Old June 3rd, 2015, 07:27 PM   #41
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
All this talk about boiling fluid and temp of fluid, has me wondering if im doing something wrong. Mine doesn't go fast enough, quick enough to even get brake fade, I mean its a 250 not a 1000.
This is my second year doing track days on the wee little ninja. I flushed the original fluid with new and went to the track with stock lines and pads. The bike only had 4k miles.
It seems just sitting up, getting out from behind the almost fairing it has and closing the throttle does a pretty good amount of slowing then give a touch of brake and toss it into the corner.
rubber side down is offline   Reply With Quote
Old June 3rd, 2015, 10:49 PM   #42
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
If you're using your 250 brakes enough to boil your fluid you're messing up. Period.
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old June 4th, 2015, 07:02 AM   #43
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
^^^ dayyyyuuuummm!!! They are proud of that stuff right?!?!?!?!
Makes me ashamed to say I use NAPA DOT 4. lol
Lemme ask... is there really a difference in brake feel based on a change in fluid? I have tried a few different brands over the years, seems to make no difference to me?!?!?!
I don't know about differences, but did you know that when you ride with Tony's Track Days you automatically get a racer discount on Motul products? And it's one heck of a discount.
End of last season I took full advantage of that... probably going to do it again this year.
http://www.tonystrackdays.com/catego...tomer-deal.htm
Should help to offset the cost of riding at Palmer in August just a bit, no?
Old June 4th, 2015, 07:04 AM   #44
Lol, yea and the 82 cents I found under my couch and the 29 cents I found in the drier. Yep, it all is going in the "Palmer Jar".
hahahahahahah
Old June 4th, 2015, 07:54 AM   #45
adouglas
adouglas's Avatar
Isn't this you?
Might want to up your game on the messaging front....
Old June 4th, 2015, 07:57 AM   #46
^^^ bwahahahahhahahahah
That is so me, the hat says it all!
Old June 4th, 2015, 08:00 AM   #47
accumack
accumack's Avatar
Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol
The Motorex I got has a 509f boiling point. The Motul they had was something like 506f.
accumack is offline   Reply With Quote
Old June 4th, 2015, 08:46 AM   #48
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
+1 on the front steel line. The extra feel is worth it's weight in gold.
sell you one for 1/2 its weight in gold!
My Cafe Racer Build
My intro post
Old June 7th, 2015, 09:15 AM   #49
Mike K
Mike K's Avatar
Motorcycle(s): 2014 Ninja 300 track bike, 2007 Suzuki GSXR 750 track bike, 2002 Yamaha R6, 1995 CBR600RR f3 track bike
Brake fluid arrived yesterday. Waiting patiently for the pads and braided line...waiting...
Track, track, track
Mike K is offline   Reply With Quote
Old June 7th, 2015, 09:46 AM   #50
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
hahahahahahah
I'm starting to think I need to invest in a couch that always gives me money like yours does
That hat is so much better than some of the stuff they try to pass off at my local hat stores
Old June 8th, 2015, 07:26 AM   #51
adouglas
adouglas's Avatar
The problem is that it was originally white.
Old June 8th, 2015, 07:28 AM   #52
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
Old June 8th, 2015, 07:37 AM   #53
Old June 8th, 2015, 08:20 AM   #54
Fishbine
Motorcycle(s): '10 Ninja 250 track bike, '06 Goldwing, '81 HD FXB
Man, Cal Crutchlow has really let himself go
Fishbine is offline   Reply With Quote
Old June 8th, 2015, 08:17 PM   #55
Mike K
Mike K's Avatar
Oh yeah! The parts were sitting on the front step when I got home from work this evening. Guess what I'm doing tomorrow...
Track, track, track
Old June 10th, 2015, 10:11 PM   #56
Mike K
Mike K's Avatar
Turns out that I ordered the rear hose instead of the front so I only did the pad install after first giving the front caliper a good cleaning. I did go ahead and order the correct front braided line and figured I'd get new rear EBC pads too.
Another question: Which fuses to pull for the track? I'd like to disable the blinkers, horn and headlight. The wiki http://faq.ninja250.org/wiki/How_to_check_the_fuses details what each fuse controls. Looks like #1, #2, #5 and #6. Anyone know if I'm right?
Thanks
Track, track, track
Old June 10th, 2015, 10:16 PM   #57
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
The new gen has a fuse diagram on the fuse box. I don't know about the pre-gen.
Floki is offline   Reply With Quote
Old June 10th, 2015, 10:20 PM   #58
Mike K
Mike K's Avatar
I'll have to check it tomorrow. I don't recall either.
The lowered risers should arrive tomorrow.
Track, track, track
Old June 12th, 2015, 11:36 PM   #59
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I would rather remove all of those then just pull the plugs on the headlight and tail light, no need to mess with fuses. They unplug and clip right back in when you're done
Old June 13th, 2015, 05:26 AM   #60
^^ werd. Just pull all of the ones that the bike doesn't need to run. No worries about the horn or headlight or anything then.
Seems cool to me how the whole bike runs on 3 fuses, including the dummy warning lights seems like *just maybe* the bike was meant to be run on track haha
Old June 13th, 2015, 06:15 AM   #61
Mike K
Mike K's Avatar
I'm here. Just finished the first classroom session. About to get suited up. Fingers crossed.
Track, track, track
Old June 13th, 2015, 08:10 AM   #62
Gir r done! Wish I was there to watch.
Old June 14th, 2015, 04:44 PM   #63
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
are you keeping up with Drew? if not then you aren't going fast enough.
TEAM ALFALFA
www.apexassassins.com
Old June 14th, 2015, 06:10 PM   #64
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
update?
Old June 14th, 2015, 06:25 PM   #65
Mike K
Mike K's Avatar
It was AWESOME! Great group of guys. The guys pitted around me were friendly and helpful. A few of them watched me out on track and gave some great feedback. Mark (the coach) was just hands down the friendliest and most helpful guy around. He wasn't even my coach but numerous times he sought me out and gave me some invaluable observations and tips.
The Ninjette got a lot of attention for a couple of reasons. I was the only one on a 250 and it's apparently as loud as f**k! I knew that it was sort of loud but at bunch of guys came over to see what I was riding. They said that they always knew where I was on the track.
It was a great day spoiled only by an incident in the third session. I overcooked it going into a turn an was way off line. I went down hard but luckily it was in the grass. I'm pretty sore now, actually it hurts like hell now, but I got up after figuring out which way was up, picked up the bike with my good arm, (hurt my right shoulder) and tried to get her started. No good. The bowls must have drained when she was on her side. The front brake lever was broken too. I had the to suffer the ignominy of having my trusty steed wheeled onto the truck by track officials and me loaded (I walked actually) into the ambulance. Long story short-- strained shoulder, small abrasion to my right forearm, small bruise on my forehead and seriously damaged pride.
I fixed the brake lever, went back through tech and ran three or four more sessions. By the end I had to use my left hand to lift my right hand onto the throttle. In all of those sessions I worked on nothing but getting the line right, hitting entry, apex and exit and being smooth. I did almost every lap in 4th or 5th gear, only used the brakes when coming up on someone in the turns. Passed a few guys, got passed by almost everyone but had a blast. The two hour ride home was painful and slow and work today sucked I was so sore.
Can't wait for the next track day.
Mike
Track, track, track
Old June 14th, 2015, 06:31 PM   #66
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
so pretty much you had almost the exact same start to track riding that I did, heal up man that grass is harder than it looks
what exhaust do you have on the bike? I had a two bros on my 250 (and may have a yoshi on it soon)
Old June 14th, 2015, 06:41 PM   #67
Mike K
Mike K's Avatar
It has a Muzzy. It's louder than my 750 which has a Two Brothers slip-on.
It was just an awesome experience. I'm not really so interested in street riding now. Lol. All talk of getting your knee down street riding just seems silly and dangerous now. I am eager to get the 750 registered so that I can get a few hundred miles on her to familiarize myself with all of the differences and there are a lot. My Ninja is now a dedicated track bike. I'm stripping her down to only what's needed to track her. I might change the gearing to give me a little more top end speed. I have Woodcraft clip-ons and lowered risers for her. I think that I'm going to put on the lowered risers first. The Pirelli's are nice and never once gave me cause to doubt them. I'll load pics later.
Track, track, track
Old June 14th, 2015, 06:42 PM   #68
Mike K
Mike K's Avatar
I did brotha! I did.
I want to thank all of you guys for the advice and information here in the days leading up to this.
Track, track, track
Old June 14th, 2015, 08:24 PM   #69
Mike K
Mike K's Avatar
Some pics:
Track, track, track
Old June 14th, 2015, 08:30 PM   #70
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
not bad for a first track day, remember the head leads so put your head in the direction you want to go and let your body follow it
I spy mark in the first pic That dude can match almost anyone's track day pace and analyze your riding while he does so
Old June 14th, 2015, 10:00 PM   #71
Mike K
Mike K's Avatar
I can't say enough good things about Mark. Like I said, he wasn't even my coach and he gave me more feedback by far, very, very far than anyone else. Pretty much after I went down the coaches from my group had no more input. If it wasn't for Mark and one of the more experienced guys that was pitted next to me (I didn't know it but each followed me for a few laps) I would have been on my own. I took everything that Mark told me and incorporated it each time I went out. My biggest lesson was exactly what you said-- look through the turn, head up, connect the dots further out.
My Ninja turned its 10,000th mile on the track by the way!
Track, track, track
[roadracingworld.com] - SoCal Track Days Issues Revised 2015 Track Day Schedule Ninjette Newsbot Motorcycling News 0 December 30th, 2014 12:00 PM
[roadracingworld.com] - N2 Track Days Takes Over NESBA Track Event Operations Ninjette Newsbot Motorcycling News 0 March 26th, 2014 12:50 PM
[roadracingworld.com] - Sportbike Track Girl Schedules Track Days For Women Only, At Ninjette Newsbot Motorcycling News 0 April 23rd, 2012 04:20 PM
[roadracingworld.com] - Racers Edge Performance Track Days/Practice Days Now Open To Ninjette Newsbot Motorcycling News 0 March 25th, 2011 10:50 AM
[roadracingworld.com] - Sportbike Track Time Hosting Track Days At Barber Motorsports Ninjette Newsbot Motorcycling News 0 August 1st, 2010 11:20 PM
Except where otherwise noted, all site contents are Copyright 2022 ninjette.org, All rights reserved.
