June 23rd, 2014, 05:31 AM | #5761 |
June 23rd, 2014, 05:32 AM | #5762 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
^^ yup, its a much better look.
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
June 23rd, 2014, 06:28 AM | #5763 |
antiant
MOTM - Oct '14
Added a RAM mount, will be adding another soon, hopefully.
June 23rd, 2014, 08:32 AM | #5764 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
Drag raced it!
First time I've ever drag raced anything, plenty of race starts but drag racing was new. Bike feels much better and I was actually able to hang with the other 250s wheres as my old motor/exhaust and tune would get left behind.
MCRA.com |
June 24th, 2014, 05:51 PM | #5765 |
Drained some Seafoam + E0 from 2012 from the tank and filled with new E0 + Seafom purchased today.
Reinstalled a blue peg I bought from eBay a couple years ago because I finally found a replacement M4 set screw (at Lowe's, no less!). Played around and discovered that the Arctic Silver Thermal Adhesive on my custom CDI cooling solution failed and my heat sinks fell off. You can tell that they never had good contact in the first place. I plan to try again with a lot of pressure if I can figure out how to clean off these old scrap PC heatsinks. The stuff is pretty much Arctic Silver thermal compound inside a hard-drying epoxy. Since I'm doing so much other electrical work on the bike I should probably stick some 40mm PC drive bay fans down there and set them up so that they only come on when the bike is running, but I hesitate to add moving parts. Airflow should already be much improved (no insulating rubber surround, mounted to Sportisi undertail with no molded obstructions using minimal perforated pieces I stuck on myself). |
June 24th, 2014, 05:59 PM | #5766 |
yes, I'm famous.
Join Date: Nov 2012 Motorcycle(s): 2009 Ninjette 250R Posts: 80
Took a ride around town and enjoyed myself until some punk in a 02 eclipse pulled up next to me at a light and revved his engine then pulled away from the line. Long story short, all he ended up doing was looking at my taillight.
I cant wheelie and that makes me sad. |
June 24th, 2014, 08:39 PM | #5767 |
Motor halfway assembled. I need to order an output shaft seal and get around to porting the heads.
June 25th, 2014, 10:10 AM | #5768 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Not related to Ninjette, but sold the ZX6R today.
I will be done with bikes for the next couple of years, thank you Ninjette and all the helpful members. |
June 25th, 2014, 01:15 PM | #5769 |
You're still welcome to stick around but the best of luck to you in your life endeavors.
June 25th, 2014, 05:49 PM | #5770 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250R, 2007 Ninja 650R, 2001 F650 Dakar Posts: A lot.
Inspected front sprocket cover interior. Already there is fling-off from the chain. Arrrrrrgh!!! Then again, I may need to just clean and start over, since I did notice a bit of blue cleaner dripping off the front sprocket, which leads me to believe I didn't get all the cleaner off in the first place. Stuff I need to do tomorrow or Friday has been added to the list. Rrrrgh. Thank goodness for air compressors to aid in quick drying that front sprocket.
June 25th, 2014, 06:39 PM | #5771 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
Rode to work this morning and had the headlights flash and burn out taking out the fuse with it, and having to ride the rest of the way to work with no headlights.
Got out of work and had to buy a new headlight and replace the fuse along with replacing a burnt out tail light that never seems to last very long. |
June 25th, 2014, 07:18 PM | #5772 | |
June 25th, 2014, 08:39 PM | #5773 |
Getting ready for round 4, had 2 little helpers causing some "issues".
NO LEAKS!!!! Check
June 25th, 2014, 08:46 PM | #5774 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
Technically this was yesterday, but I rode her home from the station. The bike had zero gas in it and I forgot to carry some with me. Luckily I met a good Samaritan who sold me half a liter of fuel, just enough to get me to a pump.
I'm really unhappy with my brakes coz they are way too spongy for most of the travel. Zip tied the lever to help bleed out some of the air that's likely still inside. Can't wait to switch over to my up coming radial master cylinder and caliper mod |
June 25th, 2014, 10:12 PM | #5775 |
Lost my brake pedal steppy thing on my rainy ride to work this morning. No lock tite fail
June 25th, 2014, 10:46 PM | #5776 |
Virgin Blood
Join Date: Jun 2012 Motorcycle(s): '10 Ninja-250 Posts: 106
Adjusted my shift linkage to accommodate a pair of used riding boots a friend gave to me. It was getting late and I had to stop but I think I'll be able to really dial it in tomorrow.
While riding the bike through my neighborhood tonight I was struck by how freeing riding a bike is. Best purchase in a long time. |
June 26th, 2014, 09:28 PM | #5777 |
Join Date: May 2014 Motorcycle(s): 2004 Ninja 250R Posts: 26
I was finally able to balance the wheels today after installing new tires last week. Ordered one of the Marc Parnes portable balancers and it is super slick!
June 26th, 2014, 10:30 PM | #5778 |
Join Date: Apr 2013 Motorcycle(s): 2013 Kawi Ninja 300 Posts: 109
After a week long, finally adjusted the rear shock, painted my rims, installed new tires, balanced, and aligned them.
June 26th, 2014, 10:54 PM | #5779 |
This seems to have worked, will confirm after a ride. Brake lever no longer feels mushy tho, so that's a definite plus.
June 28th, 2014, 07:28 AM | #5780 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
I installed a Yoshimura slip on exhaust. I bought this off a guy on the forums. See pic below. Put it on this morning and it sounds bad ass. I love how it sounds.
Riding as I stole it. |
June 28th, 2014, 08:45 AM | #5781 |
Board Member
Changed the main jets.
June 29th, 2014, 01:12 PM | #5783 |
Board Member
June 29th, 2014, 07:26 PM | #5784 |
Certified looney toon
MOTM Jul '13, Jul '14
Got a little sticker crazy ...
5 out of 5 members found this post helpful. |
June 29th, 2014, 08:18 PM | #5785 |
Board Member
You mean to tell me that you haven't been to wi!!!
June 30th, 2014, 08:58 AM | #5786 |
Fighting Texas Aggie '05
Flogged her for two days at the track, MSRC CCW Sat and CW Sun.
June 30th, 2014, 09:30 AM | #5787 |
You're still missing KY though...
June 30th, 2014, 09:44 AM | #5788 |
50 never crossed the river, i could've thrown a rock into Kentucky!
Ah shucks, guess I need to come back. LOL
June 30th, 2014, 09:47 AM | #5789 |
Well sure! That route looks like you avoided KY on purpose.
June 30th, 2014, 10:42 AM | #5790 |
Put some new spark plugs in.
July 1st, 2014, 12:35 PM | #5791 |
MOTM - Sep '14
filled it with gas
4.55 gallons
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
July 1st, 2014, 12:56 PM | #5792 |
July 1st, 2014, 02:06 PM | #5793 |
NSFW Bike porn!
July 1st, 2014, 05:50 PM | #5794 |
Board Member
Nice wires.
I played with the jetting again. |
July 1st, 2014, 06:43 PM | #5795 |
I like the box guard for the chain lol
July 1st, 2014, 06:55 PM | #5796 |
Join Date: Jun 2014 Motorcycle(s): 2010 Kawasaki Ninja 250r Posts: 11
I went to work! Then came back home, took the freeway too.
July 1st, 2014, 07:11 PM | #5797 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Looked through boxes of parts an drooled, way too tired an its bedtime
But hey least I got the parts, an a fancy shirt, an stickers... Is that why folks say I act like a kenda Gardner? |
July 1st, 2014, 07:17 PM | #5798 |
Rode around and did some errands. Due for another oil change and chain maintenance, already. I feel like I'm doing it every week. Maybe I need to stop going on 200+ mile rides every weekend, while using the bike as a daily driver.
July 2nd, 2014, 04:38 AM | #5799 |
Join Date: May 2014 Motorcycle(s): 99 Ninja 250 Posts: 217
Well it was not today but Saturday the 28th I replaced the rear shock with a new gen shock and installed Soupys dogbones. I also went ahead and serviced the Uni-track since it was off the bike. I raised the rear and it has changed the maneuverability. Lower speeds it is more agile and it handles better through turns. Much more to come.
July 2nd, 2014, 11:16 AM | #5800 |
Hooligan
Join Date: Jun 2013 Motorcycle(s): 2013 Ninja EX300 Posts: 250
Ordered my Pirelli Diablo Rosso IIs. I can't wait for them to come in and get installed because the stock tires just suck.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300 |
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
