Old June 23rd, 2011, 05:23 PM   #1
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
What's up with my bike? Dropping gears
Lately I've been cruising around on my ninjette and when I shift into 2nd, usually within 2 seconds the thing drops back in to neutral! It makes the engine rev really high as I'm usually applying throttle through my shifting and gives me a bit of a jolt.
At first I thought maybe it was me, as I'm a fairly new rider (3 weeks today) but there have been a few times where I'm solidly in 2nd gear, been there for at least 6 seconds with my foot underneath the shift lever and boom, the bike drops in to neutral! Even more recently, starting yesterday, the bike seems to have been doing the same in higher gears. Maybe not completely dropping but it seems to get caught between gears as I shift. The jury is still out as to whether or not that's me being a noob or the bike playing with my emotions; but do you guys have any idea as to what's up or how I can fix it?
To cover some questions you may ask I have experienced this issue both when I've first started riding as well as when I've been riding for a fair amount of time (so when the bike is both warm and cold) and it happens when I'm really rolling on the throttle or just cruising down the road.
Trailerboy531 is offline   Reply With Quote
Old June 23rd, 2011, 05:56 PM   #2
MattRichling
Motorcycle(s): 2011 250R Black
I have had the same thing happen...
MattRichling is offline   Reply With Quote
Old June 23rd, 2011, 05:56 PM   #3
nah.uhh
Motorcycle(s): n/a
Let the shift lever fully release betwEen shifts
Don't ride w your foot under the lever
You don't have to, but I recommend riding on the balls of your feet with your heels in
Edit: I've never had it happen to me, so its just my 2c
nah.uhh is offline   Reply With Quote
Old June 23rd, 2011, 05:59 PM   #4
adjust the shift lever.
Old June 23rd, 2011, 11:07 PM   #5
This will help you get better body position.
New boots or steal toe? kkim may have it again with adjustment. Depending on your size, boot and your comfortable foot position, you may have to adjust your shift lever. Seems to me, the variance (2secs vs 6sec) in time points to when you move your foot.
The false neutral is a known thing on these bikes and only made worse by poor adjustment with your boots. You have to shift with authority and completely.
But for 3 weeks... Ride how you are comfortable and be safe out there.
Old June 24th, 2011, 01:40 AM   #6
Trailerboy531
Well I was heavily considering the fact that it could be my foot, but then there were times when it would drop down when my foot was nowhere near the shift lever and that's what concerns me. Or if my foot is by the shift lever it's below it so it shouldn't be dropping down a gear?
I'll try what you guys have posted though and see what results I get, thanks!
Old June 24th, 2011, 02:39 AM   #7
sigh... try adjusting your shift lever.
Old June 24th, 2011, 05:05 AM   #8
HKr1
IC2(SW)
HKr1's Avatar
How old is the bike, bran new with factory oil?? If its new and never had an oil change, do an oil change. Thats what fixed ours from doing that.
Old June 24th, 2011, 05:18 AM   #9
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
+1. This can happen when you don't quite pull on the shift lever far enough to really click into gear (even though it seems in gear for a second). If the lever doesn't allow you to reach the top of the shift range easily or if you're making half-hearted shifts, it can click back into neutral. Plus, if that's the problem, it'll make it much more comfortable to control.
LazinCajun is offline   Reply With Quote
Old June 24th, 2011, 10:37 AM   #10
greg737
Motorcycle(s): -
+1 on that.
1st to 2nd gear is the biggest shift in a motorcycle gearbox. Crossing over the neutral area between the two gears.
The shift lever has to rotate the cam-drum further on this shift than on any other, moving the gearbox shifting forks far enough to disengage 1st, cross neutral and then engage the dogs on 2nd.
Old June 24th, 2011, 10:52 AM   #11
Bols
Norwegian dude
Motorcycle(s): Ducati 748
Been having the exact same problem lately, and happening more often. And it's definitely not me, there is something with either the shift lever itself or the "neutral-finder" mechanism. Actually called the shop last night, where i bought the bike from about a year ago and asked about it, and they told me to bring the bike in and have it checked asap.
Uhm, I would kinda like to try this myself if possible before bringing it in. However I have no idea how/what needs to be adjusted. Yes, I am very noob and afraid of messing things up when it comes to mechanical stuff. If anyone could explain this abit further I would be very thankful
Bols is offline   Reply With Quote
Old June 24th, 2011, 11:04 AM   #12
loosen the 2 lock nuts on the shift rod and turn the rod in or out till it adjusts the shifter to the position you want it, then retighten the lock nuts.
pics of the shift rod install in this DIY should help. read the text along with the pics as one of the lock nuts is reversed threaded.
http://www.ninjette.org/forums/showthread.php?t=15136
Old June 24th, 2011, 11:09 AM   #13
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
If you carefully run the bike on a stable rear stand does it disengage?
Back to KKim's point I know when I change boots I often have shifting issues until I get a good feel for the shape of the boot.
Old June 25th, 2011, 04:04 AM   #14
tac12345
Motorcycle(s): Ninja 250r 09 SE
it's hapenning to me under hard acceleration in gear 2, 3, 4, 5 and 6....
I will try to adjust the shift lever.
tac12345 is offline   Reply With Quote
Old June 25th, 2011, 11:32 AM   #15
Bols
Norwegian dude
Adjusted the shift lever + idle rpm, and it seemed to work wonders! Thanks alot Kkim But I think it's due for an oil change also, maybe I'll try doing that myself too, following your DIY closely
Old June 25th, 2011, 12:06 PM   #16
LazinCajun
LazinCajun's Avatar
Good to hear!
How the gears of your bike were made Motofool Videos 13 July 17th, 2014 07:08 AM
My bike has too many gears:/ JohnnyBravo 2013 - 2017 Ninja 300 Tech Talk 34 January 23rd, 2014 09:14 AM
My bike sorta has 12 gears. arnoldc6 2008 - 2012 Ninja 250R Tech Talk 7 October 10th, 2013 03:42 AM
[visordown.com] - New bike sales still dropping Ninjette Newsbot Motorcycling News 0 March 8th, 2013 04:10 PM
[topix.net] - Charity Bike Ride Gears Up For Good Cause Ninjette Newsbot Motorcycling News 0 August 7th, 2010 08:30 PM
