Old December 4th, 2014, 09:41 AM   #81
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Originally Posted by Jetfoi View Post
@Chicagobob did you cut the side fairings to make them shorter?
Yep. They are easy to cut with a jigsaw (hacksaw or plywood blade) or Dremel cutting wheel, and touch up with a belt or disk sander. We left the bottom bolts in place to secure them to the bike. Parts of them (near the bolts) are painted flat black.
Chicagobob is offline   Reply With Quote
Old December 4th, 2014, 09:56 AM   #82
Jetfoi
Jetfoi's Avatar
Motorcycle(s): 2013 zx6r and 1995 250r
Originally Posted by Chicagobob View Post
Yep. They are easy to cut with a jigsaw (hacksaw or plywood blade) or Dremel cutting wheel, and we left the bottom bolts in place to secure them to the bike. Parts of them (near the bolts) are painted flat black.
Awesome thanks for the pointer
spend all the spare time on two wheels
Jetfoi is offline   Reply With Quote
Old March 25th, 2015, 10:08 AM   #83
Chicagobob
Chicagobob's Avatar
Lightening project - smaller headlight, and a rear mudguard
We spent a few hours this weekend replacing our 7" headlight with a 5" Bates-style one we got for about $45 from Amazon. These lights are becoming more common in cafe and scrambler builds, so we thought we'd try it. It reduces the front profile of the bike, and is also lighter. It's a bottom-mount light that mounts to the horn bolts on the bike's lower triple clamp, with a small aluminum bracket we made. We remounted the turn signals to the coil bolts (near where they were on the bike originally).
Surprisingly, this light seems just as bright as the larger one.
That rear mudguard is is also new. It's made from formed 1/16" aluminum and a dirtbike fender extender with a tiny LED tail and brake light. We also swapped the cafe-style rear turn signals with little lights mounted in the ends of the frame tubes. It's all very lightweight, and the mudguard protects the rider's back from the prodigious amounts of moisture on the roads around here, especially this time of year.
Anyhow, the bike's up and running around. Just need some decent weather.
Old March 25th, 2015, 10:22 AM   #84
Old March 25th, 2015, 10:40 AM   #85
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
Getting better and better!
My Cafe Racer Build
My intro post
Old March 26th, 2015, 03:03 AM   #86
fast1075
Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite
nekkid frame tubes in the back
I just can't get past the look of the nekkid frame tubes in the back. The rest looks great.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike.
fast1075 is offline   Reply With Quote
Old April 15th, 2015, 11:33 AM   #87
DanielObrien42
And that's the part I liked best, the naked frame. Would like to see more of it.
DanielObrien42 is offline   Reply With Quote
Old April 15th, 2015, 12:18 PM   #88
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
I didn't want to delve into exhaust and intake mods, because this is a LOW budget build - the bike cost $1,500, I had the headlight and signals, the taillight was $20, the Trail Tech gauge was $95 used, and I hope to sell some of the removed parts to get a little back from that.
What was the part number for the gauge and was it a direct fit?
Old April 15th, 2015, 04:56 PM   #89
UnshavenCanuck
UnshavenCanuck's Avatar
Motorcycle(s): 2005 Ninja 250
I didn't like that look either. Thought it distracted from everything else so I got daring one day and chopped them out. Found pipe that slipped over the original support and bent it a little and welded her all up.
UnshavenCanuck is offline   Reply With Quote
Old April 15th, 2015, 05:30 PM   #90
looks really good!
Old April 17th, 2015, 07:40 AM   #91
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Attachment 36032
Do you have a close-up of your exhaust hanger? Why didn't you shorten the seat at the same time?
ÇĄńď©Ş| ß˙ Ńâ7µ®é. Äńtˇ~§ş˘Ďä| ßý Çhřî©č.
Old April 17th, 2015, 08:48 AM   #92
crazymadbastard
Attachment 36032
I chopped mine up and came up with some C shaped supports.
Click VVVV
My Cafe Racer Build
My intro post
Old April 17th, 2015, 11:00 AM   #93
UnshavenCanuck
Look closer. How much more could I have shortened it lol.
Hangars are just some nuts and 1/4" rod welded up and powdercoated
Old April 17th, 2015, 12:14 PM   #94
CynicalC
CynicalC's Avatar
Oh I see. I didn't realize it was a tailpiece. I thought it was just red vinyl stretched over the seat or something.
Old August 24th, 2016, 04:10 PM   #95
Chicagobob
Chicagobob's Avatar
Remounted the Vapor gauge
We recently made a new bracket and remounted the Trail Tech Vapor gauge in an offset position. Its a little more compact this way.
Another thing - finally got rid of the yellow rim tape, which I hate. We couldn't figure out how to remove it, so a wide black Sharpie came to the rescue
Also, saw 98 mph on the highway. Couldn't get any more, even with a speedway tuck. 15T front sprocket may be hindering top gear revs.
Old August 24th, 2016, 04:37 PM   #96
Good to see you here, Bob. I don't know if you saw my post on the other board about the 250 I did after seeing yours, but I posted in your thread to say thanks.
Old August 25th, 2016, 12:41 AM   #97
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Looks way better without rim tape... Never thought I'd say that
Old August 25th, 2016, 06:11 AM   #98
VaFish
VaFish's Avatar
MOTM - Jan '16
What handlebars, mounts and cables did you use?
Looking to do a similar thing on one of mine.
Old August 25th, 2016, 06:45 AM   #99
Chicagobob
Chicagobob's Avatar
Renthal low bars (Ultra or Super Low, can't remember what they call it). Outlaw bar mounts from Amazon (many other types available there, too). We used hex-drive bolts, rather than the bolts supplied by Outlaw, so they could be tightened from above.
Stock cables and wires, with a stock-length Venhill braided steel brake line. I had to reroute the clutch cable a little, I think. It's been a few years.
Old December 3rd, 2016, 02:50 PM   #100
acook3323
Motorcycle(s): 2005 ninja 250
[QUOTE=Chicagobob;592913] fabbed a taillight mount and turn signal mounts,
How did you fab the taillight and signal mounts and what did you use? Also wehre did you get the taillight?
acook3323 is offline   Reply With Quote
Old December 3rd, 2016, 03:16 PM   #101
Chicagobob
Chicagobob's Avatar
[QUOTE=acook3323;1148652]
We used aluminum plate, which we bent and drilled. The light is from Amazon, and cost only about $15. Many similar ones are available there, and from eBay.
Old December 11th, 2016, 11:28 AM   #102
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
You might want to remove the paint on the expansion tank just the rectangle between the upper & lower mark lines so you can see what the fluid level is.
Bike does look good.
Old December 11th, 2016, 02:15 PM   #103
acook3323
[QUOTE=Chicagobob;1148656]
Where did you mount the aluminum plate?
Old December 11th, 2016, 02:50 PM   #104
acook3323
Old December 12th, 2016, 08:31 PM   #105
Chicagobob
Chicagobob's Avatar
[QUOTE=acook3323;1149871]
Onto the tops of the rear frame rails, behind the crossmember. We originally used a shorter plate, but swapped it out for the "duck tail" fender to help keep our backs dry.
The taillight is mounted (with double-sided foam tape, because its original bolts have failed) to a small aluminum bracket that is bolted to the bottom of this plate, like so:
Old May 16th, 2017, 10:01 AM   #106
MrAtom
MOTM - July '15
Hey, Bob. I've slowly been seeing more and more of your style of bike on here. I did some of your mods to my bike a while ago, and have since seen more and more in the wild, and a few on Craigslist. You're famous-ish
Old May 16th, 2017, 11:03 AM   #107
Chicagobob
Chicagobob's Avatar
Thanks. It's a really fun bike. Latest mods: CRG Blindsight bar-end mirrors. Very good quality and only $40 each on Amazon:
Old May 16th, 2017, 12:51 PM   #108
Ram Jet
Ram Jet's Avatar
Here's where I mounted the rectifier and ignition modules (you can just see the ignition module peeking out from under the tank, where it's held in place with servo tape and foam):
And here's how I tidied up the undeside of the seat - a piece of sheet aluminum painted black:
I would be very careful mounting your rectifier with servo tape. The rectifier gets damned HOT. Don't believe me put your hand on it after a short ride. Also, make sure your rectifier has plenty of cooling air moving over it. I LIKE YOUR BIKE!!! I'm riding mine without the fairing right now waiting for some eBay parts but I'm getting to like it without the fairing. If you have any of the fairing stuff you want to unload "billalbertson@mail.com". Keep up the good work!
Cheers,
Bill
Old May 19th, 2017, 07:23 PM   #109
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
I can never trust tape, no matter how strong it is. I also mounted my R/R exactly where ChicagoBob has his, but instead of tape, I cut off the original mount from the wheel well and Gorilla Glued it to the Airbox. Works great.
Also, yes; you want to make sure plenty of air is getting to it, BUT a stock Ninja 250 has it hidden under fairings anyway where I'm assuming not a whole lot of air can get to it, so I wouldn't be too worried about it.
Cra1g is offline   Reply With Quote
Old May 19th, 2017, 10:50 PM   #110
Ram Jet
Ram Jet's Avatar
Sounds like you've got it covered. I'll have to try that Gorilla glue someday.
Bill
Old July 5th, 2017, 11:47 PM   #111
Rielen
Late
Pretty late to the party but I was curious how you went about fabricating your aluminum sheets.. any particular tools?? Are they all 1/16" thick? all the ones near me at like lowes are so thin. Also did you end up keeping the original rear fender? I'm having alot of issues trying to replicate what you did with the fender extender.. would this work similarly? (except removing the light) https://www.amazon.com/dp/B01FLNOH1I...=2C9AOJJEB0HUS
Rielen is offline   Reply With Quote
Old July 6th, 2017, 04:33 AM   #112
Chicagobob
Chicagobob's Avatar
I'm not sure how thick mine is, but I've used 1/16 and 1/32, aluminum plate, which you can get from various eBay sellers. Hardware stores don't usually carry it. I've been able to get a 24" X 24" plate on occasion. It is very useful for fabrication.
And that looks exactly like the Acerbis light we used.
Last futzed with by Chicagobob; July 7th, 2017 at 05:11 AM.
Old July 30th, 2017, 02:36 PM   #113
Chicagobob
Chicagobob's Avatar
New taillight and "fender"
So, inspired by Rielen's $10 Amazon Acerbis knockoff dirt bike taillight/fender from this thread, we decided to again change the rear of the ultralight Ninjette cafe/scrambler. The idea was to control rainwater spray while adding as little bulk as possible to the rear of the bike. This light weighs only a few ounces, looks sleek, and is bright.
We replaced the $6 Chinese taillight and plate aluminum license holder with the dirt bike item, but then what to do about the license plate? Fortunately, we had one of those bobber-style axle mounted plate brackets. It needed a little trimming to thin the mounting hole area enough to allow the axle nut to fully seat, but it fits, and the curve even matches the bike's 16" wheel, so on it went:
Old July 30th, 2017, 02:38 PM   #114
Chicagobob
Chicagobob's Avatar
We did the same, but instead of glue, we used self-tapping sheet metal screws to mount the R/R mount to the airbox. Also, the ECU is now in the battery box with the Ballistic 4-cell dry battery.
Old July 30th, 2017, 03:40 PM   #115
Cra1g
Cra1g's Avatar
I need to do this. My ECU is just sitting freely where the tool tray would go. It works, but it's probably not ideal.
Old August 22nd, 2017, 01:25 PM   #116
Kool-aid
Kool-aid's Avatar
Chicagobob, found your bike in google image search months ago. You have been my inspiration for my build. I cannot find the pic of how you mounted the brain and rectifier. I'm guessing the battery looks to be in the stock position as well as the fuse box. Love how you trimmed the side pieces. Looks good. Just the right amount of naked.
Kool-aid is offline   Reply With Quote
Old August 22nd, 2017, 02:55 PM   #117
Chicagobob
Chicagobob's Avatar
Here's the pic:
Since this was taken, we switched to a Ballistic 4-cell battery, very small and light, which is in the battery box, leaving room for the ECU in there also. The rectifier is still bolted to the airbox like it is in this photo. We cut out the part of the rear fender that had the rectifier mounting lugs, and screwed it to the airbox with sheet metal screws.
We've also since painted the coolant reservoir silver.
Old August 22nd, 2017, 07:46 PM   #118
SRoehr
Motorcycle(s): 2009 Ninja 250
Some folks have asked for details of how we mounted the Trail Tech Vapor to the steering lock housing, so here they are:
We trimmed the lower tab of the Trail Tech mount, ground it thinner, and slipped it under the shroud. You can bend the mount to get the viewing angle you want:
Then we drilled through the whole thing and screwed in a couple of small bolts (which really aren't the right type, but they were the only small stainless bolts we had at the time):
You can see that the gauge is very close to the headlight (so much so that the air temp usually reads high from the headlight's heat), and that it could have been mounted directly to the headlight bucket with spacers.
Hope this helps.
Chicago Bob, do you know which model vapor you installed? My son hit a deer witg his bike and now wants to rebuild as a cafe style. I've never worked on bikes so this is all new to me. We installed the headlight, no just need to replace the gauges and figure out how to wired it all! Any suggestions are greatly appreciated!
SRoehr is offline   Reply With Quote
Old August 23rd, 2017, 05:32 AM   #119
Chicagobob
Chicagobob's Avatar
Any of them will work. But call Trail Tech to get the correct tach wire (with a built-in resistor) for your model of bike. The pregen works particularly well with the Trail Tech dashboard because the bike's indicator lights fit into the back of the Trail Tech board, so you don't have to cut and splice any of the wires.
Old August 23rd, 2017, 10:28 AM   #120
Kool-aid
Kool-aid's Avatar
Thank you very much. I'll throw the airbox back in. I was going to go with the two cone air filters, but seems like using the airbox for a the battery box as well as a mounting surface works great. I'm gonna pull the fender and trim it up as well. I am very sorry for copy catting your build. bike looks great and everything you've done is amazing. I will be doing some differences for the lights front and back, so they will be a little different =)
this front light
https://www.amazon.com/gp/product/B0...A1YO4CUGMH8FEZ
this rear light
https://www.amazon.com/gp/product/B0...=ARHL164GNCEO7
and these turns
https://www.amazon.com/gp/product/B0...A2O0WRO2IFEXV7
I will be running the same look for handlebars. its a great look. and the trailtech looks great. I'm going to try the cheap knockoff first. Its 40.00. I'm sure i will hate myself for it.
https://www.amazon.com/gp/product/B0...=AY1GFLIL9VDFX
"the field mouse is fast, but the owl sees at night"
Lightening her up Chicagobob 1986 - 2007 Ninja 250R Tech Talk 57 October 7th, 2014 10:55 AM
[RoadRUNNER] - The Lightening LS-218 the Electric Superbike Ninjette Newsbot Motorcycling News 0 May 26th, 2014 03:01 AM
[motorcyclistonline] - VIR Cancels Suzuki White Lightening Nationals, AMA Pro Road Ra Ninjette Newsbot Motorcycling News 0 July 11th, 2011 07:30 PM
[superbikeplanet.com] - VIR Decides No DMG: "White Lightening" Indeed Ninjette Newsbot Motorcycling News 0 July 11th, 2011 04:30 PM
[superbikeplanet.com] - MotoGP: Thunder & Lightening On The Grid Ninjette Newsbot Motorcycling News 0 March 16th, 2010 09:50 AM
