Old November 25th, 2023, 02:59 PM   #1
atxninjette03
My 09' 250 is running rich, right? What can I do.
I'm like 90% sure my bike is running rich but I'm not finding a lot of help online. When I start the bike it doesn't need choke even when super cold, and if I give it more than 50% choke it instantly dies and wont start unless i revert it. The bike smells super rich and last time I checked the plugs they were pretty dark. Mileage is nothing to write home about either (43).
The bike is mostly stock other than a Devil exhaust put on by the previous owner and an extra front tooth I added. I have already leaned out the idle mixture screws to about half from default. Not sure if I should reduce it more there, or if the next step is to buy new main jets?
If the next step is indeed jets I'd love to be pointed in the right direction as to what size and where to buy from.
atxninjette03 is offline   Reply With Quote
Old November 25th, 2023, 03:12 PM   #2
ducatiman
ducatiman's Avatar
https://www.ninjette.org/forums/showthread.php?t=399698
QUICKEST, EASEST WAY, a carb swap with refurbs
contact me via PM if interested
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old November 25th, 2023, 03:44 PM   #3
atxninjette03
Ah the legend himself. That actually is a tempting offer but probably as a last resort as I'm trying to spend as little as possible. Money that is, not time.
Old November 25th, 2023, 04:05 PM   #4
ducatiman
ducatiman's Avatar
fully understood. If things somehow change, just let me know.
Custom Carb Service
Old November 25th, 2023, 04:14 PM   #5
ducatiman
ducatiman's Avatar
i'll go out on a limb.....if your bike is running rich, i'd surmise the float valve to seat "interface" is weak....varnished, not fully sealing. In reality, not simple, but quite a tricky situation to correct. A full "clean and reset" is called for.
To begin with...do you own ultrasonic? have compressed air? a place to park the bike and work indoors? Have appropriate tools? Capable and willing?
Custom Carb Service
Old November 26th, 2023, 04:42 PM   #6
atxninjette03
The float valve has already been replaced relatively recently with a brand new one. I tested it thoroughly and I'd be surprised if it's not sealing, but is still a possibility.
I do have everything else other than an ultrasonic cleaner though.
Old November 26th, 2023, 05:03 PM   #7
ducatiman
ducatiman's Avatar
a "wet test" would reveal either integrity or leakage of float valves and establish the float fuel level....high or low, sealing or not.
THIS (see pic) is float level you are after, note a gravity fed fuel source needed to complete this test
Custom Carb Service
Running too rich.. Fixit 1986 - 2007 Ninja 250R Tech Talk 31 January 27th, 2020 05:41 PM
Running very slightly rich Karman 2008 - 2012 Ninja 250R Tech Talk 18 December 1st, 2018 08:33 AM
am i running rich? willtrimble 1986 - 2007 Ninja 250R Tech Talk 19 April 18th, 2014 01:20 PM
Running rich, any help? hillbilly86 General Motorcycling Discussion 15 June 5th, 2013 05:32 AM
Running rich? SabreValkyrn 1986 - 2007 Ninja 250R Tech Talk 4 November 15th, 2012 08:36 AM
