Old August 15th, 2010, 01:45 PM   #1
karlosdajackal
karlosdajackal's Avatar
Motorcycle(s): Ninja 250R Fuel Injected Model 2009
Wiring things to turn on/off with the key
Ok so i've been under the seat a few times, and wired up an alarm, a mini-usb and a lighter socket. However all these things go straight to the battery. The alarm obviously needs too, the mini-usb is clever enough not to draw current when its detached so no big deal as i usually take my usb devices with me. The lighter socket can drain my battery in 4 hours if i forget to unplug it and I will as its under the passenger seat.
I would like to wire up the lighter to turn on and off with the key. I have my gps on a ram mount/waterproof case. It will turn on and resume itself when it gets power and turn off itself when the power disconnects, so basically if i get the socket to turn on and off with the key I won't have to remove my gps out of its case once in a whole days worth of riding. usb is not an option on the gps as first the socket is kinda loose and 2nd it would stick out the side of the waterproof case making it not waterproof. Also I'd have to open the case all the time to interact with the sat nav, which is no fun when it rains.
So my question is where do i start
I already have the ground wire hooked up for the lighter. So I only need to relocate the positive wire which has an inline fuse already. Where do i relocate it to? I can see the 3 relay plugs on top of the battery and a bunch of wires coming out of each of them. I can see the terminals on the battery and I can see the fuse box.
If needs be I can cut wires and solder. I'm willing to photo/video the whole exercise too and put up a DIY if it works out and I get some good advice (pay it forward as they say )
My vlogs on Youtube are here
karlosdajackal is offline   Reply With Quote
Old August 15th, 2010, 08:37 PM   #2
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
Tap into the power line running into the ignition. That's what I did with my temp gauge.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old August 15th, 2010, 11:48 PM   #3
karlosdajackal
Cool, what does it look like and where is it?
Is that the main red wire going to a 30A fuse or is it one of the wires on the relays? Don't suppose you have a pic of where you hooked up the temp gauge wire? I'll go look at the DIY's now in case its in there.
Old August 15th, 2010, 11:53 PM   #4
gogoKawi
gogoKawi's Avatar
Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000
I use the wire that runs to the license plate light for just about everything. Since i have the fender eliminator, the light wasn't used anyways. The line is only active when the bike is on.
gogoKawi is offline   Reply With Quote
Old August 16th, 2010, 12:10 AM   #5
karlosdajackal
Cool, and I know that will work. But my concern is the extra current draw on that circuit. My cigarette lighter powering my sat-nav will draw 2amps and the charger is fused at 2.5amp. The cigarette socket is fused at 10amps.
Do we know what the tail light is fused up to? And how much overhead is available? I might end up doing this but I wonder is there an earlier point or source available. Thanks.
Old August 16th, 2010, 04:28 AM   #6
g21-30
g21-30's Avatar
Originally Posted by karlosdajackal View Post
Is that the main red wire going to a 30A fuse or is it one of the wires on the relays? I'll go look at the DIY's now in case its in there.
Have you looked at the DIYs, yet? If you did, you would have seen this one:
http://www.ninjette.org/forums/showthread.php?t=31087
Do you have a service manual? If not, you definitely need a VOM, in order to determine what wires are hot or not and when they are.
The two connectors on top of the battery are NOT relays, if that's what you're talking about splicing into.
Old August 16th, 2010, 05:28 AM   #7
karlosdajackal
3 connectors on top of the battery (FI model). What are they?
Ok I seen that link i don't see how it helps me. I don't know the Watts consumed by whatever I plug into my cigarette lighter. All i know is that the device that plugs into it says it 2000mA on it (2 amps) and inside of it there is a 2.5A fuse. On the positive wire I have a 10amp fuse.
Maybe its obvious to you, but its not to me. Are you saying I can piggy back onto say the tail light (we know that's hot with the key right) without blowing any fuse or would we need to figure out what is plugged into the socket first? If that is the case that we could piggy back that wire and job done, although with potential to overload or blow the fuse for the tail light.
How about having it switched with the ignition but not piggy backed onto another circuit?
Old August 16th, 2010, 07:41 AM   #8
karlosdajackal
ok so if i get a 4 pin 30A relay in halfords, can i put my socket on that with a 10amp fuse, and use the power from the tail light to switch the relay on and off?
Is it that simple?
Old August 16th, 2010, 09:20 AM   #9
g21-30
g21-30's Avatar
That will work.
Old August 16th, 2010, 04:41 PM   #10
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Is it that simple?
That will work perfectly, you will be able to draw as much current as the fuse and that wiring will take (not depending on the tail light wiring) I done this exact same setup, except I tapped into the lowbeam headlight for the relay (I had HIDs, so the socket was easily accessible) to run LEDs and heated hand grips
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old August 16th, 2010, 11:49 PM   #11
karlosdajackal
Cool, i have an R+G tail tidy done, and I used screw in connector blocks for the 2 wires I had to cut for the plate light, so I can easily tap into them.
Wiring a DIODE for 4 L.E.D turn signals AnarchoMoltov 2008 - 2012 Ninja 250R Tech Talk 126 November 9th, 2021 12:13 PM
Need wiring help for new turn signals Insane Pie 2008 - 2012 Ninja 250R Tech Talk 15 May 24th, 2014 02:26 PM
My only key is damaged and is hard to turn Floki 2008 - 2012 Ninja 250R Tech Talk 21 February 14th, 2014 04:59 PM
wiring for flush mount front turn signals for 07 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 October 4th, 2013 01:35 PM
WTB: Ninja 250 turn signal wiring CGNY87 Items Wanted 10 January 22nd, 2010 01:32 AM
