Old March 24th, 2024, 03:17 PM   #1
unionjack
Motorcycle(s): ninja ex250f
Exclamation carbs cleaned, runs but only starts with starter fluid
to preface this post I bought this bike with it not being able to rev past around 5k found it had to do with a vacuum line not being hooked up on the carburetor maintenance I've done so far includes new spark plugs, oil change, and carb cleaned with adjustment to the mixture screw as well as cleaning out my gas tank, my new leads for things to check is going to be a rebuild with an all balls racing rebuild kit and replacing the fuel and vacuum lines maybe along with a new petcock the bike runs and drives great and will even start first try when warm but starting it cold requires 20 minutes of cranking and starter fluid
thoughts on things to look for or suggestions?
unionjack is offline   Reply With Quote
Old March 24th, 2024, 07:49 PM   #2
I think you're saying you're planning to rebuild the carbs with a kit. You should talk to @ducatiman here before doing that. He has worked wonders with the carbs of many of us here. He knows his stuff and if you need his help, his prices are very reasonable.
These carburetors run very well stock, when truly clean and in good condition. There's no reason to rejet or otherwise try to improve them.
This page may be helpful too: https://n4mwd.blogspot.com/2013/10/s...-passages.html
Old March 25th, 2024, 11:17 AM   #3
unionjack
that link is actually EXTREMELY helpful i didnt see those initially thank you
Old March 25th, 2024, 02:26 PM   #4
ducatiman
ducatiman's Avatar
IMHO "kit" parts are totally not necessary. Original jetting components can be cleaned/reused (related before/after pics provided)
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Carbs cleaned - Diaphragm ripped - Options? DanilloZ28 1986 - 2007 Ninja 250R Tech Talk 2 March 27th, 2019 08:08 AM
Carbs cleaned - Diaphragm ripped - Options? DanilloZ28 1986 - 2007 Ninja 250R Tech Talk 0 March 26th, 2019 01:55 PM
Carbs cleaned twice. But still dead on throttle Cww125 1986 - 2007 Ninja 250R Tech Talk 6 May 31st, 2016 09:33 PM
What acceleration? carbs cleaned MrSavvy 2008 - 2012 Ninja 250R Tech Talk 25 April 12th, 2013 01:47 AM
HELP! Cleaned carbs, fixed ninja, now broken again!! synapsekiller17 2008 - 2012 Ninja 250R Tech Talk 19 November 18th, 2010 11:22 AM
