May 1st, 2014, 05:09 PM | #1 |
Join Date: May 2014 Motorcycle(s): 1994 ninja 250 Posts: 4
petcock leaking
Im new here and i have a few questions im hoping you guys can help with. This petcock started leaking after sitting over winter. I opened it and checked the gaskets and they all look fine, the spring looked weak so i put a stronger one then no gas would flow and bike wouldnt start. So back to old spring now it leaks again. The gaskets alone are like 45 bucks but a new petcock is like 80? even on ebay?? Would a petcock from a new gen 250 work on my 94 or should i just bite the bullet and get the new oem one for 80 buck? Any sellers on here by chance?
May 1st, 2014, 05:16 PM | #2 |
Check the similar threads that now show at the bottom of this page; the last two seem on point for this.
May 1st, 2014, 05:17 PM | #3 |
Welcome Sean! And good luck!
May 1st, 2014, 05:17 PM | #4 |
I'm crazy,your excuse is?
stretch the stock spring and call me in the morning. This will give it more push.
May 1st, 2014, 05:31 PM | #5 |
thanks for the replies i will check those threads. but does any1 know if a petcock off a 08+ will fit with a little extra line added?
May 1st, 2014, 05:57 PM | #6 | |
In what position is leaking? After a while in contact with gasoline it may stop leaking.
May 2nd, 2014, 07:29 AM | #7 |
it leaks in all positions, it seems to be around where the two metal pieces come together
May 2nd, 2014, 10:17 AM | #8 |
Rebuild parts are cheap and commonly available from places like http://www.ronayers.com and http://www.bikebandit.com . If it's flowing fuel in the OFF position or when the engine isn't running then you need a new diaphragm, and if it's leaking externally you need a new gasket. It's super easy to rebuild one of these, basically just take it apart, clean the pieces, put the new parts in, and reassemble. The ones from later model bikes won't work as they've got the mechanism for the fuel level gauge so the mounting pattern is different.
May 3rd, 2014, 06:30 AM | #9 |
would this one work? looks like it has a vacuum and gas hose
http://pages.ebay.com/motors/link/?n...389048&alt=web |
May 3rd, 2014, 07:50 AM | #10 | |
Please read this article: http://faq.ninja250.org/wiki/Rebuild...tcock/fuel_tap As you see, the petcock can only leak in three ways: 1) Around the handle: When the big O-ring has shrunk. 2) Down into the carbs: When the disc-shaped rubber piece has shrunk and/or the spring washer is not putting enough pressure on it. 3) Through a perforated vacuum diaphragm. If the oval O-ring at the base of the tank has shrunk, fuel could cover the whole petcock, misleading you to think that the leak is originated in the petcock itself. The vacuum operated valve attached to the diaphragm fails (allows flow of gas into the carbs when the engine is off) when the little O-ring has shrunk and/or the spring is not putting enough pressure on it. The metal parts never wear out, reason for which you only need to buy the mentioned rubber parts to repair the petcock, ......... or soaking the whole thing in gasoline until the those dried parts (due to a long storage with empty tank) swell back to normal.
August 2nd, 2014, 05:30 AM | #11 | |
Captain 2 Sexy
Join Date: Apr 2014 Motorcycle(s): Kwaka EX250 Posts: 241
August 2nd, 2014, 05:33 AM | #12 |
Captain 2 Sexy
Has anyone tried to take one of these apart, clean it and then reassemble making certain everything was properly torqued?
I think this is the course I will take since I am going to have to tear into it eventually. BTW, a quick search revealed a new OEM petcock could be found for just under $60.00 + shipping. According to the FAQ link the rebuild kit is $50.00 + shipping. I don't see the sense in moving forward with a full rebuild if that is the necessary route. |
August 2nd, 2014, 04:33 PM | #13 | |
Don't hesitate about taking it apart; it is very simple. All you need is a repair kit which contains all the soft parts. Nothing is torque-critical.
August 4th, 2014, 06:22 AM | #14 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
I just bought a new one for 65 bucks. The nipple on the old one had come out so after jamming it back on there I figured a new one would be the better buy to stop the leak.
August 17th, 2014, 08:16 PM | #15 |
Join Date: Feb 2014 Motorcycle(s): 2003 Ninja 250R Posts: 5
Partszilla
I have been buying all of my parts from www.partzilla.com and the are all OEM parts. I just got a fuel tap or petcock for under $60. I like them so far. They have saved me tons of cash.
August 18th, 2014, 06:32 AM | #16 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
I bought one of these kits
http://www.ebay.co.uk/itm/KAWASAKI-G...item3f368a99f7 Basically I wanted the diaphragm which had a tiny tear and that fitted fine but the base gasket was different, The original '91 plastic washers crumbled and the new ones fitted fine One problem is that the "vacuum only" taps you can prime by sucking on the vacuum line but it takes very little suction to open the valve. If you suck hard you can tear the diaphragm. |
Leaking gas | Alisha_Ardella | 2008 - 2012 Ninja 250R Tech Talk | 23 | May 11th, 2015 10:41 AM |
Coolant leaking into oil and oil leaking out of somewhere. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 25th, 2013 04:09 PM |
Vacuum nipple came off petcock - fix or replace petcock? | fierostetz | 1986 - 2007 Ninja 250R Tech Talk | 3 | November 24th, 2012 11:03 AM |
Fuel Petcock Leaking | FrankW | 1986 - 2007 Ninja 250R Tech Talk | 9 | July 8th, 2012 04:19 PM |
leaking petcock | crackerjack | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 15th, 2010 11:47 AM |
