Old June 2nd, 2011, 01:22 PM   #1
mr.jake
mr.jake's Avatar
Motorcycle(s): 1996 ninja 250
broke left handlebar. where to get mx style bars?
i recently droped my bike and broke the left handle bar off. does anyone know where to get a dirtbike style handle bar kit for the ex250? thanks
those who think they can and those who think they cannot are usually right.
mr.jake is offline   Reply With Quote
Old June 2nd, 2011, 02:21 PM   #2
Don't know where he got them, but it looks loike Reza SS in Indonesia uses them to gain more room/clearance for certain stunts and it holds a second hand brake on the left side.
Old June 2nd, 2011, 05:27 PM   #3
mr.jake
mr.jake's Avatar
thanks man, my ninja is a 96 though. ive looked all over and cant find a kit any where...
Old August 7th, 2011, 08:33 AM   #4
tanman2003
tanman2003's Avatar
Motorcycle(s): 2004 Kawasaki Ninja 250, 2007 Harley Davidson Nightster XL 1200N
I've been interested in doing this myself, it appears you need to drill two holes in your triple tree clamp so you can mount some of these.
i have also found this, but its not in production yet apparently
http://www.satoracing.com/ninja250_handleriserkit.htm
the second option would be more ideal, but it is not available.
one thing to think about when drilling holes to mount the first option, is that there is bracing under the triple tree clamp that was cast/forged when the part was created, so its not a flat surface under there. I'm currently in the process of deciding what i want to do with that situation.
tanman2003 is offline   Reply With Quote
Old August 9th, 2011, 03:38 PM   #5
OP said he has a pregen, but thanks for showing us!
Old August 9th, 2011, 03:59 PM   #6
nickadolph
Motorcycle(s): ninja 250
Go on ebay and pickup some virago xv1100 risers. I used them to put drag bars on my bike. Also if you go with dirty bars there is a good chance you'll need longer cables. The bars themselves can be picked up at most sportbike dealerships.
nickadolph is offline   Reply With Quote
Old August 12th, 2011, 11:44 AM   #7
tanman2003
tanman2003's Avatar
can you post some pics of your setup. particularly under your top triple tree clamp, i want to see where you drilled your holes for the risers.
Old August 12th, 2011, 12:18 PM   #8
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
http://japan.webike.net/products/9651932.html
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old August 12th, 2011, 12:33 PM   #9
nickadolph
The virago riser basically just has a stud sticking out the bottom of it, so I drilled the most forward stock clipon mounting holes a little bigger and bolted it on.
Old August 12th, 2011, 11:41 PM   #10
tanman2003
tanman2003's Avatar
thanks nick!
that looks like it would work just fine for me, i wonder if i need to switch with a new gen upper clamp to get the flush bolt holes, or if i can fab up some spacer.
Old November 20th, 2014, 08:52 PM   #11
ascencionalberto
Motorcycle(s): 09 ninja 250r 09 ninja 250r stunt 2011 ninja 250r
Do you have any more pics of your set up for the handlebars
ascencionalberto is offline   Reply With Quote
Old November 20th, 2014, 09:01 PM   #12
cuong-nutz
cuong-nutz's Avatar
Buy standard dirt bike mx mounts
Drill holes larger and new holes
Mount your favorite bar
You might need new longer brake lines
HalfFast Racing Team
Old November 21st, 2014, 08:22 AM   #13
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
I used the aftermarket risers, available on Amazon. They're good because you can insert an internal-drive hex head bolt from the top, which is good because space for a bolt is tight underneath. You can then tighten the risers with a hex driver from the top, and a wrench held on the bolt below.
Here's ours:
I like the idea of bolting a plate to the existing handlebar attachment area (don't know why I didn't do that). It would add a little weight, but would allow easier use of a variety of handlebar mounts, and lower ones, too - just drill four holes in the right place, and any $20 riser set will work.
Chicagobob is offline   Reply With Quote
Old April 15th, 2015, 01:11 PM   #14
jessekreib
Motorcycle(s): 07 ninja 250, '72 cb500, '03 750monster, '69 cb350
riser source
Here's ours:
do you have a source (brand) on the risers you used? thanks!
jessekreib is offline   Reply With Quote
Old April 15th, 2015, 01:53 PM   #15
Chicagobob
Chicagobob's Avatar
Outlaw Racing. I got them from Amazon.
Old April 15th, 2015, 03:12 PM   #16
Ghostt
Ghostt's Avatar
Another option,
How to lower your bars....
violente et ignorantia
ZX-2R BLOG
Old April 15th, 2015, 03:40 PM   #17
Welcome Jesse!
Old April 15th, 2015, 09:43 PM   #18
ieathonda
ieathonda's Avatar
Motorcycle(s): Ninja EX250F
i was just about to page you @Chicagobob
ieathonda is offline   Reply With Quote
Old January 8th, 2016, 06:10 PM   #19
Pigeonherd
Pigeonherd's Avatar
Motorcycle(s): 2006 Ninja250, 2014 Honda CB500X, '15CB300F
Originally Posted by caps View Post
IN WHAT WORLD IS THAT HUNK OF METAL WORTH $270????????
Pigeonherd is offline   Reply With Quote
Old January 12th, 2016, 12:29 PM   #20
Pigeonherd
Pigeonherd's Avatar
Okay, but more seriously.....
Are there any of these in existence that do (or could) use same size bolt as the stock handlebar mounts?? Part #92002-1178 says "Bolt,Socket,8x20" so that's 8mm diameter, right?? Most of these look to use 10mm+ bolts...
Would it really hurt that much to use 8mm bolts?
It'd be cool to be able to do this without drilling, as I haven't the tools for drilling....
Old January 29th, 2016, 11:24 AM   #21
RickM
Motorcycle(s): 2000 EX250
Yes, 8mm bolts. I doubt any off the shelf clamps can be used with the stock bolt holes due the angle they are at. You could have custom risers made, but that won't be cheap at all.
Drilling to fit generic risers is pretty easy. Ask around and borrow a drill??
RickM is offline   Reply With Quote
Old March 1st, 2016, 06:03 PM   #22
Pigeonherd
Pigeonherd's Avatar
FOUND.
EIGHT MM BOLTS.
Old January 24th, 2022, 08:56 PM   #23
Yamastorm
Yamastorm's Avatar
Motorcycle(s): 2007 Ninja 250r
It is 7/8 handlebar or bigger?
Yamastorm is offline   Reply With Quote
Old January 24th, 2022, 09:49 PM   #24
You can get them in either 7/8" or 1-1/8" clamp. Here's 7/8":
https://www.amazon.com/dp/B06W9G99Q3 - silver
https://www.amazon.com/dp/B08G1JL2T8/ - black
Then pick from large selection of 7/8" bars.
https://www.revzilla.com/motorcycle-...=featured&fit=
Last futzed with by DannoXYZ; January 25th, 2022 at 01:10 PM.
Old January 25th, 2022, 09:16 AM   #25
Yamastorm
Yamastorm's Avatar
Handlebars
Going with 7/8" is better because all mine levers fit correct?
Or do stock levers fits on 1 1/8" handlebars?
Old January 25th, 2022, 01:08 PM   #26
No, you'll need new levers and controls for 1-1/8".
Yeah, sticking with factory 7/8" is easiest.
Depending upon where controls end up, you may need longer carb cables.
left peg broke brokenninj 2008 - 2012 Ninja 250R Tech Talk 10 April 15th, 2015 01:51 PM
WTB: (300 or 250) OEM left handlebar, left rearset, left mirror iamakitkatbar Items Wanted 7 September 1st, 2014 03:33 PM
Moto-style bars Otter 2008 - 2012 Ninja 250R Tech Talk 4 February 27th, 2012 08:03 PM
Handlebar adapters for regular bars Bosgarage57 1986 - 2007 Ninja 250R Tech Talk 3 January 26th, 2012 07:22 PM
