May 18th, 2024, 08:05 PM | #1 |
Join Date: Jul 2022 Motorcycle(s): 2006 EX250F Posts: 10
High and Hanging Idle
After about 7 months of sitting around, I finally built up the courage to put some gas in my bike and see how it started. To my surprise (and after a lot of cranking) it finally shot to life and could sustain itself at idle.
While that's all great, I'm having an issue where the lowest I can get it to idle is around 1800 to 2100 RPM. My idle screw is no longer in contact with the throttle body (idk the technical term for that little springy guy on the carbs) and even then I'm still running high. I've also noticed after revving up the engine, the idle will slowly drop and tend to stick around 5 or 6k. I thought it might be a throttle cable issue, but the cables feel loose when I mess with the throttle. I was thinking it could be a mixture screw issue, but I'm not sure if I should increase or decrease the fuel ratio. I've got many more issues with this beauty, but I figured this might be something the gurus have seen before. I'd appreciate any advice |
May 19th, 2024, 04:50 AM | #2 |
synch issue, IMHO
May 19th, 2024, 06:18 AM | #3 |
After looking into what ducatiman suggested, another possibility is air leaks between the carburetors and engine.
May 19th, 2024, 11:21 AM | #4 |
certainly could be a cause for synch issues
May 30th, 2024, 08:34 PM | #5 |
Thank you for the advice - I haven't gotten the bike running well enough to do a proper vacuum sync between carbs. I can putt around on it, but after taking a lap of my apartment complex the bike tends to idle down and die. It'll come back if I give it time before trying to restart it.
However, I did just pull my carbs off and checked them with a sewing needle. The right butterfly valve is slightly more open (barely even noticeable) than the left. I'll keep screwing around with it, but for some additional context, I'm around 2,000ft above sea level, have a muzzy exhaust, and threw on some cheap pod filters. It's definitely the best my bike has ever run, but it still isn't road worthy. |
Yesterday, 05:36 AM | #6 |
In case you haven't found it, there's a black idle speed adjustment knob on the left side near the carbs.
Valves that need adjustment can cause a guy to fight carb problems forever. Pod filters can cause carb tuning headaches. If the starting enrichers aren't fully closing they'll cause an overly rich idle so it stalls when the engine is warm. |
Slight hanging idle question. | Fatherof2 | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 18th, 2022 07:25 AM |
Hanging idle and dies with throttle? | gitter | 2008 - 2012 Ninja 250R Tech Talk | 30 | November 9th, 2017 08:32 AM |
Idle High, Adjuster All the Way Down | Speedy3 | 2013 - 2017 Ninja 300 General Discussion | 2 | May 22nd, 2017 08:48 AM |
Idle - too high | ninja_sleeper | 2008 - 2012 Ninja 250R Tech Talk | 26 | August 30th, 2011 06:11 PM |
Hanging Idle | ak_907_ak | 2008 - 2012 Ninja 250R Tech Talk | 33 | June 14th, 2009 08:31 PM |
