Old September 12th, 2011, 02:53 PM   #1
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Clutch In During Startup?
I've been told not to trust motorcycle neutral lights as they sometimes lie. For this reason I always start the bike with the clutch fully disengaged (lever fully squeezed).
Questions!
Do any of you do this?
Have any of you experienced a new-gen Ninjette showing a Neutral light when in-fact it is in gear?
Final question: How cute is the little guy in my avatar?!!
I should probably state that I normally leave the bike in gear when it's off and parked up so no one can roll it away. I always flick it into neutral before starting the bike.
Thanks
Old September 12th, 2011, 02:59 PM   #2
Bunker
Motorcycle(s): gold wing 2008
the bike wont start if it is truly in gear without pulling the clutch lever. If my neutral light is on, no clutch pulled, and it does not start, then i know it must be in gear. Bunker
Bunker is offline   Reply With Quote
Old September 12th, 2011, 03:08 PM   #3
kingkang204
Motorcycle(s): Bike-less, Can I ride yours?
Questions!
Thanks
Did MSF teach you this, they told me this when I took it. As the comment about me states the bike won't start if its not in neutral. There is a thing that ninja's do sometimes called "False Neutral" but this usually happens at speed and you can just click up or down and it will pop into gear again.
RR stands for Responsible Riding... Right?
kingkang204 is offline   Reply With Quote
Old September 12th, 2011, 03:28 PM   #4
mrlmd
mrlmd's Avatar
Many bikes will not start unless the clutch is pulled in, and definitely will not start in gear unless the clutch is pulled in (a safety feature). You also are making it easier to start by disengaging the clutch, putting less strain on the battery and starter motor because the oil may be cold and more viscous and you don't have to get everything spinning inside the trans.
Old September 12th, 2011, 03:29 PM   #5
Heed
Heed's Avatar
Motorcycle(s): None yet, yet.
Yep.
Hold the clutch lever in every time you start the engine. Never trust the neutral light. I remember that from the MSF.
Even if it isn't in neutral, though, you'd stall the engine immediately even if it did start.
I also remember being taught to squeeze the front brake as you're mounting just in case.
Heed is offline   Reply With Quote
Old September 12th, 2011, 03:36 PM   #6
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Originally Posted by Heed View Post
Yep.
I do the exact same thing.
LoD575 is offline   Reply With Quote
Old September 12th, 2011, 03:38 PM   #7
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Questions!
Thanks
I usually start the bike with the clutch pulled in.
I have yet to see a neutral light on with the bike being in a gear.
He's vermin.
I always park in gear. I usually start while still in gear unless I'm standing next to the bike.
Old September 12th, 2011, 03:41 PM   #8
Heed
Heed's Avatar
I'd guess that it's probably more likely for the neutral light to NOT turn on when it truly is in neutral.
Old September 12th, 2011, 04:22 PM   #9
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
Yes. No. As cute as the plague and rabies.
Old September 12th, 2011, 04:23 PM   #10
KJohnson21
KJohnson21's Avatar
Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick"
Yes, I always pull in the clutch while starting.
BTW, I never park it in gear unless I have to. (Parking on a grade, etc.)
HEY!! Unregistered!! Does your bike have a name?
KJohnson21 is offline   Reply With Quote
Old September 12th, 2011, 04:42 PM   #11
Snake
Snake's Avatar
I have a pre-gen so I can't answer the clutch question.
Yes he is a cute little bugger. I have a few squirils in my back yard which I feed.
Old September 12th, 2011, 04:46 PM   #12
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
I rarely ever start my bike without disengaging the clutch, even if I'm not sitting on it.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old September 12th, 2011, 04:52 PM   #13
miss_syn
my hair matches my bike
miss_syn's Avatar
Motorcycle(s): 2010 Red 250r
I always start with clutch in.
Once, when I first started riding and I was at a toll booth.
Adorable!
miss_syn is offline   Reply With Quote
Old September 12th, 2011, 05:01 PM   #14
HKr1
IC2(SW)
HKr1's Avatar
He;s pretty dam cute
Old September 13th, 2011, 02:19 AM   #15
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Just woke up. Thanks for all your responses. I think I shall continue starting with the clutch disengaged.
In England we don't have "MSF". We are forced to take quite a big test before we can ride Ninjettes (or bigger bikes). For that we go to a training school, which I suppose teaches similar stuff to your MSF. The training school people did teach me about the neutral light sometimes lying. They had beaten up 125CC bikes to learn on. Maybe they're more prone to lying.
That's interesting and good to know. Presumably then, if someone was trying to start their Ninjette on a low battery with the clutch engaged and the bike wasn't starting, then they could try starting the bike with the clutch disengaged and there is a better chance of it starting.
Originally Posted by rockNroll View Post
He's vermin.
How dare you!!
Old September 13th, 2011, 03:10 AM   #16
Skippii
Milkshake Drinker
Skippii's Avatar
I don't think I've ever experienced the light on while in gear on any bike. False neutrals, however, I've experienced on just about every bike.
You MUST pull in the clutch to get out of a false neutral safely. Clutchlessly clicking it into a gear from a false neutral is a great way to get pitched off in a highside.
"What a sweetheart."- ninja_sleeper to me
Old September 13th, 2011, 07:46 PM   #17
Jerry
Jerry's Avatar
Motorcycle(s): 2007 EX250
Best bet, then is to get in the habit of starting with the clutch pulled in AND the bike in neutral.
(Super especially so when it's cold)
Jerry is offline   Reply With Quote
Old September 13th, 2011, 08:49 PM   #18
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Questions!
Thanks
Always
Yep
Eh, I'm more interested in seeing what a person from England named Akima looks like
AFM #676
Supersports are for n00bs
Old September 14th, 2011, 02:20 AM   #19
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by Jiggles View Post
Always
Yep
"Akima" isn't my real name. She's a character from a film who I think is cool!
Old September 14th, 2011, 02:31 AM   #20
kenji_808
Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current)
Actually you can turn the engine over a little while being in gear and the clutch not being disengaged, it will jump forward as if you killed the motor. Ive done this a few time being in a rush.
I rarely ever start my bike while holding in the clutch lever.The reason being that when I park my bike I always roll the bike up against the gear to prevent it from rolling of the side stand and so when I want to start it I have to roll off the gear and click into neutral. That way I know for sure my bike isn't in gear. Since that Neutral light doesnt like to work sometimes
kenji_808 is offline   Reply With Quote
Old September 14th, 2011, 10:53 AM   #21
Jiggles
Jiggles's Avatar
MOTM - Apr '13
That makes more sense. I was picturing a japanese person with an english accent.
Like that starburst commercial with the scottish koreans lol.
AFM #676
Old September 14th, 2011, 12:18 PM   #22
akima
Nooblet
akima's Avatar
MOTM - Oct '13
My last house mate was a Japanese guy, born in Scotland but with an English accent.
Old September 14th, 2011, 12:52 PM   #23
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
I have! For a while my confused little ninjette had a faulty neutral switch, and happily showed neutral as I rode off.
As for the clutch lever -- I personally think it's a good habit to have. I feel like it's one of those little things that will probably never make a difference to most people, but 1/10000 will avoid a parking lot drop because they pulled the clutch while starting.
LazinCajun is offline   Reply With Quote
Old September 14th, 2011, 01:00 PM   #24
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
Not sure if other people do this, but when I read posts sometimes the voice inside my head sounds different based on the persons avatar. I always imagine a squeaky thing talking when I read you're posts because of that lol.
Mr.E is offline   Reply With Quote
Old September 14th, 2011, 01:38 PM   #25
akima
Nooblet
akima's Avatar
MOTM - Oct '13
ha ha! I'm not squeaky.
Here's a mysterious picture of me to replace your mental image of me as a cute, squeaky, squirrel:
Old September 14th, 2011, 01:48 PM   #26
jamesio
jamesio's Avatar
Motorcycle(s): None
Questions!
Thanks
Totally cute!
Check out my pic...I call it surfs up squirrel
Oh, and never happened to me b4 and have never heard not to trust neutral lights. I always park and start mine in neutral, unless on a hill or something. The clutch safety switch will prevent the bike from starting anyway if it's in gear with the clutch engaged (lever out).
'09 Ninja 250R SE
TB Slip-On l Puig DB l Pazzos l Pro-Grips
jamesio is offline   Reply With Quote
Old September 14th, 2011, 01:52 PM   #27
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Originally Posted by jamesio View Post
Totally cute!
Aww. Adorable little guy.
This is my favourite one:
I laughed so hard when I saw that. That couple had set their camera to go off on a timer and that little guy popped up out of nowhere!
Old September 14th, 2011, 01:52 PM   #28
Mr.E
That rider dude.
Mr.E's Avatar
Attachment 14743
Hmmm. Which tree are you in? Just kidding lol. I looked at the pic before clicking on it, and it looked like you were walking on water. It was very mysterious indeed.
Old September 14th, 2011, 02:22 PM   #29
jamesio
jamesio's Avatar
Motorcycle(s): None
oh my gosh! That's so cute
'09 Ninja 250R SE
Old September 14th, 2011, 02:37 PM   #30
areifel
areifel's Avatar
i have had many mishaps when the indicator neutral light was lit up and when i went to start my bike it leapt forward, almost falling over. you should never really rely on the neutral light
areifel is offline   Reply With Quote
Old September 14th, 2011, 06:05 PM   #31
You should consider always parking with the bike in gear. Put it in first, let the clutch out, roll the bike forward to take up all the drivetrain slack, and put the kickstand down. It keeps the bike from rolling forward at all without a very significant bump from behind, and makes it that much less likely it ends up on its side unexpectedly.
Old September 14th, 2011, 11:44 PM   #32
Clearlynotstefan
Clearlynotstefan's Avatar
Motorcycle(s): 2000 Ninja 250, Totally black. Gsxr 600 Red.
With the GSXR you have options
You can start it in neutral with the side stand down using clutch
you can't start it in gear if the side stand is down, even with the clutch in
The bike has to be in neutral to start with the kickstand down
I usually park in first and leave it. then when riding, I click down to neutral, and start it (clutch required) then gear up and wait to ride
Clearlynotstefan is offline   Reply With Quote
Loud crack on cold startup mrb 2008 - 2012 Ninja 250R Tech Talk 24 October 21st, 2013 07:51 AM
Bike turns off at startup sunspots 2008 - 2012 Ninja 250R Tech Talk 5 July 5th, 2013 07:44 PM
Backfire at Startup!!!!!! g21-30 2008 - 2012 Ninja 250R Tech Talk 175 January 17th, 2013 12:16 PM
Needing blip on startup. headshrink 2008 - 2012 Ninja 250R Tech Talk 34 March 28th, 2011 10:52 AM
Loud noise at startup? Zaneman 2008 - 2012 Ninja 250R Tech Talk 4 August 15th, 2009 11:12 PM
