dual carb and it turns out it's twice as much to keep track of.
Old June 2nd, 2022, 04:33 AM   #16
ducatiman
ducatiman's Avatar
you seem to be missing the tiny oring/seal located in the cutaway between sections i've pictured.
The white seal in your pic is 1 of 4, located over/under 2 mount points of choke lever and your spring is the choke return spring or decel valve spring?
Difficult to discern the length of the spring in your pic of decel valve.....? May be incorrect....length necessary to better judge it.
Custom Carb Service
Old June 2nd, 2022, 05:08 PM   #17
blackiredi
O-ring! Thank you!
Here are pics of the springs with measurement. The shorter one was what I had in the air valve in the previous post, the longer one is the loose one in my previous post. The other pic is of the two with the carb and choke slide bring installed for reference. Ducatiman, your pics look like you have the longer of the two in the air valve? I am thinking the shorter one may be part no. 92081B but in the parts diagram it is not clear where it goes in the butterfly shaft assembly- this could be totally wrong.
Thanks again for the guidance.
Old June 2nd, 2022, 05:27 PM   #18
ducatiman
ducatiman's Avatar
the longer of your 2 springs is, in fact, the decel valve spring. The shorter one goes between the 2 carbs, separating the throttle shafts.
Custom Carb Service
Old June 2nd, 2022, 05:29 PM   #19
blackiredi
Awesome! Thank you!
Old June 3rd, 2022, 05:45 AM   #20
ducatiman
ducatiman's Avatar
may want to assure your needles are in correct orientation....
N9VU in LH CARB, N9VW in RH
Custom Carb Service
Last futzed with by ducatiman; June 3rd, 2022 at 09:29 AM.
Old June 3rd, 2022, 09:25 AM   #21
ducatiman
ducatiman's Avatar
curiously enough....i've found in the new-gen set I'm currently refurbing that exact scenario! Somebody previous had them reversed...made a big boo-boo.
Its a fairly common error I've encountered prior.
Custom Carb Service
Old June 3rd, 2022, 09:27 AM   #22
blackiredi
Are these the needles themselves or the collar? I can't find what those numbers mean? The needles and collars look the same to me......
Old June 3rd, 2022, 09:35 AM   #23
ducatiman
ducatiman's Avatar
the actual jet needles are marked near the top and differ left and right. No idea precisely what the numbers mean, though. Prior to any shimming, I'd suggest confirming correct orientation.
Custom Carb Service
Old June 3rd, 2022, 06:24 PM   #24
blackiredi
Thank you again! These are my needle choices. The silver ones are what was in the bike and they seem to be the first gen shape? But this is an '08. The gold ones are new and seem to be the correct shape, but they are unmarked. The silver ones have N9VU and N9VV. SO, it looks like I need to go with the old needles seeing as how the new ones aren't marked. I had to use my phone's extreme zoom and wear my glasses to even come close to reading those markings. Never would have noticed if you hadn't said something.
Old June 4th, 2022, 05:51 AM   #25
ducatiman
ducatiman's Avatar
N9VU in left carb, N9VW in right carb .....verify and confirm!
unless aftermarket, part # markings will appear on the thick area beneath head
Custom Carb Service
Old June 5th, 2022, 06:06 PM   #26
blackiredi
EDIT: found where it goes. Finally found a video where it was clearly there behind the synch adjust screw. ONWARD!
OK. Race weekend. No carb work to date other than getting parts in the mail.
I got an email that said DannoXYZ commented on the needles even though I can't see it here. Thank you for that.
SO, my new air valve (deceleration) diaphragm came in the mail. Turns out the spring that cam with it is the same size as the one the previous owner had between the choke levers. (You can see how it is all weird in my previous post. I compared it to Ducatiman's air valve picture and it the same. SO, I have three springs.
One is the longest- seems to be decelerations air valve spring.
Then there are the two I posted earlier. I assume the longest of those two is the spring between the chokes. It seems to fit well there. Then there is the shortest one. It is not for the needles and it is not for the synch screw.
"The shorter one goes between the 2 carbs, separating the throttle shafts." Where is this exactly? I don't see another external spring on any pictures I can find.
I am hopeful the wrong spring being in the deceleration valve is the root of my problems once this is all back together.
Old June 6th, 2022, 04:57 AM   #27
ducatiman
ducatiman's Avatar
ok?
Custom Carb Service
Old June 6th, 2022, 09:07 AM   #28
blackiredi
Yep! That's the one. Thanks! I don't know why I didn't see it before.
The two spring here are the new air valve and the one that was originally between the chokes
Whoever worked on this before obviously didn't join ninjette.org
Old June 6th, 2022, 05:27 PM   #29
blackiredi
Success! Winds out strong. No bogging. No midrange loss (adjusted mix screws 2 3/4 out, added two 3mm washer shims- also removed Kleen air and installed block off plate.)
Things learned: clean means clean not half clean. Don't mix up your springs. And, if you buy a used bike never trust the "work" that was previously done to it.
Thanks for all the help. Seriously couldn't have done it without you Ducatiman and DannoXYZ. Really appreciated.
Old June 23rd, 2022, 11:24 PM   #30
blackiredi
Workin' good now! Thanks again!
Old July 3rd, 2022, 04:19 PM   #31
jcgss77
jcgss77's Avatar
Newgen 250's look great in white, glad you got that carb done.
Old July 10th, 2022, 05:06 PM   #32
lordhelemt
Motorcycle(s): A few
I picked up a non-running 08 Ninja 250 over the weekend. Guy claimed it ran well but had been sitting. Pulled the carb and it looked like someone tried to clean it (meaning they sprayed carb cleaner on it) but it needed a real clean. I broke most of it down and ran it through my ultrasonic cleaner and it is clean now, but I can't get the bike to start.
I ran across this thread and saw that someone mentioned 2 different needles. I so I guess I have to pull the carb again to see if they are placed correctly. Is there anything else sided in this carb? I don't have a FSM (yet) and I wanted to get moving on this project but I guess i'm paying the price now.
lordhelemt is offline   Reply With Quote
Old July 11th, 2022, 01:48 AM   #33
Did you scrub out secret hidden passages?
Poke out all bleed holes with soft copper wire (especially ones in carb venturi)?
Ultrasonic soak is only to clean up chads and scruff left over from these processes.
Micro soda-blast everything?
ultrasonic does very little without these other steps
You'll also need to replace all rubbers: Fuel-rail O-rings, pilot-screw O-rings, float valves, float bowl seals.
Then adjust float-level with wet-test
ultrasonic is just 1st 5% of getting these carbs working...
Many experts who know these bikes like back of their hands have had to pull carbs 4-5x for ever deeper cleaning before they got them factory-fresh clean. One guy had to pull his carbs 10x!!!
Last futzed with by DannoXYZ; July 16th, 2022 at 08:51 PM.
Old July 11th, 2022, 06:13 AM   #34
lordhelemt
I did not soda blast the carb but it is all cleaned out. Passages are all clear (even the tiny ones on the choke circuit).
I did notice 2 things after reading this thread. First I didn't realize there were 2 different needles, second the needle seal/collars were in the bottom of my ultrasonic tank (didn't realize these were not pressed in). Will order new rubber orings and get this back together with the collars and needles in the correct position.
Old July 11th, 2022, 06:13 PM   #35
blackiredi
On my “rebuilt” carb the needles were also the wrong gen. Probably worth double checking while you have the carb out. Good luck.
First Time Ninja Started, But Has Fueling Issues! Speedy3 2008 - 2012 Ninja 250R Tech Talk 6 February 11th, 2017 05:46 PM
Strange Fueling after Carb Clean ncarota 1986 - 2007 Ninja 250R Tech Talk 21 January 30th, 2015 01:50 PM
Ninjette is having fueling issues AncientTV 1986 - 2007 Ninja 250R Tech Talk 29 April 10th, 2011 02:58 PM
Video Precaution about Fueling Up islanderman7 Videos 2 December 24th, 2008 11:50 PM
