May 1st, 2011, 05:07 PM | #1 |
certified newbie
Join Date: Apr 2010 Motorcycle(s): 08 ninja 250r blue Posts: 127
problem with ignition?
i am starting to notice that my engine isnt starting at the first push of the button. its now taking 2-3 pushes to get the engine to start up. also my oil and temp light stays on for 10-15 seconds after startup before turning off. maybe my carbs are dirty? i bought a can of seafoam and poured the entire thing into my gas tank. i hope that will help somewhat but maybe someone knows what exactly is causing these to happen.
locktite ALL the things!!! |
May 2nd, 2011, 10:20 AM | #2 | |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250R Posts: 9
How many miles on the bike? It might just be time for a spark plug change |
May 2nd, 2011, 11:10 AM | #3 |
Might also make sure your battery's fully charged.
For what it's worth, they recommend using about a quarter or a third of the can of Seafoam with the volume of gas we have, so don't be surprised if this tank o' gas acts a little weird.
May 4th, 2011, 08:21 PM | #4 |
certified newbie
as of this post, 5030
May 5th, 2011, 05:34 AM | #5 |
May 5th, 2011, 11:36 AM | #6 |
how's your oil level in the sight glass? is it low? what's your idle speed?
May 5th, 2011, 11:48 AM | #7 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
was it just a bad tank of gas?
May 5th, 2011, 05:45 PM | #8 |
certified newbie
i put too much oil in during my last oil change. rode it for a week until i noticed the oil level was a little over the line. then i drained some out and now the oil level is fine, its exactly at the full line. i started using shell rotella-t full synthetic. idle speed is at 1100-1200. i just filled the tank with 3.66gallons of 87 octane this morning. also, when riding for the first 5 minutes, the whole bike seems to vibrate as i open the throttle on the first few gears but thats probably due to the engine being cold.
May 5th, 2011, 06:10 PM | #9 |
raise the idle speed to 1500 and see if that helps.
Tricky Ignition Problem | smp | 2008 - 2012 Ninja 250R Tech Talk | 5 | March 16th, 2015 03:07 PM |
Ignition Problem - Multimeter and New Battery | garman | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 27th, 2014 08:36 PM |
ignition removal problem | blegerton | Ninjettes At Speed | 27 | January 28th, 2014 07:04 PM |
Are Ignition Boxes a Common Problem | bikertrash2001 | 1986 - 2007 Ninja 250R Tech Talk | 1 | June 5th, 2011 06:02 PM |
Ignition problem | nilo | 2008 - 2012 Ninja 250R Tech Talk | 8 | January 9th, 2011 04:23 PM |
