January 22nd, 2012, 07:16 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R Posts: 131
How many racers have cut off the 2008+ kickstand mount?
I'm reading that some racers have done this for clearance. I use a lot of lean angle at the track, but I hate to cut off the mount because i'm always considering when I sell the bike, the buyer may want to put the bike back on the street.
Posted via Mobile Device |
January 22nd, 2012, 10:00 AM | #2 |
I have not, but there are a few racers here who have cut every uneeded tab/mount off their bikes in the name of weight savings.
January 22nd, 2012, 11:23 AM | #3 |
Join Date: Dec 2011 Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L Posts: 142
I cut mine off...it does hang down a bit. in a good place to lighten the back. last place I wanna take load off the rear wheel is in a corner.
figure if/when i sell it, it will go to a racer. no way i'm going to put all the street crap back on.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles |
January 22nd, 2012, 11:33 AM | #4 |
CMRA Mini Endurance #6
Join Date: Mar 2011 Motorcycle(s): CBR954, CBR600RR, EX250 Posts: 108
January 22nd, 2012, 11:59 AM | #5 |
Join Date: Oct 2011 Motorcycle(s): 1999 Kawasaki ZRX1100, 2006 Yamaha R1, 2006 Kawasaki ZZR600, 2009 Kawasaki Ninja 250R, 2017 Kawasaki Z900 Posts: 320
Got the same concern on the mount touching down at the track. Think I am going to grind it off but it shouldn't be too tough to weld back on if I want.
January 22nd, 2012, 05:44 PM | #6 |
OMRRA 701
I have not yet removed the kickstand and mount but will as soon as I understand how to to it properly. Just searched the forum and online for a how-to but came up empty. Could anyone w/experience doing this please post create a new thread or wiki for how to disable the killswitch in the kickstand and a good way to cut off the mount? If here is already a good writeup out there that I missed a link in this thread would be helpful.
thanks Kangxi |
January 22nd, 2012, 06:08 PM | #7 |
Join Date: Nov 2011 Motorcycle(s): 09 250r race bike, 06 R6 race bike, 06 YZ450f Tard Posts: 122
i hacked ours off as per the rules(CRA) and smoothed with a grinder....along with alot of other tabs. as far as the switch goes, just made a little jumper wire where the switch plugged into and done!
January 22nd, 2012, 06:12 PM | #8 |
Unless someone has a better idea I plan to disable the kickstand switch by cutting and soldering together the two switch wires just before the wiring harness, meaning leave the stock wiring harness connector intact. I plan to use a dremel to cut the mount.
January 22nd, 2012, 06:18 PM | #9 |
January 22nd, 2012, 06:21 PM | #10 |
January 22nd, 2012, 06:24 PM | #11 |
OMRRA 701
January 22nd, 2012, 06:27 PM | #12 |
air cut off tool....basically a die grinder with a cutoff wheel on it..
http://buy1.snapon.com/catalog/item....re&dir=catalog |
January 22nd, 2012, 06:34 PM | #13 | |
OMRRA 701
January 22nd, 2012, 06:48 PM | #14 |
Just get a cheap angle grinder...I'm sure one from Harbor Freight would work fine. I'm gonna use one to remove my bracket.
January 22nd, 2012, 08:26 PM | #15 |
Join Date: Mar 2011 Motorcycle(s): 899, 748, 250, 250, 70 Posts: 348
Your bike will be worth a lot less to a potential buyer if you drag that kickstand mount and shitwreck it.
January 22nd, 2012, 10:33 PM | #16 |
OMRRA 701
January 23rd, 2012, 12:27 PM | #18 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
I highly recommend removing/grinding/cutting the kickstand mount off especially if the track you ride on has corner elevation changes. Last thing you want is for mount to pivot into the track and cause you to crash which has happened to a few racers I know.
January 23rd, 2012, 07:29 PM | #19 |
Thanks for the feedback, I will chop it off!
January 23rd, 2012, 08:15 PM | #20 |
la pussy gata
After turn 3 at big willow, i cut off that kickstand!
January 23rd, 2012, 09:22 PM | #21 |
Chop it off, and - if only for some peace of mind - click that preload all the way up. This bike needs every mm of ride height it can get!
January 24th, 2012, 11:46 AM | #23 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250 Posts: 256
I used a drill with a cut-off wheel attachement from Home Depot. Pretty cheap solution also.
WERA #273 Novice Boogeyman Racing. |
January 24th, 2012, 12:57 PM | #24 |
Join Date: Oct 2011 Motorcycle(s): 2008 Kawasaki ninja 250 Posts: 132
Cut it.... It's gotta go. You'll def want something more than a dremel!!!! That mount is fairly stout.
January 24th, 2012, 10:34 PM | #25 |
OMRRA 701
Embarrassed to say that I can't even get the kickstand leg off of the mount! The 17mm bolt holding it on is on steroids - anyone else have problems getting this bolt off without help from a friend to help hold the retaining nut on the other side? Suggestions?
January 25th, 2012, 12:13 AM | #26 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
Hacksaw works fine and save the piece to weld back on if needed. Simple.
January 25th, 2012, 05:28 AM | #27 |
I've always been told to heat up the bolt(s) a little. I'll be removing it this weekend too - let me know how it goes.
January 26th, 2012, 08:00 AM | #28 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
I'd like to cut my mount bracket off for track days, but my 250 is also used mostly for street use at the moment. an easy to remove kickstand would be awesome, if there was one...
January 26th, 2012, 08:39 AM | #29 |
OMRRA 701
Could someone please post a close up picture of exactly where you cut off the mount?
Also, if someone has more detailed info on how to deal with the electrical running from the kickstand to the starter that would be great. - tks, |
January 26th, 2012, 10:11 AM | #30 |
Eberhart Creative |
January 26th, 2012, 10:37 AM | #31 |
OMRRA 701
Perfect! Thanks for posting up, Ed!
January 26th, 2012, 02:25 PM | #32 |
for the wires, all you need to do is make the 2 wires contact each other. cut them off, splice them together, throw some solder on there, and heat shrink it or electrical tape. you could also use a jumper or some electrical splicing connector. but make sure whatever you choose, it is secure. if those wires come apart when you're on the track, your engine's turning off!
January 27th, 2012, 09:41 AM | #33 | |
OMRRA 701
March 30th, 2012, 04:27 PM | #34 |
Name: Zander the Expander
Join Date: Nov 2011 Motorcycle(s): 2010 Kawasaki 250 (Track scooter) 2012 Triumph Daytona 675 Posts: 153
March 30th, 2012, 04:36 PM | #35 |
The belly pan bolts up to it.
March 30th, 2012, 05:13 PM | #36 | |
2) Race rules require a lower fairing that can hold two quarts of oil |
March 30th, 2012, 06:21 PM | #37 |
Join Date: Apr 2011 Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike Posts: 137
I cut mine off too. I heard too many stories about the 250s crashing on track that i decided it had to go. However, i am having a problem with the newly exposed bare metal rusting. Has anyone else had this? it looks from peoples pics that they painted/coated it with something... i may need to do that.
March 30th, 2012, 06:28 PM | #38 |
I painted mine before it had a chance to rust.
March 31st, 2012, 12:32 PM | #39 |
covered in awesome sauce
Join Date: Aug 2011 Motorcycle(s): 09 Ninja 250r racebike, 09 Triumph Street Triple R Posts: 31
I havent cut the tab off yet, I find the pegs and shift lever are scraping still, after i get rearsets I will probably cut it off.
April 2nd, 2012, 06:05 AM | #40 |
Just cut mine with a sawz all ... covered the exposed metal with JB Weld and then spray painted over
WTB: OEM 2008-12 Ninja 250r Kickstand | pingels | Items Wanted | 2 | January 10th, 2015 01:31 PM |
Kickstand after it's been cut off? | bitaria | Ninjettes At Speed | 14 | September 15th, 2013 10:27 AM |
Does this kickstand mount look guilty | ock1 | !%@*#$%!)@#&!%@ I crashed! | 2 | October 23rd, 2012 11:42 PM |
Relocating or modifying the kickstand mount? | StevieMac | Ninjettes At Speed | 3 | August 4th, 2012 01:11 AM |
[hell for leather] - FIM to supermoto, motocross racers: cut your hair, hippies | Ninjette Newsbot | Motorcycling News | 0 | December 23rd, 2008 02:20 PM |
